Sandblasting + Powdercoating - How to make sure stamped VIN on BB is still legible?
Bikes: Peugeot, Legnano, Fuji, Zunow, De Rosa, Miyata, Bianchi, Pinarello, Specialized, Bridgestone, Cinelli, Merckx
Quoted: 430 Post(s)
Liked 476 Times
Hi all-
I'm in the process of restoring an 80's 3Rensho road frame that has taken on some rust damage. The paint is already bubbling in some areas, pitting in others. I'm planning on having it sand/beadblasted, cleaned of rust, and then powdercoated.
My question is: How can I maintain the VIN number stamped into the bottom bracket?
The rust is pretty bad down there, but I'm a little concerned that the above process(es) will more or less remove the VIN stamp. A thicker powdercoat layer seems like it would fill in the VIN stamp.
Can I mask off that portion of the BB and then paint it by hand after the other work is done? I don't mind a slight color difference, but it would be nice to hold onto that VIN. Or is there another method I should attempt?
Thanks a mucho
Thanks a mucho
Quoted: 4206 Post(s)
Liked 3,870 Times
Well first remember that the serial number isn't a VIN. There's no bureaucratic recording with the government or insurance companies of this number. One can stamp whatever word or number they wish and state on any bike registration form, invoice or police report that this is the ID for the bike.
Second why don't you ask your painter their method of saving surface detail? If they have no answer or don't seem to offer any indication of concern then maybe that's an indication of their skill or motivation. perhaps moving onto another painter is indicated...
Third there are masking methods available. But since I don't have my frames powder coated (I like detail to be preserved) I can't say much more. Andy.
Quoted: 430 Post(s)
Liked 476 Times
Thanks for the reply, Andy.
Ah yes, my mistake. FWIW serial numbers on bicycles are taken much more seriously here in Hawaii than other places I've lived...they actually require all bicycles ridden on the street here to be registered with the serial number and a DMV-issued bicycle ID number. The system is far from perfect, but it's one way they try to crack down on bicycle theft, which is rampant here. I meant serial number, but said "VIN".
Good point, something I'll inquire about with the painter.
The preservation of detail is somewhat important, as the frame has decent lugs and the "3RENSHO" embossed on the rear triangle. I'll definitely consider this.
Again, appreciate the reply. Mahalos
Randomhead
Liked 3,698 Times
sandblasting is unlikely to be a problem. A good powdercoat really isn't so thick as to obscure a properly embossed serial number, but some of them were pretty weak to start with. Telling the powdercoat guy to go a little thin on the area of the number will probably be enough. I suppose there are ways to improve the number, but they would be a lot of work.
Decrepit Member
I had my frameset repainted (primer, 2 coats of wet paint, then clearcoat) and the paint filled the serial number so that it was illegible after painting. I used Jasco paint remover just on the serial number stamped into the bottom bracket shell, then hand painted the area using a small hobby brush and Testors enamel model paint which closely matched the paint color. It's a little sloppy, but the number is legible now and protected by paint.
Quoted: 430 Post(s)
Liked 476 Times
Would paint remover have any impact on powdercoat, though? I suppose I could wear down the powdercoat using a physically abrasive means, but am not sure about a chemical agent that would have the same effect.
Liked 3,870 Times
If paint is to be removed to expose the serial number I would suggest a mechanical method. I'd probably use a sharp knife or an Xacto to scrape under/through the paint. For such a localized removal getting into the possible issues of chemicals isn't worth it to me. Maybe experiment on the OEM paint before the bike is prepped for refinishing just so you have a better idea of what this project entails. Andy.
Decrepit Member
In my experience, chemical paint stripper may be used without any damage to the surrounding paint, powder coat, or base metal if you're careful to keep it localized to the small area of the serial number and then thoroughly clean the area with soap and flush with lots of water after removing the paint. I did have to use an Exacto knife to get the paint out of the stamping crevices.
Eric is probably right by suggesting you ask the powdercoater to simply make the coating thinner on the bottom of the BB bracket. It would be much simpler and cleaner than having to do what I did after the fact.
rather than you, DIY before hand,
Ask them mask it off before blasting clean, then leave it bare when powder coated , apply touch up paint when finished .
same powder mixed in clear lacquer should do. & match.
Likes For fietsbob:
Bikes: Indeed!
Quoted: 1507 Post(s)
Liked 3,478 Times
Further help with frame identity maybe forthcoming if you post a couple photos to the Classic & Vintage forum.
Brent
Randomhead
Liked 3,698 Times
welcome to the forum, upload your pictures to an album in your gallery and we can rescue them for you
Randomhead
Liked 3,698 Times
Picture rescue
