Chain skipping
Bikes: Trek FX 7.3, Specialized Roubaix, Orbea Terra, Aostimotor S17 ebike, Huffy RedRock (first bike)
Quoted: 195 Post(s)
Liked 266 Times
Chain skipping
Trying to figure out why chain skips under load on 24 speed road bike. Bought a new ig51 chain 116 links, for 8 speeds, made it even worse. Thinking it's the cassette. Can anyone visually tell?
https://youtu.be/m7dNhDgwBK0
https://youtu.be/Sd0QETB8MqQ
Quoted: 6193 Post(s)
Liked 4,809 Times
Depending on how badly the old chain was worn and how many miles is on the cassette you might have a worn cassette or at least the cogs on the cassette you use the most might be worn.
Are you certain it's on the rear that it's skipping? Mine was a worn out front chain ring when I had a similar issue after getting a new chain.
I'm not certain what you think we are supposed to see in the videos. Chain skip is something you'll experience when you are on the bike and start to put some power into the crank and then it feels as if it suddenly lets go and slips for a most of a pedal stroke.
Just spinning the crank with the wheel unloaded might be showing us any number of issues, most being adjustment or bent hanger.
If your skipping is more like a bad shift, then did you put the correct speed chain on the bike?
Quoted: 195 Post(s)
Liked 266 Times
I'm not sure what information experts would require so i though shooting some videos would help. Chain skipping whenever I'm spinning by hand or on the bike. When I'm on the bike, it doesn't grip at low cogs at all. It looks like original is SRAM PG-830 8 speed 11-32, can I replace it with 11-28?
Quoted: 94 Post(s)
Liked 151 Times
The cassette looks suspect to me. As long as it is shifting correctly and only skipping under load I would swap it for a new one. The jockey wheels on the derailleur look worn. A video from the rear showing going through gear shifting would be helpful.
Likes For ARider2:
Likes For Tawraste666:
Quoted: 195 Post(s)
Liked 266 Times
Cassette does look pretty bad to me, all the cogs uneven. Derailleur looks straight to my untrained eye. Still question remains, can I replace it with 11-28, which is $14 vs $30-40 for 11-32?
Likes For ARider2:
I suggest that the cogs would need to be far more worn than that for it to skip when turning by hand.
5 seconds with a hanger alignment tool might, just might save you some cash.
Quoted: 195 Post(s)
Liked 266 Times
Comparing to someone's same cassette for sale, my teeth are a lot thinner and sharper. 11-32 is $5 more expensive, so I might just splurge for that.
Quoted: 195 Post(s)
Liked 266 Times
I purchased a new 11-28 cassette, black. Spent too much time and money on this bike already.
Bikes: 2016 Fuji Tread, 1983 Trek 520
Quoted: 676 Post(s)
Liked 741 Times
Your sixth gear looks like it's worn to points. Check your chain rings too. Even if they don't skip, they may be rough and noisy.
Quoted: 195 Post(s)
Liked 266 Times
Likes For XxHaimBondxX:
Go Ride!
Bikes: Klein Quantum Pro, Klein Attitude, Azuki SS, Merckx AXM, Klein Quantum Race, Klein Quantum
Quoted: 109 Post(s)
Liked 155 Times
You have a third chainring up front—you won’t miss the 32.
Likes For Sonofamechanic:
Quoted: 114 Post(s)
Liked 119 Times
If you have your old chain, you can measure the rivet spacing on 12 links. Ideally, it should measure 12" (brand new). As wear occurs, this spacing will increase. If the same length measures 12-1/16" the chain probably did not damage the cassette. If the spacing measures 12-1/8", then chances are the cassette was damaged by chain. I tend to measure my chain as a habit, just to avoid damaging the cassette.
Basically, a worn chain physically damages the cassette by forcing the cassette to match the chain dimensions. Then when you install the new chain, it doesn't match the worn cassette and hence chain skip.
Go Ride!
Quoted: 109 Post(s)
Liked 155 Times
I know the chain use also ‘wears’ on the cassette teeth, but I’ve always wondered if the main reason for a cassette ‘wearing out’ (stretching out really) was using a stretched chain—sounds like that’s what you are saying and it makes sense. Similar to your chain test explanation, is there a relatively straightforward way to test/measure cogs in a cassette to see which might be worn (other than a visual)? Using a chain wrap?
Mostly harmless ™
Bikes: Heavy, with friction shifters
Quoted: 1107 Post(s)
Liked 216 Times
All the other methods are not very accurate.
Visual inspection especially.
Visual inspection works OK for the fornt chainrings, but not for the (smaller) rear ones.
Likes For Bike Gremlin:
Quoted: 114 Post(s)
Liked 119 Times
Unfortunately, as others stated, there are no reliable ways to gauge cassette wear with typical shop instruments and inspection tools. There have been times I put on a new chain, thinking the cassette was fine, but only to have it skip with a new chain. Then I'd reinstall the old chain, ride around until I can get a new cassette..
Quoted: 581 Post(s)
Liked 921 Times
Mostly good advice above, as this problem is common - if replacing a worn chain results in skipping under load, the problem is the cassette was also worn to match the worn chain.
Go Ride!
Quoted: 109 Post(s)
Liked 155 Times
2 follow ups on this: (1)…wouldn’t the front chainrings be equivalently worn/stretched and also need replacement, or does the shorter radius of the rear cogs somehow cause greater wear or create lower tolerances before skipping? (2) on measuring/checking rear cogs for stretch…couldn’t you cut a short section of tubing/pipe that fits tightly into the ‘trough’ between the ‘teeth’ of a brand new rear cog and then use hat as a measure? When you can wobble it back and forth more than a mm then that cog is worn?
Quoted: 195 Post(s)
Liked 266 Times
Seems to me on cheaper bikes it worth just replacing both and skip the guesswork, although on this bike someone already replaced the chain, but being it from fb marketplace, I chose not believe that.
Quoted: 676 Post(s)
Liked 741 Times
2) KMC makes a sprocket check tool, but the lead mechanic in a shop where I got some training didn't trust it. Others may have a different take on it.
Likes For andrewclaus:
Quoted: 114 Post(s)
Liked 119 Times
1. Like you, I would expect the front chainrings to wear because they're usually made of aluminum (softer material than the steel chain and steel rear cogs). As mentioned previously, the larger diameter should favor the chainring but even factoring larger diameter my chainrings seem to last longer than I'd expect . And they do wear, as the teeth on my chainrings do no have a symmetric shape, but yet they chainrings don't skip. I have over 30,000 miles on Ultegra chainrings.
Sheldon Brown discusses chain wear and how a chain should properly engage into the cogs and chainrings. He also discusses the worn cog / new chain problem: https://www.sheldonbrown.com/chain-wear.html
2. I assume you could make some sort of gauge that measures the width of the trough (or wear of the teeth), but slipping might also have to do with tooth profile shape, too. I'm also guessing different cassette brands have different teeth profiles, although imperceptible to the eye. I really don't know, but it's fun to think about
Likes For MudPie:
