Help identifying Binachi
I recently got this Bianchi, 55cm seat tube, S/N B9 03733 ( or could be 89 03733 ), Giepemme dropouts, Columbus chromor sticker, the down tube is like SBX ( getting oval towards the bottom bracket ), 27.2mm seat post. I was wondering how old is this bike exactly and is the Cromor sticker applied later since the downtube is an SBX? Any other thoughts and observations? Thanks.
r
r
USAF Veteran
Don't know the date from serial number (someone will be along soon!). In the meantime, you can check the date codes of the Shimano components. Look on the inside of the crank arms, on the hubs, etc. Then check here:
https://www.vintageshimano.com/blog/...ano-date-codes
Quoted: 4722 Post(s)
Liked 3,039 Times
This one is a real puzzle. The decals point to 1988-1989, while the serial number is from early 1989. However, that's too earlier for a Superset 2 style downtube which was oval at the BB end, with the major axis oriented laterally. The components are Shimano New 600EX, which are 1984-1987. Since it's friction shidting, their likely from the earlier half of that time frame. It appears to have been completely rebuilt with non-OEM componets, as even the headset wouldn't be orignal. There's no front derailleur hanger, so we shouldn't be looking at Columbus SPX/SLX or even SP/SL. The Cromor decal is probably correct. During this era, Canada received Brava manufactured in Italy with Cromor but I don't recall then coming with a Unicrown fork and they didn't have the Supereset 2 down tube..
Likes For T-Mar:
Bianchi Goddess
Quoted: 2936 Post(s)
Liked 2,933 Times
That BB shell and bridge are different from the ones on my SBX but…it has semi vertical dropouts and I believe the earliest ones had a horizontal, at least looking at the US market indicates this.
the overall appears of the frame looks a lot like the ‘89 Sport SX but again they wouldn’t have that DT or dropouts
BTW is Bianchi engraved on the top of shell
Sugar "Kane" Kowalczyk
Likes For Bianchigirll:
feros ferio
Quoted: 1393 Post(s)
Liked 1,329 Times
There seem to be lots of nonconforming, "head-scratcher" Bianchis out there. Mine checks all the boxes for a 1982 (frame made in late 1981) Campione d'Italia, except for the "charcoal" color, which is not listed in the catalog for that year.
Original equipment matched 1982 Campione d'Italia specs. Frame date is late 1981. "Charcoal" color not found in catalog listing.
(Shimano aero brake levers are not original, but their shorter reach and improved leverage are critical safety features that, along with the KoolSTop brake pads, compensate for the inferior stopping power provided by the brake calipers. Other component swaps include the Serfas ARC saddle and the 14-26 SunTour freewheel, to accommodate local hills better than the OEM 13-23 Regina America.
Liked 3,039 Times
Thanks so much T_Mar. I forgot to mention that the front derailleur is Shimano RX100 ( everything else is Shimano 600 even the rims have 600 hubs and are tubular to my surprise after got home ). This RX100 may be the original component to this model as you alluded to. Thanks again.
I don't believe that RX100 is original. RX100 wasn't introduced untilt eh 1990 model year and it's price level was low enough that it typically came on Asian manufactured Binchi, at least in Canada and the USA. Your Bianchi is definitely Italian manufacture based on the Gipiemme dropouts.
