Interesting brazing & magnets!
Quoted: 455 Post(s)
Liked 112 Times
Yesterday I was working on the rear rack for my wife's bike. I was using a few rare earth magnets to hold some tubing while I talked the joint. One fell off as soon as I finished and afterwards I found that they had lost their magnetic force.
Thoughts?
Thoughts?
Quoted: 913 Post(s)
Liked 515 Times
Yes, I discovered that heat kills magnets exactly the same way. Gets those electrons spinning around like crazy
https://van.physics.illinois.edu/QA/listing.php?id=2744
Bikes: Bicycles? Yup.
Quoted: 481 Post(s)
Liked 1,585 Times
You found "critical temperature"! The heat energy allows the once aligned electrons to run free and un-aligned.
I use this to heat treat blades as a temperature measurement; heat to critical (usually orange-red) and a magnet no longer sticks to the blade steel, and you know it's time for an exciting dunk into coolant.
Likes For BTinNYC:
Randomhead
Liked 3,698 Times
It's really hard to hit that temperature a motor when you are trying to make one fail.
I have some Strong Hand grasshopper welding fingers that are nice, but sticking them to the same tube as you're working on is probably a bad idea.
Alnico
Alnico magnets are what you need. My magnets are six or seven years old and going strong. You have to limit the heat into the magnet, I have only used them with silver (45-56%) rod.
Old fart
Quoted: 3588 Post(s)
Liked 3,400 Times
Quoted: 481 Post(s)
Liked 1,585 Times
It's been known by smiths for centuries. Really highlights the difference between the public exchange in science and private proprietary technology (Old guilds held the heat treat IP closely).
