Hand cramps
Quoted: 7 Post(s)
Hand cramps
Hi Guys,
after some years of a bmx break I started riding again. After some hours my hands cramp very painfull and it takes up to two weeks to recover. I think the main problem is my deathgrip but maybe there are some things I can change on my setup to help my hands. I thought about getting thicker grips like the s&m hoder grips which are 31.5mm in diameter. At the moment I have the eclat shogun grips with a diameter of 29.5mm. The different seems pretty small but I didn't find thicker ones. I also thought about trying different bars. At the moment I ride 12 degree backsweep and 2.5 degree upsweep. Maybe more upsweep can help with putting more pressure to my index finger side because it's more severe in my pinky fingers.
Quoted: 506 Post(s)
Liked 639 Times
Hi Guys,
Quoted: 569 Post(s)
Liked 589 Times
You have 10 posts so post a picture of your set up. Treking bars have maximum position and raising you stem would take some weight off you hands.
Likes For easyupbug:
Quoted: 8287 Post(s)
Liked 9,066 Times
Sounds like arthritis to me. What are you riding? Road riding on a flat bar? No reason for a death grip.
Likes For big john:
One thing you can do to reduce the pressure on your arms in that position is rotate the handlebar backward to get the grips closer to you. But not too close your knees are hitting the handlebar. The adjustment will help move your body to the back and reduce pressure on your arms.
I ride a BMX in such handlebar position and I can be pedaling over 5 minutes out of the saddle continuously on a climb. You'll also need to learn how to move your body against the bike forward or backward and typically backward to unload your arms and then be comfortable enough pedaling in that position without straining yourself. That takes time to practice including your pedaling technique.
I prefer rolling hills when riding around with BMX bike. Out of the saddle climbing and then coasting down sat down or standing makes your faster than on flats where it's annoying to stand to pedal with little resistance or try to pedal seated on such a very low seat.
Likes For koala logs:
Grupetto Bob
Bikes: Bikey McBike Face
Quoted: 2591 Post(s)
Liked 5,661 Times
see your physician. Two weeks is extremely unusual, death grip or not.
Road 🚴🏾♂️ & Mountain 🚵🏾♂️
Likes For rsbob:
