Kenda tires good?
Rhapsodic Laviathan
I bought a used Roubaix not long ago. When I posted pics someone said it looked like the previous owner had tried to turn it into a gravel bike. I am guessing it’s the blow 700x28c Kenda Kwest tires, blue tires.
Are these tires more for gravel than road? Are they good, bad or just OK?
I looked them up and read several poor reviews, but I don’t believe every review I see good or bad. Since I will be riding exclusively on paved roads or trails would a 25mm road tire give a better ride?
Once the 100* weather lets up I am planning on riding further than loops around my neighborhood and don’t want cheap tires causing problems.
These two came off my ratrod, and oddly enough; I never got a flat with these.
One is 1.75 I think and the other is 2.50
Rhapsodic Laviathan
Did not matter. They suck at any pressure. Run them low and they are slow as molasses, run them high they are less slow but ride like crap.
These are just cheap, crappy tires with stiff sidewalls.
EDIT: I just realized the OP has 700 x 28 Kwests. Mine were 26 x 2.1. Maybe they use an entirely different type of casing and tread compound for the road tires. But I kinda doubt it.
Advanced Slacker
Quoted: 2764 Post(s)
Liked 2,539 Times
I never had a problem with the Kwest, and back in the day I thought max psi was best and fastest, and ran them at 65psi. I don't think they use a different case/compound for the 700c tires, since they're for hybrids. Every 700c Kwest I ever saw was on a hybrid and no narrower than like 35mm, or never near as narrow as the 559 versions. The ones in my picture are new, bought like 4 years ago, and have a thin sidewall, the older ones did have a stiffer, thicker sidewall.
These were on my commuter bike.
I did not mind them terribly until I tried something better.
Since then, I’ve had a couple sets of Bontrager H2 (I think that is the model) and some Performance (as in the store) brand tires that were a much nicer ride.
Bikes: 2020 Masi Giramondo 700c; 2013 Lynskey Peloton; 1992 Giant Rincon; 1989 Dawes needs parts; 1985 Trek 660; 1985 Fuji Club; 1984 Schwinn Voyager; 1984 Miyata 612; 1977 Raleigh Competition GS
Quoted: 1127 Post(s)
Liked 255 Times
Over the last 20 years I've had 3 sets of Kenda tires, the first ones were Kwest, they didn't last long, and I got a lot of flats; my next pair came on a new bike I got in 2020 called Drumlins. At first, the Drumlins seemed ok, but then I started getting a lot of flats, not only that but they only lasted about 1,000 miles; but wait, there's more...they weighed 950 grams a piece! Not sure why they weighed that much, there wasn't much if any flat protection built in, the tread wore out very fast. Those were larger tires, but I then I had a pair of Kenda Kountach back in early 2000's, these were very lightweight, and paper-thin thread which I thought was going to be problematic, but they lasted about 4,000 miles, and I only had one flat.
So larger tires seem to suck from Kenda, but their road tires, if the ones I had were any example, are pretty good; not sure if the new version of those are any good.
Anyway, just telling you about my experiences.
Likes For rekmeyata:
old newbie
Bikes: Specialized Roubaix
Quoted: 562 Post(s)
Liked 373 Times
I ran across a reference to Specialized Roubaix Pro tires. It caught my attention since that is what my bicycle is.
Are these good or is it just a marketing gimmick?
Bikes: 2007 Motobecane Fantom Cross Expert, 2020 Motobecane Omni Strada Pro Disc (700c gravel bike), 2021 Motobecane Elite Adventure with Bafang 500W rear hub drive
Quoted: 174 Post(s)
Liked 143 Times
Kendra Kwick were original equipment on my 2007 cross bike, 700x30c. I liked them and stuck with them because they were decent and cheap at about $12 if you looked for bargains and bought several when you spotted a good price.
Speed demons on the forum pointed out that they didn't have very good rolling resistance numbers, but that's moot to recreational/fitness riders like me. I notice they've doubled in price since I last bought some. I wouldn't buy them again unless they are the best value I could find. They're neither bad nor exceptionally good, but are decent tires that I feel safe with cornering at high speeds, and not particularly prone to flats. Good for pavement and gravel, as the center portion is fairly smooth but the outer edges have taller tread pattern to grip on rougher surfaces.
Just Pedaling
Bikes: YEP!
Quoted: 341 Post(s)
Liked 547 Times
I was not able to wear a set out . They got deformed and I had to throw them away. I now run Panaracer and have for quite a while. They don’t deform . The Panaracer is only a few dollars more. The Kenda tires I ran felt ok for about 6 months of light riding but then developed a weird deformity in both tires at the same time. I only ran about 90% of max tire pressure on the rear and about 80% on the front.
Advanced Slacker
Liked 2,539 Times
Any generalizations about Kenda (or most other major tire brands) based on a few models is going to be suspect..
Kenda makes some very good tires (particularly MTB) and also some garbage.
Likes For Kapusta:
Quoted: 643 Post(s)
Liked 1,342 Times
I've had nothing but good experiences with Kenda Kwests on an old rigid MTB and a couple hybrids. I absolutley love the way this one rides on chip and oil or crushed limestone with them.
I've had 3 different K35's however do this......
Likes For Murray Missile:
old newbie
Quoted: 562 Post(s)
Liked 373 Times
Are they just more comfortable? Wouldn’t the 25s be faster? Faster enough to make a real world difference?
Guest
Quoted: 1346 Post(s)
Liked 3,270 Times
Quoted: 4227 Post(s)
Liked 2,489 Times
28mm tires are more comfortable than 25mm tires and provide better handling and give you a much better ride quality especially over rougher pavement....Personally I prefer bigger tires and I don't ride anything smaller than a 32mm tire.
Likes For wolfchild:
OM boy
Bikes: a bunch
Quoted: 539 Post(s)
Liked 671 Times
but, i sortta remember your bike... from your Post/Thread - a 2008-9 ish Roubaix with Blue Tires ??? funny what stick in one's cabesa...
those bikes had fairly narrow chainstays... and for my Roubaix and Tarmacs, 28 width is a 'no go' - barely fit with prolly 1-2 mm clearance... But that's with HED wheels which have a 21 internal rim width...
Depending on your rims - 28 might just fit - but I'd make sure or expect they might not, after you get them...
... just sayin...
Ride On
Yuri
BTW, that was a good buy... how the bike workin?
EDIT: just saw that the prior Kendas were 28s, so those wheels should handle most 28s...
old newbie
Quoted: 562 Post(s)
Liked 373 Times
depends...
... just sayin...
Ride On
Yuri
... just sayin...
Ride On
Yuri
From what little research I can do-Specialized is no help with serial numbers, my bike is a 2012 model. That is from comparing pics and features I could find online.
The smurf tires are growing on me.
Liked 255 Times
I don't think any tire is worth $60 plus, in fact I refuse to pay over $40 a tire. Why do I think that way? You can get a car tire for $120, are they telling us that two skinny road bike tires have more technology than a car tire? LMAO!! Bicycle tires, like a lot of things cycling related, is a rip off. They can sell us a brand new $15,000 CF wonder bike and some how that bike has more technology than a brand new $15,000 BMW F850 GS motorcycle? LMAO again and again.
I think one of the best overlooked brand of tire on the market is Panaracer Race D Evo, these cost around $31 and last a long time with good flat protection. There is a slew of good tires between $31 and $35, like the Vittoria Rubino Pro IV G2.0, and the Speed; Pirelli P Zero; Schwalbe One Performance Road tire; and the Goodyear Eagle F1. Also find end of the season sales on tires, you can usually find $60 or dollar tires for 40 to 60 percent off, those sales usually come in October, October will have the best selection, some go on sale after that till April but the pickings could be slim.
old newbie
Quoted: 562 Post(s)
Liked 373 Times
I currently have those Spec tires on two of my road bikes, and I like them...BUT...I don't think they're worth the retail price, but I think that about a lot of tires on the market! I got mine on a sale, one tire for the regular price, and the other for half off, so at that price I bought them (back when they were $40 each, they're now $50). They handle good, but I don't have any twisting mountain roads to test them nor race on them to press their limits, they are lasting around 3,500 miles of non aggressive riding.
