Simple upgrades to a gravel bike for long paved road rides?
Randomhead
Liked 3,697 Times
I have an extra set of wheels with some 40mm Maxxis Velocitas mounted. I'm not sure how much they speed me up, but they are quieter than the Gravelking SK I usually run. And they run fine on smooth unpaved surfaces, like you find on rail trails. I think those wheels are going on a dedicated bike though. It's a pain to switch back and forth, so I don't do it as often as I should.
Bikes: 2021 Trek Verve 2 Disk
Quoted: 130 Post(s)
Liked 119 Times
I have Domane SL6 with two sets of wheels. The Paradigm 25s it came with now have Bontrager GR1s 35mm (measure 37mm) set up tubeless. The second set are Aeolus Pro 51s with GP5000 25mm F and 28mm rear. Same course same by road segments. Comparing down hill and on flats about 3 mph difference. Up hills about 2. Not huge but makes a difference on a long ride. The GR1s are smooth on rough surfaces. The Colonial parkway in Va from Jamestown to Yorktown is concrete but exposed River stones. The GR1s are slower but less taxing.
I’d go 28mm or 30mm for the road. Second set of wheels if you can swing it. I have no issues with brake disc alignment. Oh for road getting some latex tubes for F & R to try when the new rear tires arrives.
Bikes: 2022 Fuel EX 8, 2021 Domane SL6, Black Beta (Nashbar frame), 2004 Trek 1000C for the trainer
Quoted: 270 Post(s)
Liked 447 Times
I too am running the Bontrager GR1’s, but with tubes on Bontrager Affinity Disk TLR wheels in a 700x40c. The only complaint I have is that the 40c is to narrow on loose gravel. My buddies are riding Maxis (don’t know the model) in 29x2.5 on their Checkpoints, they are killing the gravel, and still doing century + days on the pavement still maintaining a 15mph average pace.
Quoted: 130 Post(s)
Liked 119 Times
Ah I'd have gotten a Checkpoint SL6 if available. Rack mounts. Allows much wider tires and has a regular round seat post too. I am still looking at and AL5 for more gravel and also lite touring. The GR1 35MM is not too bad on fine gravel but the rough stuff I had it burp some sealant. I'm still not sold on tubeless. Wish I could larger tires.
I was asking about running the GR1 Tubeless, because it’s not a tubeless rated tire, unless it’s the GR1 Team Issue…
Obsessed with Eddington
Bikes: '16 Spesh Diverge, '14 Spesh Fatboy, '18 Spesh Epic, '18 Spesh SL6, '21 Spesh SL7, '21 Spesh Diverge...and maybe n+1?
Quoted: 532 Post(s)
Liked 621 Times
Kind of answered your own question here. It might work. Personally, my time is much more important to me, I’d just get a set of tires that are tubeless ready, and there are many options, and be off and riding in 30-40 minutes.
Quoted: 130 Post(s)
Liked 119 Times
it was something a friend and I were discussing as I was dismounting the tire to fix a flat tube… the tire was so hard to break the bead we thought it might be possible to run it tubeless on the TLR wheel with the appropriate sealant tape and valves… it was just a question
Quoted: 532 Post(s)
Liked 621 Times
Likes For Badger6:
Quoted: 130 Post(s)
Liked 119 Times
I didn't mean to come off snarky, if I did. It's worth a shot, as some "non tubeless ready" tires can be set up that way, but in my experience it's very hit or miss (usually miss), and with the plethora of available TLR options available, I just think it isn't worth the hassle to experiment with "off label" use when you can get a tubeless ready rim and tire combo and get set up with minimal effort.
I have a set of Maxxis tires in my sights… i am going to wear out these GR1’s first though.
Likes For M Rose:
Quoted: 1083 Post(s)
Liked 686 Times
The people that are saying it won't make much difference have never tried it. In fact the tires make a huge difference and the GP5000s would give you an entirely different riding experience, much better for paved roads.
I have three nearly identical wheelsets that I can swap between a few different bikes (different handlebar setups). If I'm going to be riding a paved MUP, I'm going to use the skinny tires, not the big heavy MTB tires that I use when riding the dirt/gravel roads. The bike is faster and handles much better. There's tread pattern and rolling resistance, but also a big part of it is weight. Compare the weight of your current tire to a GP5000. I'm guessing the difference is substantial, and you will definitely feel the difference in a lighter tire. They're faster and the bike is more nimble - it's just more fun to ride. We use the MTB tires for most of our riding on the local hardpack/gravel roads. Skinny tires are NOT so much fun there and in fact it's a bit risky. We need the grip and cushioning of the larger knobby MTB tires. When we dive off into a paved subdivision, those tires are heavy and slow.
Tires (and rims, and tubes) make one of the biggest differences in the characteristics of how a bike rides and handles. It's rotating weight, so of course. You can't turn it into a fast road bike, but you can make it lean more in that direction with lighter tires. If your rims aren't too wide and all of the riding will be paved, could you go with 28c?
Likes For Jeff Neese:
Bikes: Two Independent Fabrications, a Niner RLT, and a Trek Domane
Quoted: 10 Post(s)
Liked 16 Times
Tires and potentially aero rims make a huge difference. With retirement in mind I purposefully went N-1 for my last gravel bike purchase. I have two sets of wheels with identical I9 hydro hubs but very different rims profiles - one for gravel and one very aero for road (ENVE G23 with Schwalbe G-One 40C vs SES 4.5 with Schwalbe Pro One 28C). The bike is much faster and more nimble on the road with the appropriate wheels. I put identical 11-34 cassettes on them which has been the only downside. Being in a pace line with a group at speed means hunting for the right gear compared to my road bike with an 11-28. Otherwise the ability to swap wheels/tires makes one bike into two.
Likes For gravelfan:
Bikes: Dahon Jetstream p8 (sold), customized Dahon Helios x10, customzed Dahon Smooth Hound x11,customized Dahon Hammerhead 8.0 d7, Planet X Free Ranger (mullet setup 1x11), Planet X Giovanissimi 20 (1x9), Frog 52 (1x9) and Frog 48 1s
Quoted: 264 Post(s)
Liked 239 Times
reducing rolling resistance, aero, etc. that's all good to improve average speed but for me, the main issue is time in the saddle. Past 2.5/3 hr, lower back, wrists are getting tired and I fond that whatever improved comfort is more valuable as Time is the limiting factor rather than distance.
As many, I have a redshift stem on "lower pressure" tyres which look after the upper limbs comfort but, the latest mod is a S-Work CGR seatpost. As I'm short, the seatpost does not protrude much so I cannot use the canyon VCLS and had to go for the next "best thing"; it kills the buzz in the lower back and that alone shift the discomfort point much later increasing the potential time in the saddle and the yield (much easier to transfer power when it's confy).
Talking to local pro coach etc, the next thing to do is a proper fitness plan with gym schedule, physio etc, but with a family and work, this is not an option so compromises have to be accepted
Quoted: 270 Post(s)
Liked 447 Times
I didn’t want a Checkpoint… got a 520. I can go up to a 29x2.0 with fender or 29x2.5 without fender. It came with front rack, added a rear rack… the 520 has a regular seat post… well had, it now sports a PNW Coast Dropper Post.
Edit. Got back from a trip. Air pressure dropped from 50 psi to 42 psi. Better than before.
Likes For biker128pedal:
Quoted: 270 Post(s)
Liked 447 Times
Liked 686 Times
Exactly. My first experience with this was my '83 Trek 720, a full-on touring bike with tough but heavy 1 1/4" touring tires that held up well to many miles of loaded touring. But then I had another set of wheels built, specifically to be as light as possible and with skinny 1" road bike tires, and man - what a difference. The 720 was still as long as a Cadillac and just as comfortable, but now it actually handled, it was somewhat fast, and it was fun to ride. It turned it into what we would now call a "sports touring" bike. Having two wheelsets turned the 720 into two different bicycles, literally.
A second set of wheels with road tyres. In the summer, my gravel wheels don't come off the gravel bike and I use my summer bike for road rides and most commuting duties. In the winter, the gravel wheels come off the gravel bike, and I swap on my other set of wheels with 32mm pirelli cinturato velos for winter road riding and commuting. Not the fastest rolling of tyres, but have excellent puncture for protection for winter road conditions. I keep the cassette the same on both wheelsets (a whopping 11-42) because I don't use my gravel bike for racing, and winter isn't about fast rides, but about being sociable (for me- I use zwift in the winter if I want to race and for training).
