SRAM front derailleur pull any different?
Old 10-01-20, 08:41 AM
adlai
Quoted: 280 Post(s)
Liked 54 Times in 34 Posts
My bike frame has a braze on. I'm thinking of installing an ADVENT system in the rear with a double in the front. Only mountain braze on FD I can find is SRAM X7. Probably just do a bar end for the FD.
It would be 46/30 front to 11-42 rear.
adlai is offline
Old 10-01-20, 10:06 AM
c_m_shooter
c_m_shooter's Avatar
Bikes: Soma Pescadero, Surly Pugsley, Salsa Fargo, Schwinn Klunker, Gravity SS 27.5, Monocog 29er
Quoted: 186 Post(s)
Liked 234 Times in 166 Posts
It should be fine. Even if the pull ratio is a little different, you are only running a double and bar end shifters pull a lot of cable.
c_m_shooter is offline
Old 10-01-20, 10:29 AM
adlai
Quoted: 280 Post(s)
How about the chain issues? how many links would a 46/30 front to 11-42 rear require?
adlai is offline
Old 10-01-20, 11:57 AM
dsaul
Quoted: 714 Post(s)
Liked 800 Times in 475 Posts
The Advent 2x9 rear derailleur has a capacity of 47t, so you will have enough capacity for the 46/30 front the 11/42 rear. The 1x9 rear derailleur only has a capacity of 41t and is not designed for the extra capacity needed for a double front chainring. As far as the chain length, that depends on the length of the chainstays on your bike, but any standard 116 link chain should be long enough.
dsaul is offline
