Dropped chain vs Mavic wheel
#51
Quoted: 4406 Post(s)
Liked 1,560 Times
Slightly out of tune limit screw or bent RD combined with a bump and/or shifting lots of gears at once carelessly can lead to this. I've had this happen once, fortunately at low speed and at the door of my house. Since it was low speed, nothing broke, but I had to remove the cassette to free the chain, wedged between the cassette and the hub. In my case it was my fault since I didn't adjust the RD well enough.
Dork discs, that we all hate and nobody uses (including myself), were designed to avoid exactly this.
I had always wondered what would happen if this happened at speed. Now I know.
That's a new one on me.
#52
"Slightly out of tune limit screw or bent RD combined with a bump and/or shifting lots of gears at once carelessly can lead to this."
I think it was clear form my phrase that for this to occur there has to be a misadjusted RD.
#53
Quoted: 3511 Post(s)
Liked 2,926 Times
#54
Senior member
Quoted: 943 Post(s)
Liked 658 Times
Can't believe no one has mentioned this, but a perfectly tuned driveline with a perfectly aligned derailleur can be totally thwarted by an improperly installed rear wheel.
Likes For Dan Burkhart:
#55
Liked 2,926 Times
Aren’t vertical dropouts nearly idiot proof?
#58
Liked 1,560 Times
So no, it was not clear to me.
#59
Liked 1,560 Times
How? Even horizontal dropouts won't offset the cogs enough to matter before the tire is buried in one of the chainstays.
#60
Senior member
Quoted: 943 Post(s)
Liked 658 Times
An improperly seated axle in vertical dropouts can make the difference between a derailleur that clears the spokes and one that does not.
#61
Liked 2,926 Times
If we take Larry at his word, and look at the pictures he posted, it’s clear the chain dropped between the cogs and spokes, and the rear derailleur never got caught in the spokes.
#62
Liked 1,560 Times
#64
Quoted: 241 Post(s)
Liked 454 Times
User error then blaming others for his misdeeds...boring, moving on...
Likes For Kai Winters:
#65
Sock Puppet
Bikes: 2014 Cannondale Synapse Carbon, 2017 Jamis Renegade Exploit and too many others to mention.
Quoted: 1031 Post(s)
Liked 863 Times
Everyone seems oddly certain that the derailleur broke the spokes. My experience is that the opposite is normal, and the derailleur and hanger would be trashed with the spokes intact. This seems like something else - like the chain cutting the spokes.
Which could be from a bent hanger or not.
It seems many here like to dump on LarrySellerz because of his posting history. In this particular case, we really don't who is to blame. If the hanger was bent, was it the shop that failed to check this or did the hanger get bent afterwards? Hangers can be bent quite easily, not just in a crash. If the bike falls on the DS, if someone taps the RD, the hanger can be bent. I had some a-hole on a club ride bump my RD with his front wheel which bent the hanger. I have also seen hangers get bent if there is a stiff chain link and the cage is pushed to its limit.
#66
Senior member
Quoted: 943 Post(s)
Liked 658 Times
You have been in the bike biz a long time, right? I'm sure you have had times when someone brings you a bike complaining about the shifting and all you had to do was open the QR with the bike resting on the floor and the dropouts clunk into place on the axle, and viola, all fixed.
#67
Expired Member
Quoted: 3674 Post(s)
Liked 5,431 Times
To be fair, he has manned up to having the wheel repaired. Still, there is some distance to go between dropping off the wheel and actually paying to retrieve it. I'm staying tuned, predict more drama to come.
#68
Liked 1,560 Times
#69
Quoted: 2482 Post(s)
Liked 2,955 Times
I hesitate to tell this story, but:
The first time I set up one of my bikes on my brand new smart trainer, I was a bit hasty and didn't get the 130/135-mm axle spacer in the right place and, consequently, didn't have the left end of the axle seated fully in the dropout. Climbed on the bike---crack. The right (carbon) seat stay now has a line running across it at the point where it narrows to meet the dropout. (The bike is OK for use on the trainer but is now useless on the road---with even minimal pedaling force, the rear tire rubs the chain stays and the chain jumps wildly from sprocket to sprocket.)
Not a rear wheel, but:
I was admiring a cute girl riding along at the start of a local bike club ride when I noticed that her boyfriend had tightened the front wheel skewer with one end of the axle in the dropout and one out. Stopped her, fixed it. "I thought the brake was maybe rubbing a little," she said. (Score one for the male gaze.)
[Edit: I agree that a rear wheel with one end of the axle in and the other out of the dropouts is unlikely to be able to be pedaled very far. With a non-indexed gearing setup, it might be possible, though.]
#70
Quoted: 2700 Post(s)
Liked 486 Times
On another bike that I crashed hard on, the rear rim brake was bend out of adjustment and I had to have the wheel not fully in one of the dropouts to stop the rubbing, but the gears were skipping/chain dropping in all gears (already happening but having the wheel askew in the dropout made it worse)
#71
Liked 1,560 Times
#72
Sock Puppet
Liked 863 Times
#73
Expired Member
Liked 5,431 Times
Likes For shelbyfv:
