Tube in tubeless tires
Hi,
My actual tires are worn and I am changing. I use tubes and my rims are not tubeless. I have a hardtail and the reason I am staying with tubes is because I rarely and rarely get a flat, so pointless for me to invest on tubeless.
However, most bike shops in my town do not have non-tubeless tires in the stock right now. They only have tubeless.
My question is, can I run tubes in tubeless tires?
Thanks
Thanks
Quoted: 4411 Post(s)
Liked 4,862 Times
Most of them you can yes. Post again with a specific tyre(tire) for confirmation.
Happy With My Bikes
Quoted: 884 Post(s)
Liked 2,307 Times
Not meaning to thread-jack, but I've not considered this. What criteria is there to determine what tubeless tires would not be suitable with a tube? I remember as a kid and tubeless car tires were becoming the norm that it was advised to not run tubes in them for some reason. What would the reasons be for bike tires as long as the tube doesn't create bead seating issues?
Thread Killer
Quoted: 3146 Post(s)
Liked 1,710 Times
There are tubeless tires you cannot run tubes in? I didn’t think there were, but maybe I’m not up on the current state of affairs.
Or are we talking about problems using hookless tubeless tires in hooked rims with tubes? And is that a problem?
Quoted: 1461 Post(s)
Liked 1,485 Times
I'm pretty sure you can run a tube inside any tubeless tire. This is not an optimal setup, as tubeless tires are heavier, more difficult to mount and often more expensive, but it'll work in a pinch.
I have no idea where the OP is or what kind of tire is being sought here, but scanning online stores shows lots of availability for popular road tires. If you can find them on Amazon with overnight shipping, your LBS can likely get them within a day or two.
Liked 1,485 Times
If you have hookless rims, you can only use tubeless tires, but you can still run an inner tube in them if you want. It just doesn't make sense to do so, as it adds weight, rolling resistance and nerfs any benefits of tubeless.
I'm not aware of any tubeless tires that don't work with hooked rims.
Advocatus Diaboli
Quoted: 4736 Post(s)
Liked 1,532 Times
or this as another example: https://www.enve.com/learn/tire-comp...caAj96EALw_wcB
Liked 1,485 Times
but not necessarily any TL tire. Eg. scroll down in this to near the bottom https://www.cadex-cycling.com/global...rim-technology
The OP says their rims are not tubeless, so they are not hookless. I'm pretty sure the OP can run any tubeless tire they want (with an inner tube) on their standard hooked rims.
A better/cheaper solution would be to ask an LBS to order them a set of regular tires, or buy a set online if the LBS can't do that for some reason.
Thread Killer
Liked 1,710 Times
That’s what I think, too…on both counts.
Quoted: 2975 Post(s)
Liked 1,182 Times
This is true.
This is not true.
There is more to tubeless than whether or not you get a flat. Tubeless is better ride quality, no pinch flats, and if you happen to get a puncture...sealant seals the hole so you can keep on riding or at minimum add a little air, instead of having to stop and change or patch the tube etc.
Liked 1,485 Times
This is not true.
There are no benefits to this setup vs. using a standard non-tubeless clincher.
Liked 1,182 Times
You said "tubeless tires are heavier" which is simply not a true statement. And they are not more difficult to mount than a tubed tire.
Advocatus Diaboli
Liked 1,532 Times
They are typically heavier. Compare a Conti GP5K tubed vs TL, which is what most folks always refer to. I think the Pirelli P Zero Race TLR vs the NonTL weighs about 50-60g more. In turn, the beefier bead/sidewall area, where the extra weight is evidently residing, makes for a less compliant mounting experience.
Quoted: 1819 Post(s)
Liked 1,694 Times
Any tubeless tire is heavier than a tubed version of the same tire. However, once you count in the weight of the tube, the tubed version plus tube can easily be heavier than the tubeless version without the tube. If you install an inner tube in a tubeless tire, it will be heavier than the same tire in a tubed version using an inner tube
Liked 1,485 Times
25mm Continental GP5000 = 215g
25mm Continental GP5000 tubeless = 300g
If you have examples of tubeless tires that are lighter than a non-tubeless version, please post them.
Likes For msu2001la:
Liked 1,485 Times
28mm P Zero Race TLR (tubeless ready) = 295g
Well good debate going on. I guess, I will stay with tubular tire. The CST Camper maybe. I see the Maxxis Ikon is rare on the market. I'm not from US. I use tire liner to protect from flats. Since 2018 I am using Mr Tuffy. Rode on thorns, broken glasses etc and got only 1 flat since. So, pointless to switch to tubeless. Not a necessity for me.
Liked 4,862 Times
Sunshine
Quoted: 10964 Post(s)
Liked 7,491 Times
Habitual User
Quoted: 4947 Post(s)
Liked 8,089 Times
Habitual User
Liked 8,089 Times
I remember mounting tubed clinchers without needing a tire lever. I have not experienced that with any TL tire, so far.
Habitual User
Liked 8,089 Times
No. You have a clincher tire.
Tubular tires - also known as "sew-ups - have the tube built into the casing of the tire, and the casing is literally sewn around the tube. Tubular tires are glued onto the rim, and require rims specifically built for tubular tires. This is the type of tire most commonly used at the top levels of road racing (although that is starting to change).
Clincher tires come in 2 types - tubeless and non-tubeless. As has been said before in this thread, you can use a tube in a tubeless tire.
Likes For Eric F:
Habitual User
Liked 8,089 Times
Yes. No problem at all.
