Fork transfer 54 to 56 cm frame: odds of success?
Hump, what hump?
Bikes: See signature
Quoted: 337 Post(s)
Liked 227 Times
Anyone know offhand the minimum fork steerer tube length for a 56cm frame? I have a fork in a 54cm frame I can measure. Not in possession of the 56cm frame, but I may purchase it. It is 1000+ miles away.
Quoted: 332 Post(s)
Liked 743 Times
Getting a measurement of the new frame’s head tube length and comparing it to yours would be the best bet. If you have extra spacers in your current headset that will give you some wiggle room too. This is assuming the 2 frames use the same headset interface.
Quoted: 3814 Post(s)
Liked 3,345 Times
depends also on what headset they were designed for use with
a Chris King for example needs a lot of steerer while a Stronglight P3 needs several mm's less
Quoted: 359 Post(s)
Liked 582 Times
The highest stack headsets I've used are Campy Record. The lowest was a Chris King I just traded away in January. I'm thinking the difference between the two was maybe 12-15mm. I'm not sure if that's enough to make up for the head tube length difference.
Other than the 54's fork being from a bike with a Campy high-stack headset, and using a low stack headset on the 56, I'm not very sure of your likelihood of success.
The Innicycle headset/stem adapter will likely reach down into that 56's head tube and grab that 54's fork. I've done it.
Bikes: 1981 Bianchi Specialissima, 1971 Bob Jackson. 2012 Kestrel 4000. 2012 Willier. 2016 Fuji Cross 1.1, 1950 Hetchins, 194X James Fothergill, 1971 Paramount P15, 1973 Paramount P12, 1963 Legnano
Quoted: 279 Post(s)
Liked 955 Times
I'm thinking it's going to be very low probability. A good frame builder might be able to either replace the steerer tube on the 54's fork or cut the steerer tube and braze an extension. I've seen both options discussed in different threads. I'm looking at potentially using a fork from a 57 in a 58 and those look like my best options if I need to swap out my current fork.
If it's not a matching fork, or a special fork, I would just look for a close enough match.
Bike Butcher of Portland
Bikes: It's complicated.
Quoted: 4682 Post(s)
Liked 5,802 Times
Steerer tubes on production frames are "just the right length". If both forks are from the same production make, model and year, the fork for a 56cm frame will be about 2cm longer than for a 54.
Also, head tube lengths vary from one make and model to another even if they have the exact same seat tube length (which is how classic diamond frames are typically measured).
Hump, what hump?
Quoted: 337 Post(s)
Liked 227 Times
Thanks for the replies so far. I figured stack height would have some bearing (no pun intended) on steerer tube length, and I’m aware most tubes are cut to match, but my headset has several spacers, so I’m hoping for wiggle room. I may ask the seller to measure the head tube. It’s the same bike frame and year, even color (!) just different in size. He’s selling the frame only.
Liked 5,802 Times
If the buyer isn't willing to measure the head tube (with +/- 1mm accuracy), pass. Otherwise give me a PM and we can discuss building you a custom fork
Hump, what hump?
Quoted: 337 Post(s)
Liked 227 Times
I'd be willing to bet cash money, and give you very good odds that your fork from a smaller frame won't work on the same model and year with a 2cm taller frame. The head tubes are most likely 2cm difference in height.
Can you make me a reasonable Ciocc-style fork for a 58cm frame? The last time I checked, the Pellizolis (sp) would make one new for around $300.
Liked 5,802 Times
My Ciocc Competition is an orphan. It came with a Tange fork, correct for the frame size, but nothing like the original. I don't need another orphan frame, so I'll just pass on this one.
