Front and rear Dynamo hubs
shaken, not stirred.
Bikes: I've lost count.
Quoted: 1412 Post(s)
Liked 971 Times
You are unlikely to do much touring with a rear dynamo hub. The only rear dynamo hubs that I'm aware of are the Sturmey-Archer AG three-speed and FG four-speed hubs from the 1940s - 1960s. Those hubs are a bit scarce to find these days and don't generate as much current as a modern front dynamo hub. You will likely be walking up a lot of hills if you use one.
The other possible way to have a dynamo hub front and rear would be somehow rig a fixed gear sprocket to the shell of a disc braked dynamo hub. Then you'd be down to a single speed. It may work depending on your terrain.
Modern dynamo hubs from Shimano, Shutter Precision and SON are generally very reliable.
vBulletin: snafu
Likes For gnome:
Clark W. Griswold
Quoted: 4367 Post(s)
Liked 4,006 Times
I have yet to see any modern dynamo hubs at the rear gnome listed probably most of them and they are quite ancient at this point. I don't even think any BB based ones are still around. You can find bottle dynamos still but in the end a new SON hub is way better than anything else and if you are in need of more power you maybe want to consider alternative forms of power generation or better batteries. I think with a SON hub and a Cinq Plug V you will do pretty darn well and you probably could also run front and rear lights as well.
Liked 971 Times
The AG was a three speed internal gear hub with a dynamo. The FG was a four speed internal gear hub with a dynamo. They had a limited range and generally didn't allow you to set the gearing up low enough to climb steeper hills. If you could set the front chainring and sprocket up to have low enough gears to spin up a hill you would have a very low top gear for on the flat. Also as they are now very old internal gear hubs I wouldn't like to stand on the pedals when riding one as the additional torque generated may result in the pawls in the hub slipping.
A modern front dynamo hub allows you to use any gearing you like. If you have a modern internal gear hub you can probably get the gearing low enough for climbing and have a reasonable flat cruising gear. Modern internal gear hubs probably have a lower minimum front chainring to rear sprocket ratio as well. If you run derailleur gears you can run as low a gears as you like.
vBulletin: snafu
Quoted: 1188 Post(s)
Liked 1,154 Times
If you were that worried by reliability it'd be easier to carry a spare front hub and a spoke key....
Likes For Trevtassie:
Overdoing projects
Quoted: 784 Post(s)
Liked 1,238 Times
It's probably relatively easy to build a bike with a front dynamo hub and a Velogical rim dynamo and make it easy to switch between them using some SON coax connectors.
But generally speaking it's rarely the dynamo hub that fails.
The only other rear dynamo hub I know was a Shimano 4-speed automatic shifting unit. Incredibly rare though.
Quoted: 3462 Post(s)
Liked 1,468 Times
I bought my first SP dynohub seven years ago. I have no reliability concerns, I see no reason for another dynohub. My last tour, for the last two or three weeks of it I was fully self supporting on electrical needs from the dynohub.
Quite frankly, if my dynohub was unreliable, it is the bearings that are more likely to go than the electrics from it.
If you are worried that much, pull a trailer that uses the same dynohub wheel as your bike front dynohub wheel. Check out the Extrawheel trailers.
Enthusiastic Sufferer
Bikes: 2015 Specialized Roubaix, 2014 Salsa Fargo, 2013 Trek Remedy, 2014 Cannondale Synapse
Quoted: 124 Post(s)
Liked 311 Times
Half way there
Quoted: 989 Post(s)
Liked 883 Times
I've owned 3 dynohubs (SP, Shimano, and Sturmey) and found all of them to be completely reliable in generating electricity. The main lighting issue I've had is that sometimes the connectors need tweaked. Mechanically they are all good, though I did have to replace one of the cartridge bearings on my Sturmey (after 10,000 miles or so).
There's really nothing complicated about a dynohub. Basically it's a ring of permanent magnets that rotate (non touching) around a fixed stator. Worn bearings and physical damage are the only things you need to worry about. It's certainly a good idea to carry extra wiring and connectors on a tour, though.
Liked 1,468 Times
Palmer
Quoted: 1671 Post(s)
Liked 1,828 Times
Liked 971 Times
ooh that is an interesting hub. I didn't know it existed, even briefly. I may have to hunt for one to add to my obscure hub collection. You could use it to charge a powerbank to power your other electronic devices. Of course a front dynohub will produce more power and charge quicker.
vBulletin: snafu
Liked 971 Times
reading up on that obscure, obsolete Shimano hub it was rated at 4.1V and 1.2 watts.. A SON dynohub is rated at 6v and 3 watts. You'll have to ride twice as far or twice as fast to get the same charge from the Shimano rear hub as you would from the front dynohub.
vBulletin: snafu
Half way there
Quoted: 989 Post(s)
Liked 883 Times
Tape is a good carry, but like I said, extra wiring and connectors are comforting to have. It's easy to imagine an event where something snags your wire at the hub knocking it into the spokes, which then damage the wire and fling the connector into the brush. I reckon if this happened to you, you'd likely figure out how to MacGyver it with just electrical tape.
Liked 1,468 Times
My heavier duty touring bike, I consider it to be my expedition bike, on a tour the dynohub is used solely to power my Sinewave USB charger for charging batteries, no other wiring on the bike. There is wiring on my other touring bike that has a dynohub for lighting, but if I lost my dyno powered lighting, it would not be a disaster, only an inconvenience.
Thanks for answering, that might be an issue for some other people. Maybe for bikepackers that don't have front panniers and might snag a wire on something.
If anyone is curious, I described at this other link how I wired up the lights and charger on my rando bike.
https://www.bikeforums.net/electroni...b-charger.html
I’m a little Surly
Quoted: 699 Post(s)
Liked 1,294 Times
sure if your wiring looks like mine does right now but I don’t think anyone goes on the road like this
Overdoing projects
Quoted: 784 Post(s)
Liked 1,238 Times
How do you like those Pirelli Cinturato Gravel H tyres? They look interesting for a touring/rando bike.
I’m a little Surly
Quoted: 699 Post(s)
Liked 1,294 Times
that picture though is of my new cross check which replaced my touring bike as my commuter. The reason I’ve got the wires wrapped around the fork blade is I’m considering putting my local basket on the there and will need cable if I do that
Likes For Germany_chris:
