Tubular stem hole question
Bikes: '85 Schwinn Madison, '46 Higgins Ultralite, 1950s Wally Green, '85 Trek 660, '82 3Rensho Export, '90 Trek 970, '91 Schwinn Paramount, '78 Dawes, '78 Trek 730
Quoted: 77 Post(s)
Liked 263 Times
The tubular stem hole on the Mavic rims is not allowing the tire to seat at the stem. My specialized rim has a larger hole. Do I need to open the outer hole or is there a better tire choice (using Yellow Jersey tubulars)
Likes For brewerkz:
Standard Member
Bikes: 1948 P. Barnard & Son, 1962 Rudge Sports, 1963 Freddie Grubb Routier, 1980 Manufrance Hirondelle, 1983 F. Moser Sprint, 1989 Raleigh Technium Pre, 2001 Raleigh M80
Quoted: 1297 Post(s)
Liked 940 Times
I took a look at one of my Nisi Corsa Stretto, and the inner drilling of the valve stem hole is noticeably wider than the outer, like with your Specialized. My diameter measurement for that hole is 12mm.
Unless you climb the rungs strategically, you’re not going to build the muscle you need to stay at the top.
Quoted: 3015 Post(s)
Liked 3,804 Times
Drill it. YJ tires are for spares, not riding.
Likes For iab:
Quoted: 77 Post(s)
Liked 263 Times
Likes For brewerkz:
Half way there
Quoted: 987 Post(s)
Liked 880 Times
I'd widen the inner hole a tad with a countersink bit. Clean the burrs up afterwords with a file.
Likes For Moe Zhoost:
Old fart
Quoted: 3590 Post(s)
Liked 3,401 Times
A tapered hand reamer can easily enlarge the rim bed hole without affecting the other side.
Quoted: 77 Post(s)
Liked 263 Times
Likes For brewerkz:
Bike Butcher of Portland
Bikes: It's complicated.
Quoted: 4682 Post(s)
Liked 5,802 Times
That’s what we called it in my LBS days.
Quoted: 1609 Post(s)
Liked 2,216 Times
Be careful about the taper. Make sure you don't accidently make the other hole bigger.. I would use something more like this
CONQUER Tools 5 Flute Metal Countersink Drill Bit, 90 Degree for 1/4'' Hex Shank Fit 1/8"-3/4"(3mm-19mm), Burr Removal, Deburring Beveling Chamfer Tool, Holes Shaping Trimming, Inner/Pipe Reamer - Amazon.com
Quoted: 3464 Post(s)
Liked 2,831 Times
‘cannot tell from the image, looks to be an anodized rim, I have not seen a Mavic like that with anodizing, but I have not seen everything.
I think the hand driven taper reamer will not provide a large enough hole without enlarging the stem hole.
I would use a drill press, but to be fair, not sure how I would hold it with a built wheel.
might reach for the Dremel tool, think about the forces and go that way.
if the rim does not have even a single surface eyelet… take it apart and add washers.
Bikes: many
Quoted: 1446 Post(s)
Liked 1,395 Times
Gerd Schraner (The Art of Wheelbuilding) has a bit in the back of the book about this. He countersinks valve stem holes, as they are often not sized properly to accommodate the tire lump. Can't recall who he blamed (rim or tire mfrs), but he views it as pretty much necessary.
(From memory. Not hunting for the reference at 4am.)
Likes For smontanaro:
Quoted: 1106 Post(s)
Liked 1,328 Times
Use a countersink as others have suggested - they're usually 45 or 60 degrees so it'll make the inside hole big enough without touching the inner hole
I'd put the bit in a chuck by itsellf and just use it as a hand-reamer; that ally is thin and you don't want to go too big.
Make sure you take the edge off what results as it'll be sharp - and have a look at the other holes, there's a bit of a ridge on the ones in your pics; even for those a pass with a round file might be a good thing.
Quoted: 1641 Post(s)
Liked 831 Times
The "budget" sewups you are using might have an overly thick profile at seam tape overlap around the valve stem area.
this causes the tire not to bed down completely. I experienced the same when I tried Vittoria Rallies.
I switched over to better quality Schwalbe tubulars on the same rims and I did not experience the problem anymore, after that.
72 Line Seeker
83 Davidson Signature
84 Peugeot PSV
84 Peugeot PY10FC
84 Gitane Tour de France.
85 Vitus Plus Carbone 7
86 ALAN Record Carbonio
86 Medici Aerodynamic (Project)
88 Pinarello Montello
89 Bottecchia Professional Chorus SL
95 Trek 5500 OCLV (Project)
72 Line Seeker
84 Peugeot PSV
84 Peugeot PY10FC
Blamester
Pump it good on the rim and take a gentle spin.
See what it does. Then glue it or decide what needs doing.
Quoted: 1858 Post(s)
Liked 664 Times
I've mounted up a number of Yellow Jersey tires. Some have had a bit of extra build up at the valve hole, but none with serious problems. If you can see a way to de-burr and smooth the hole on that Mavic rim it can only help, and if the hole has roughness removed and you leave no new sharp edges, I think it should survive use for a good long time.
It is possible for careless installation to result in the valve pulling and the innertube being cut rignt near the valve, which is just about a fatal injury. But it's not due to the YJ, I've had those problems with much fancier tubulars, as well (well, they at least had fancy brand names, thought they were still low-priced Thailand casings and assemblies!).
As you glue on the tire, try to manipulate the tire near the valve to keep the valve as square as possible with respect to the rim contour - valve body points perpendicular to teh tangent to the rim at that point, pointing along a radial path AT the axle. If the glue cures in this position it will help guide the whole tire to settle well. Tires change just a bit over time as the new glue cures (aka the excess solvent evaporates).
Your tire and rim should be fine. I would maybe smooth the hole a little, but would not enlarge the hole. or otherwise modify the rim. Your tire installation really should work just fine.
