Specialized Vado 4.0 full battery- dead on display problem
Hi
After charging the battery of my Specialized Vado 4.0 to "Full", and putting it back in the bike, it seems dead...
When turning on the bike, following happens:
Can't find any similar issue online and there's no Specialized dealer I trust enough nearby
any help would be great!
Thanks in advance
- The indicator on the battery itself shows it to be full.
- The display on the bike show the battery to be empty
- the battery icon on the bike display blinks frantically
- no power for the motor
- no lights (they should work even if no power to the motor)
Thanks in advance
Quoted: 883 Post(s)
Liked 823 Times
Somewhat similar problem with my Haibike turned out to be a "broken" display on/off switch.Pretty expensive repair since the wires were in the frame and they needed to drop the motor. The switch connected to the motor which seems stupid to me (seems easy to have a connection on or near the handlebar to isolate this). Also, raked for $120 for the component. BTW, this occurred precipitously; one day it was fine, the next, dead.
Clark W. Griswold
Quoted: 4357 Post(s)
Liked 3,994 Times
I would make sure your sensor magnet is clean, make sure the battery on your display is new (if you have a TCD not the old Bloks display) and I would also make sure all connections are clean and maybe use dialectic grease on the connection points.
Would the sensor magnet have an impact when starting up the battery?
Quoted: 883 Post(s)
Liked 823 Times
Good ideas; I did that (except dielectric grease which wouldn't have made a difference). Changed the battery in the display too, but AFAICT it only keeps the clock operating. The real problem for me was there was no way I could diagnose since everything was basically sealed. The shop had a history of problems with this component, so it was easy to locate. I was fortunate that Giant and Haibike used similar Yamaha systems or might have been hosed.
Clark W. Griswold
Liked 3,994 Times
Maybe not but always worth checking.
Thanks, Just an FYI Specialized uses Brose not Yamaha but yeah we love Dielectric Grease in the shop it did help in some cases but may not in others.
Regardless I would find a Specialized retailer if you are still having issues. Unfortunately batteries are out of stock for a while but at the very least they should be able to get a warranty request started and either get to the bottom of the problem or just get the needed replacement parts if that is the case. Specialized supports their customers really well and while your local dealer may not be perfect (but who is) they should be able to help in this instance.
