No cable guide under BB
A quick question for the mechanics here. This is the photo of the compartment below the bottom bracket. Am I missing the cable guide? Or the cables are supposed to go naked directly on the frame ?
I am worried the cables will saw through the frame. There is no bolt to attach a cable guide. The silver “nut” is for the bolt that holds the compartment cover.
Quoted: 18381 Post(s)
Liked 4,512 Times
I'm wondering if the frame is designed to have full length cable housing.
Not sure to be honest. It’s a no name Chinese frame who I promised I would build for a friend but I was expecting a cable guide.
Bikes: Velo Orange Piolet
Quoted: 2228 Post(s)
Liked 2,011 Times
Maybe the cables go inside the frame. Are there holes in the frame by the head tube to route the cables into?
Liked 11 Times
Is it a brand new frameset? Is it possible that its a Di2/EPS only frame? If you contact the manufacturer I'm sure there is probably a cable guide that bolts onto that cover.
Does the cover come out? Is that single hole at the back where the RD Di2 cable goes into?
Yes it is an internal route frame. This is actually inside the frame. There is a small “door” that opens to this and when I place the cables Into the frame they get routed into this compartment.
It is a new frame and it is di2 ready. But it has both holes for di2 and cables. There are two holes near the FD one for a di2 and another smaller one for a normal cable.
Quoted: 1438 Post(s)
Liked 1,092 Times
If you want to install a cable guide you could use a longer bolt and pass it through both the guide and cover.
Liked 4,512 Times
If you get "shift" cable housing, it has longitudinal wires, and a liner to help reduce both friction and compression.
It is also slightly smaller in size than brake cable housing.
If I was you, I'd start with a piece of cable housing and shove it into the holes to verify whether you have cable stops, or if it just keeps going (full length cable). Or, perhaps cable stops in unexpected locations.
The cover plate that you removed has no grooves in it? Usually there are grooves to keep the cables in the correct position. My Colnago has a removable door, but it has grooves in it, for cable liner housing liner (not housing). This keeps the dirt off the cable. That's the only area where the cables are exposed.
What is under that cover? It wouldn’t be usual to have guides on the back of that cover. Full-length housing would be a little unusual.
Also, what is going on with the paint on the bottom bracket at the upper-left of the photo? Is there damage, or is it just an odd reflection?
Generally bewildered
Quoted: 1152 Post(s)
Liked 341 Times
I see a big hole in the front for cable housings. Are there small holes in the back for the cables themselves? Like this:?
Quoted: 4211 Post(s)
Liked 3,881 Times
AndrewRStewart
AndrewRStewart
Looking at that cover, the simple explanation is that they forgot to include the cable guide, but who knows. Any cable guide would work.
Liked 3,881 Times
I seriously doubt this. Or every bike having both carbon molded construction and internal routing aspects, that I have worked on, had their specific guide. Andy
AndrewRStewart
AndrewRStewart
With a mighty wind
Quoted: 1088 Post(s)
Liked 865 Times
I'm personally interested in these open mold bikes so I'm interested.
My immediate thought is the intent is to use a short piece of housing just under the bottom bracket. There would be cable stops that would allow this or not that should be obvious.
It could also be that the cable won't rest on the frame at all, like a mm or two away. You'd need to be concerned about the material reinforcing the holes but that could work.
I personally wouldn't be opposed to building a little barrier for the frame out of a soup can.
If it really is designed for full length housing, that's crappy. I've never gotten a bike with that to shift well.
Maybe find some used Di2?
don't try this at home.
Quoted: 974 Post(s)
Liked 512 Times
The marker over the serial appears to be a photoshop edit, to avoid posting the SN.
I assume the brake cable is internal on the top tube? And the rear derailleur runs through the top tube? Three holes with stops for housing at the head tube end of the bike? Or designed for disk brakes, allowing hydraulic housing?
This frame has one hole for cables at the bottom bracket. Otherwise, it's the same method as the 2-cable frame. Not full housing inside the frame.
I assume there's a cable housing socket at the head end of the frame? To use full length housing, it would need a single housing run from the shifter, through the down tube, then terminated at the socket in the image (if the housing actually fits into the socket and can make the bend down there -- test it first. A housing stop at the head end of the frame would have to be drilled out or removed if it's a fitting, not molded in.
one socket. There's a slot for a cable guide's wire. If there's a housing stop at the head end of the frame, it really needs a guide.
