1/2" clipless pedals???
Does anyone know if you can get 1/2" clipless pedals? It would be for a stationary bike. Thanks!
Gear Hub fan
Bikes: Civia Hyland Rohloff, Swobo Dixon, Colnago, Univega
You should be able to have the holes retapped in the crank arms to the larger size. A good bike shop should have the taps available.
Gear Hubs Owned: Rohloff disc brake, SRAM iM9 disc brake, SRAM P5 freewheel, Sachs Torpedo 3 speed freewheel, NuVinci CVT, Shimano Alfine SG S-501, Sturmey Archer S5-2 Alloy. Other: 83 Colnago Super Record, Univega Via De Oro
Visit and join the Yahoo Geared Hub Bikes group for support and links.
https://groups.yahoo.com/group/Geared_hub_bikes/
Insane Bicycle Mechanic
Quoted: 808 Post(s)
Liked 711 Times
Here's the adapter Roger was talking about: https://www.kneesaver.net/ . Note that they will spread your feet apart by about an inch on each side. This works for some people, not others.
I seem to recall a 1/2" thread Wellgo pedal that accepted their add-on clipless mechanism: https://www.biketoolsetc.com/index.cg...item_id=WO-QBS
I can't find it now- maybe Bike Tools Etc. knows.
Jeff Wills
Jeff Wills
Arsehole
Wellgo used to sell "bolt-on" SPD mechanisms that fit their BMX platform pedals. They would fit on a 9/16" or a 1/2" pedal. I've done a quick search for them, but I don't see them on eBay or in any of the online stores. We had 4 sets of them at my former shop, but I think I sold the last one before I left.
Oh.... while I was searching, I see Jeff Wills already posted as much. lol.
Gear Hub fan
Nope- running a 9/16" tap through most one-piece cranks will leave little or no material left on the crank.
Great State of Varmint
Liked 15 Times
Here's Harris Cyclery -
https://sheldonbrown.com/harris/pedals.html#adaptors
Clips and straps would be a lot more economical.
I know this is an ancient thread, but I check in on it every few years to see if anyone has found a solution...Also worth noting: when you Google 1/2" SPD pedals, this thread is one of the top hits.
Anyway, I saw a Venzo kit on Amazon recently and I'm wondering if it might be a possible alternative. I've never seen a product like this offered before, though someone mentioned a similar product on this thread a decade or two ago. They would likely require some custom fabrication to get the correct mounting holes onto your 1/2" pedal.
Search for the Venzo kit on Amazon by using this ASIN: B08CGQ7G3P . (I am locked out from posting URLs until I make 9 more posts. Sigh.)
A better solution might be to buy a 9/16 pedal and swap the axle, but the trick would be finding a clipless pedal and a similar 1/2" pedal that use the same (except for the threads!!!) axle.
Quoted: 4208 Post(s)
Liked 3,875 Times
KKT (and maybe MKS) did offer road like pedals in 1/2". Sometimes labeled as BMX. like these in this link. Andy
BMXmuseum.com For Sale / 1/2" KKT Lightning Pedals
AndrewRStewart
AndrewRStewart
Quoted: 2483 Post(s)
Liked 2,955 Times
Ride, Wrench, Swap, Race
Quoted: 1565 Post(s)
Liked 1,296 Times
It's always interesting to find this topic re-emerge! These pedals are like unicorns, but they do turn up if rarely these days.
There were 1/2" clipless pedals made by Wellgo and sold for a couple of "transitional" years, back around year 2000 or so.
Variously sold under the Wellgo and Bulletproof brands, available in silver, red and black (I have all three now on my hard-ridden Schwinns). I believe that Redline may have offered a different-styled version as well.
Quoted: 4408 Post(s)
Liked 1,562 Times
Surprised no one suggested just bolting velcro shoes directly to the pedals.
Liked 1,296 Times
Likes For dddd:
Live not by lies.
Bikes: BigBox bikes.
Quoted: 860 Post(s)
Liked 784 Times
Thank you, I like the simplicity and lack of special tools needed for Ashtabula cranks.
Liked 1,562 Times
Bikes: Trek 4300, '84 Trek 400,'88 Trek, 85 Trek 720 560, 82 Motobecane Randonee, 75 Schwinn Collegiate, Schwinn Sierra, '84 Trek 890, 2001 Trek 5200 OCLV USPS, 99 Trek Y Foil
Liked 14 Times
Go to Wally Mart, Buy a set of their cheap pedals, They come with the adapters so the 9/16 pedal will screw into a 1/2 crank. Throw the plastic pedal away, use the adapter with whatever clipless pedal you like.
