Fix it or forget it?
Bikes: 84 John Howard, 85 Raleigh Kodiak, 84 Ross Mt whitney, 74 Masi, 82 Allez
Quoted: 40 Post(s)
Liked 7 Times
I was planning on building this Masi for the California Eroica next year but found a small ripple in the downtube just above the bottom bracket. My best guess is that the ripple is from a previous repair/repaint. I'm inclined to forget it and continue with the build as planned but thought it would be better to get some more informed opinions here first.
If I needs to be repaired I will have to set it aside for a few years until I have practiced replacing tubes enough to feel comfortable taking this on myself, or a few extra years to save up the cash to have it fixed.
Quoted: 1199 Post(s)
Liked 1,355 Times
Forget it...that frame is toast...ill be glad to take off ur hands for free.
HarborBandS
Quoted: 266 Post(s)
Liked 104 Times
I’m not even sure I see the “flaw”. If it’s just paint, this frame’s paint job looks better than most of what people are riding in this forum. And it’s on a portion of the frame that’s only visible when the bike s upside down. Hardly noticeable.
The only problem I see is of the frame was damaged and repaired poorly. And the only way to uncover that type of repair work is to remove the paint to find a weld or patch job. And hopefully it’s a real Masi!
If it were me, I’d probably take the risk and just ride it. Unless it’s obvious that the ripple is more than a paint flaw.
Can you feel a ripple or disturbance on the inside of the tube?
Another thing to try, get a small inspection mirror and look at the inside of the tube there. Is it rippled or
discolored / burned?
I'd definitely do a little more inspection before building it up.
Quoted: 753 Post(s)
Liked 737 Times
Absolute neophyte here, but... I would inspect farther up the tube for signs of of rolled out damage or bondo. Rolling blocks would not be able to get close enough to the ripple because of the cable guides. I'm not sure of the metallurgy, but this might also be a buckle from overheating the tube during construction. I've been meaning to get one of those cheap phone endoscopes for this kind of puzzle. I got one for my brother and he's used it to look inside his diesel.
Señor Member
Quoted: 1491 Post(s)
Liked 1,090 Times
I wouldn't have even noticed that. I'd go with Cassave's advice. I'd be surprised if someone would have gone through the trouble of painting up a damaged frame that nicely, but checking is the prudent thing to do.
Bikes: Colnago Super, Basso Gap, Pogliaghi, Fabio Barecci, Torelli Pista, Miyata 1400A
Quoted: 316 Post(s)
Liked 13 Times
Ahhh, I think your being overly cautious. That bike is a beauty. Build it, ride it, and just keep an eye on it - if you even remember the dimple is there.
Quoted: 40 Post(s)
Liked 7 Times
On any other one of my bikes I wouldn't worry too much about it, but this is a grail bike for me so I want to make sure riding it as is wont cause any more damage. I have another excellent option to build for Eroica California if this one should be shelved for now.
It's not in the typical place for frame damage from the usual head on collision. I'm thinking that looks like laziness in sanding the primer. Essentially a paint drip. The endoscope sounds like a great idea. It should tell you if it's sloppy paint or repaired damage.
If it turns out that the tube is buckled, AFAIK there isn't as much stress at the bottom end of the down tube as there is right behind the lug. If anyone's done FEA and knows better, I'm all ears. IMHO tube replacement is the correct remedy for damaged tubes. I don't like the idea of a frame that has to be babied on rough descents, etc.
multimodal commuter
Quoted: 1908 Post(s)
Liked 574 Times
I have never seen a frame damaged at that location and can't imagine how it could have happened. I don't think it's anything to worry about, but I'm no expert and you shouldn't be listening to me anyway.
I would post these photos on the frame builders subforum and see what those guys think.
At any rate, I wouldn't see the harm in building it up and riding it as if it's maybe not quite as precious as previously thought. I don't think it's going to fail, but better have it fail close to home than on the Eroica.
Friendship is Magic
Bikes: old ones
Quoted: 26419 Post(s)
Liked 10,380 Times
...I have produced similar optical distortions with a run in the clear coat, using 2 part urethane type clear that goes on pretty thick.
Quoted: 4511 Post(s)
Liked 6,382 Times
And keep an eye on it if it helps you sleep better.
Bikes: A few too many
Quoted: 1364 Post(s)
Liked 2,181 Times
Build it and ride it...It looks like it came from the factory that way.
Best, Ben
Best, Ben
Voltaire
Voltaire
Ride, Wrench, Swap, Race
Quoted: 1565 Post(s)
Liked 1,296 Times
Also, it might be molten brass that flowed in the wrong direction along the outside of the tube.
Bike Butcher of Portland
Bikes: It's complicated.
Quoted: 4682 Post(s)
Liked 5,800 Times
Tis but a scratch!
I gotta ripple or two right here:
After a week of consternation, I built it up, rode it a couple of hundred miles, rinko'ed it, shipped it back east and did 250 miles of credit card touring on it on my recent Tour de French Fender Day. Rode it on gravel too.
Check the inside of the down tube as other's have suggested, if you don't see any cracks or signs of welding, build the damn thing up and ride it, and I'll see you at Eroica in the spring!
verktyg
Quoted: 1036 Post(s)
Liked 1,238 Times
Bulged tubes
It only takes a few seconds to overheat thin wall tubing from the orange brazing temperature to white hot. When a tube gets that hot it quickly expands in the super heated area and can cause bulging like that because the surrounding material doesn't move as easily.
Is it a problem? Probably not. The rest of the tube is going to be strong enough to support the overheated zone. If it were a problem, it probably would have caused a crack to start developing by now.
While not as extreme as in @gugie picture above ^ ^ ^ ^, I have a 1970 Gitane with a bulged head tube... see red line, it's more severe than in the photo:
As for as the sacred holy foundries of the gods (pick a name), even the best can screw up, especially when there's a new employee doing the work. BLASPHEMY! BLASPHEMY!
I'd put it together and ride it, keeping an eye of the bulged area for any sign of a crack.
It sounds like you bought the frame with that relatively new paint job. The twin plate fork crown would have been chrome plated. One reason chrome gets painted over is that it was badly rusted.
Not wanting to create FUD (Fear Uncertainty, Doubt) here's another possibility.... The bike could have been in a front ender or a garage door encounter and had the top and down tubes replaced??? Someone replacing tubes may not have had the skills to re-braze thin wall tubing into the BB???
With regards to tubing cracks at the BB, one of my Reynolds 753 frames has what looks like a crack in down tube at the BB shell. After very careful examination and with the reassurance of a very competent frame builder who thought crack was in the braze not the tube, I decided to keep riding it.
I marked the ends of the "crack" on both sides of the BB with a Sharpie pen and keep an eye on it to see if it gets bigger.
verktyg
verktyg
Chas. ;-)
Chas. ;-)
Quoted: 40 Post(s)
Liked 7 Times
Thanks all for the advice! The endoscope came in the mail today and I was able to get a decent look at the inside of the tube.
Only slight discoloration although there is also a small indent in the opposite side of the tube. Both the bulge and indent can be felt from inside the tube as well.
Also found a ding in the top tube near the seat cluster.
The two damaged areas may be related but I dont see any reason not to go ahead with the build and see how it rides. Might keep the ball rolling on my backup Eroica bike as well
Extraordinary Magnitude
Quoted: 2608 Post(s)
Liked 1,700 Times
“It’ll buff out.”
I don’t know much about frame damage and what’s safe or not safe- I’m just glad and impressed that you’re (literally) looking into it.
Commence to jigglin’ huh?!?!
Bikes: Limongi SuperRecord, Chesini Precision, Gilmour Nuovo Record, Waterford Special Super Record, Schwinn Supersport, Tempo, Peloton Carbon, 1974 Paramount, 1974 Paramount1971 Paramount, Guerciotti Nuovo Record, Martelly Diamant Super Record
Quoted: 12 Post(s)
I've seen that stuff before.....never seemed to effect anything....
