Moustache handlebars - ergonomically useful or just hipster fashion?
Pondering upgrades to the Robin Hood Lenton Sports. Its currently equipped with the OE steel drop bars. Since its more of a tourer than racer, I'm considering different bars. Moustache bars seem to be an interesting halfway between North Road and drop bars. But I've read they look better than they work, ergonomically.
Anyone have experience - good or bad - with them?
Quoted: 2333 Post(s)
Liked 2,097 Times
They allow a more upright position, which for some like me is far more ergonometric.
They have fewer hand positions (three is what I get). This is not much of an issue to me but others complain about that.
Quoted: 569 Post(s)
Liked 589 Times
Now in my 70s I am going more upright and through a lot of bar and saddle changes. Moustache bars worked on a short ride grocery getter but not on a long ride for the reason above, my hands wanted more hand positions.
Likes For easyupbug:
Here is my experience with the moustache -- it wasn't as positive as I had hoped, but this is a personal thing.
What I found was that I liked the look, and I liked riding with it -- in the end, not so different from a 46 cm wide Nitto Noodle I had on it before. This is a relatively short frame for me, and still I needed a short stem; the hands move far forward on this bar. Note how far the seat post extends here to get an idea of the fit.
I'd agree with the "three positions", but there is not much difference between grabbing the hoods and just having the hands on the bar. I rode it either way "at speed," and it was comfortable.
What I didn't like, and why I swapped the bar out after a while:
- The hands are rather close together in the forward position -- note that the "Albastache" has moved them farther apart.
- The "different positions" are for the hands, my back hardly moves, at least the way I had it set up.
- Worst of all, in iffy terrain, the backwards position was is just peachy, with plenty of control and a wide grip -- but ya can't brake! I found that just silly.
So: For a bike that might see some trail work, get a 48 cm Noodle and install 'interrupter' brake levers.
That will give you good control and plenty of hand positions.
I have a bike set up like that and wound up descending a real steep "path" between two vineyards, as I had misjudged where I was on the trail network on a really steep hill... when you're going down a 25 % grade, all of a sudden the hoods of a drop bar are not a great place to be for braking.
Finally, this bike is now set up with 40 mm Schwalbe tires and a Nitto "Allrounder" (as Tree Fort Bikes calls it" Northroads type bar. Racks and fenders are installed again, and II mostly use it in town. A longer stem, mounted lower, puts the hands in about the same position as before, but now I have brakes.See the picture below.
cheers -mathias
Not a good picture to see the bars... note that the bar tape is twined differently left and right. Right has the better way
Mid-march in Michigan -- one day of 60 F and we think it's summer.
cheers -mathias
Likes For steine13:
Quoted: 702 Post(s)
Liked 672 Times
hipster fashion
Quoted: 359 Post(s)
Liked 582 Times
Interesting
Given the chaos arising from gravel
.. I wonder how useful they are for that.
My Sports would benefit from them, sedate path riding, I think.
The flares Ive seen range from 0 to 6 to 12 to 24, would a mustache be a furthering?
Phyllo-buster
Quoted: 2298 Post(s)
Liked 2,055 Times
Less about being a hipster and more like a dalliance. We all want to like them but usually don't. How many daily riders do you actually see with them?
Old school North Roads tend to have less rise and can be inverted to achieve the maximum hipness legally available to old guys.
Bikes: A bunch of old bikes.
Quoted: 278 Post(s)
Liked 874 Times
It's usually more trouble to go from drops to moustache since brake levers might need to be changed.
I agree that drops are better for longer distances.
Likes For daverup:
Catching Smallmouth
Bikes: 1990 Specialized Sirrus Triple, 1985 Trek 460, 2005 Lemond Tourmalet, 1984 Schwinn LeTour 'Luxe, 1988 Trek 400T, 1985 Trek 450, 1997 Lemond Zurich, 1993 Diamond Back Apex, 1988 Schwinn Circuit, 1988 Schwinn Prologue, 1978 Trek TX700, Sannino
Quoted: 88 Post(s)
Liked 134 Times
I managed to bend a set of Nitto B115 45cm drops once. I launched my drop bar converted '89 Rockhopper Comp off of my Jeep at 60 mph. In an effort to get it going again I put on some Nitto mustache bars already on hand. I'd say I like drops better for most riding but for snow and ice, what I use the bike for, the mustache bars work well. The wider mustache bars offer more control in the snow and I don't do much panic braking on the ice. If I wrap my hands around the hoods with my arms stretched out I can cover smooth stretches as quickly as I can in the drops. So overall I'd say mostly a Hipster thing but I do really like them on my winter bike.
Quoted: 753 Post(s)
Liked 737 Times
I have the Soma Mnt bike control Moustache bars on a Bridgestone CB-1. Their set up with dummy hoods up front and Mnt grips, brakes and Suntour friction levers. I realy only get the 2 riding positions and it took a lot of fussing to get the primary hand grip position dialed in. When I was riding it a lot and in some sort of condition I could do a 25-30 mile ride with no hand problems. Before I found a sweet spot, my hands would get numb after 5 miles. I tried inverted Soma "Swallow" bars with Mnt bar-ends as a forward aero position. I liked the primary better, but the forward position was too narrow and "cluttered" with the control cable, bar-ends and basket access competing for territory. I tried inverted Somas "Oxford" Albatross clones and the bar ends were hitting my knees, with the 100mm riser stem I use.
Crawlin' up, flyin' down
Quoted: 1027 Post(s)
Liked 2,531 Times
Definitely not just just a hipster thing. They've been around far too long (at least 30 years, and they're based on an older design) to be "just" a hipster thing, just as fixed gear (around for well over 100 years) is not "just" a hipster thing. Moustache bars and fixed gear bikes may be current fads for "hipsters" (and I have no idea about that - I know as much about hipster culture as I do about speaking Urdu) but both are more than - and far longer-lived than - whatever the Flavor of the Month might be in some corner of the cycling universe.
I confess, I doubt I will ever ride either, FWIW (and it ain't much). Doesn't mean either is "just" a hipster thing.
Quoted: 3811 Post(s)
Liked 6,717 Times
Rumor has it that Jack Lauterwasser was the original bike hipster.
I had a set mounted on a Raleigh international and I just couldnt find a comfortable hand position. Just one data point here, but they made my wrists hurt.
Likes For orcas island:
feros ferio
Quoted: 1393 Post(s)
Liked 1,331 Times
My solution is Ritchey mountain bike bars, shortened by 1-2 cm on each end, with extensions. I have at least two comfortable hand positions, and I am delighted with them. Neutral axial forearm rotation, the big benefit of drops, is essential.
CycleAware mirror on my Giro XEN helmet.
Likes For John E:
ambulatory senior
Quoted: 1956 Post(s)
Liked 3,662 Times
I only liked them when they were upside down... Or with positive rise. I finally realized I just wanted porteur or North roads. Either make me happy but there are definitely uses for moustache bars.
Quoted: 5888 Post(s)
Liked 3,472 Times
moustache bars = no bueno
Quoted: 469 Post(s)
Liked 2,443 Times
I put some mustache vars on a Gitane a couple of years ago. I haven't done any rides longer than twenty five miles with this bike, but I haven't had any issues with them.
I have plenty of other bikes with drop bars, so these are a fun change every once in a while.
I'm fairly certain that northbend has a few thousand miles and a few centuries riding with mustache bars.
Likes For Roger M:
two wheels only
Ron Boi frame set up as single speed.
RRB frame with moustache bars
I like moustache bars and have two pair of the original Nitto model that Rivendell was selling back when. I bought the first pair because I liked the look but quickly learned that they were a big help on bikes that didn't quite fit me. Moustache bars generally need a shorter stem than a set of drop handlebars. I favor bike frames that have a relatively long top tube for my frame size and have found that moustache bars give me a comfortable riding position on frames that might have a shorter top tube than I would prefer. I currently have a set on a Ron Boi frame that Skip Montanaro will recognize.
I've tried North Roads bars. They are terrific if the bike is set up for them. That means sprung saddle, different (shorter) stem, appropriate gear controls and brake levers. You'll likely need new cables and housing all around, too. The experiment was not inexpensive.
I also tried inverted North Roads bars. They required an entirely different set up than normal North Roads bars. I never did get the controls and brakes done properly because,...
Inverted North Roads were too much like drop bars without the benefit of drop bars.
I took them off. Put my drop bars back on and called it a learning experience. I still have the bars, and levers.
This is spot on! If you don't have it, you will miss it,... a lot.
Quoted: 2339 Post(s)
Liked 2,831 Times
just drop your arms to you side and relax...look where your palms are naturally positioned, that is what you want IMHO
Flat bars are simply not ergonomic
I get that. I use the flat bars on my Sirrus, but often switch up to the extensions, or upright, no-hands position on downhills.
The Wheezing Geezer
Bikes: 1976 Fredo Speciale, Rivendell Clem Smith Jr., Libertas mixte
Quoted: 414 Post(s)
Liked 926 Times
Of the four bars I tried on my brother's Clem Smith Jr. this is my ranking:
Soma Clarence
Soma Sparrow
Soma Oxford
Soma Mustache
Soma Clarence handlebars
Soma Mustache handlebars
I guess I just prefer a compromise between flat bars and the fully turned-back styles. The mustache bars offered the most positional variety, but I didn't like the primary position so much. My brother's preference may be different.
Soma Clarence
Soma Sparrow
Soma Oxford
Soma Mustache
Abuse Magnet
Bikes: '91 Mtn Tek Vertical, '74 Raleigh Sports, '72 Raleigh Twenty, '84 Univega Gran Turismo, '09 Surly Karate Monkey, '92 Burley Rock-n-Roll, '86 Miyata 310, '76 Raleigh Shopper
Quoted: 151 Post(s)
Liked 175 Times
I tried moustache bars on my Raleigh Sports, and while they looked cool, I found that I really hated to ride with them. Replaced them with drop bars last summer.
