Double kick stand replacement tips
Hi all, I’ve got a pretty heavy duty kickstand. The rubber feet are shot, which makes the tandem a little wobbly. The shop I bought it at keeps sending me Greenfield kickstand tips, which are way too small (maybe 7/16 of an inch).
I’m measuring the diameter at the foot to be 5/8” (about 16 mm). Anyone know where I can get a replacement foot in that size? I bought a pair of cane tips; they fit, but don’t hit the ground on the correct angle.
thanks!
thanks!
Quoted: 2509 Post(s)
Liked 746 Times
What is the make and model of the kickstand? If it is unbranded you may have to take it to a bike co-op where a tech can just try stuff out on it. There is the option of using those tool handle dips but I have no idea how durable they are. Probably not very. Once you started down that route you might be renewing the material quite frequently.
