Bent Frame !! HELP
Bent Frame !! HELP
So i have a frame in my possesion currently that upon examining appeared to be bent near the lug under the down tube. there is some suspicious dots also. when i removed the headset (removed it with my hands, dont know if thats supposed to come off as easy..) the head tube was aslo bent. so im worried about it. it doesent look as bad but still..
heres some pics: (bent right under the lug, thats a down tube, otherwise everything else is good)
Liked 1,102 Times
+1 The fact that the headset came out by hand confirms the headtube is damaged also. Headset cups should be a very tight fit and should have to be driven out with some effort.
A frame builder could repair it by replacing the damaged tubes and repainting the frame but the cost will be prohibitive unless the frame has great value otherwise. Scrap it.
the guy told me that he had it sandblasted and repainted, and that he hadnt noticed this dent. yeah i can take the headset (one thats on the down part of the head tube) off with my hands no problem. might get it for $30. and i think it is some miele frame. fork is trash tho.
Liked 1,102 Times
Mechanic/Tourist
Si Senior
Bikes: Too Numerous (not)
Liked 10 Times
Yup. I tossed out a frame when head-on collision damaged it. I kinda regret not cutting it up --because I suspect a picker came along and grabbed it for rebuild.
You should probably destroy it.
Liked 678 Times
I don't know where you are from but a good frame builder in you area should be able to render the death blow to the frame for you or tell you he can save it. I would solicit his input first, the internet will tell you that a bent Renyolds 753r frame and fork can not be straightened but i have 5200 miles on a now beautiful frame straightened for $80 by Andy Gilmour in Tucson that is as straight and true as any frame I have come upon in my 50 years on bikes. He has just repainted for me and it is a gem, can't wait to build it up. Andy would not charge you to tell you it is gone.
