Patching a cut tire - what do you think?
Quoted: 142 Post(s)
Liked 34 Times
Got my first tire cut. Someone recommended to patch the tire rather than replacing it. So is doing this or something similar worth it or is it too dangerous?
Quoted: 1324 Post(s)
Liked 927 Times
Looking at the cut tire in your other thread I'd say no way I'd trust that tire with any kind of repair. In my honest opinion t hat tire is dead and should be disposed of. I'd cut it in half and throw it out. I cut any unsafe tires of mine in half before throwing them out. That way I know that some poor person won't use it.
Cheers
Cheers
Likes For Miele Man:
Really Old Senior Member
If you have to think about it, the gene pool can always use a little self chlorination.
Likes For Bill Kapaun:
Quoted: 506 Post(s)
Liked 639 Times
Assuming the tire in the video is NOT yours, unless you can show us the cut we have no idea whether it can/should be repaired. Small cuts that don't cut through the casing can be fixed with super glue or shoe goo. Small casing cuts can be booted and as long as there is no significant bulge in the tire, can be ridden safely assuming the boot job is done properly. When it comes to sewing the cut with thread, then you are on your own. I'm currently riding on a booted tire with over 3,000 miles on it.
Quoted: 6193 Post(s)
Liked 4,810 Times
My test for cuts is to look at them after they are repaired and inflated to riding pressure. I won't use them if the cut area is pooched out like grandma's lips wanting a smooch from us when we visited as a kid. Actually not even quite that much.
If the cut area bulges after repairing, then I feel that too much of the casing and structural part of the tire is damaged. Also, I'd just be too uncomfortable that it wouldn't last. And while I wouldn't be concerned about bad things happening to me while riding it, I'd just be imagining that it's going to more likely just have me fixing the flat on the side of the road again and maybe the tire be in worse and unusable shape. I don't carry spare tires.
Likes For Iride01:
Quoted: 142 Post(s)
Liked 34 Times
Clark W. Griswold
Quoted: 4356 Post(s)
Liked 3,994 Times
Why are people so cheeaaaaap. Safety seems to be somewhere in 23rd place for people. Accept the tire is dead and get a new tire. A tire boot is an emergency thing to get you home or to the nearest shop beyond that, the sidewall is done. If it truly is a small cut and doesn't bulge I guess I would monitor it very closely and still probably just get a new tire to be sure.
Quoted: 5224 Post(s)
Liked 3,581 Times
very cool & surprising video
Likes For rumrunn6:
Quoted: 431 Post(s)
Liked 460 Times
Looks reasonable for a fat mountain bike tire. I don't know if I would attempt on a skinny road slick. I've done sidewall patches on road slicks before (not with stitching) and while it looks like it'll hold, I can't convince myself to ride them with high confidence. I've had a catastrophic blowout before on a road tire with damaged casing, so perhaps I'm just scarred from that experience.
Likes For tFUnK:
Bikes: Surly Bridge Club, 1992 Miyata 914
Quoted: 5 Post(s)
Liked 15 Times
I recently banged a new scwalbe G-0ne speed 650bx50 tire that put a split in the sidewall. The split was on the outer layer -- it did not go all the way through the sidewall. Replacing it was not a question of cost (a $65 tire), but availability -- Out of stock everywhere. A mechanic friend suggested his approach to saving such a tire. He uses industrial rubber gasket material, which has a dense, tough cloth inner layer. It's about 1mm thick. He super glued it to the inside of tire, across the split location. Then he put three layers of duct tape across the boot, making sure it covered the edges of the boot. When inflated, there was no bulge at the split. Lastly, he told me to mount the tire on the rear - never the front.
I am happily riding on my repaired tire with no issues so far. When stock is available, I will order a new tire.
Likes For wrobertdavis:
Quoted: 506 Post(s)
Liked 639 Times
Likes For KerryIrons:
Quoted: 1398 Post(s)
Liked 1,878 Times
just because I'm paranoid doesn't mean repaired tires aren't out to get me !
Likes For t2p:
Quoted: 966 Post(s)
Liked 1,629 Times
I would replace the tire for sure. Then I would patch the old one just to see if I could...
But then again I am one of those guys who can get mesmerized watching Youtube Hindi tire repair vids. Those laborers patching enormous tire gashes with raw butyl and vulcanizing cement.
Ahhh... the rich Toluene in the air... smells of victory... Ha
Likes For zandoval:
Clark W. Griswold
Liked 3,994 Times
That is good luck then. Heavy damage to a tire is not worth booting it is not a paranoia thing it is a safety thing. You have gotten good luck that is awesome but it is not something I would recommend to someone. On a small little cut, maybe with some time and care you could do something that would work fine but for big damage it is a big no. The only thing I am Paranoid about is Black Sabbath's second album...LOL
Likes For veganbikes:
Likes For Hondo6:
Quoted: 506 Post(s)
Liked 639 Times
Clark W. Griswold
Liked 3,994 Times
Also I did say heavy damage so I think we are agreeing there hopefully as you mentioned too large to boot.
Quoted: 5 Post(s)
Liked 15 Times
Sock Puppet
Bikes: 2014 Cannondale Synapse Carbon, 2017 Jamis Renegade Exploit and too many others to mention.
Quoted: 1031 Post(s)
Liked 863 Times
That would all depend on the size of the cut and where the cut is. A small cut within the tread area can be booted safely. No way I would do that with a sidewall cut or a very large cut.
Quoted: 506 Post(s)
Liked 639 Times
Of course it would depend on the size and location of the cut. Perhaps I made a bad assumption about people's ability to make a common sense decision about those factors. Going back to the original photo, there is no way I would EVER stitch a tire casing to repair it. That is not booting a tire. It's a kludge.
Likes For Lombard:
Quoted: 1109 Post(s)
Liked 1,200 Times
Well, I often make an assumption, but it's assuming the lack thereof.
On a different note, it's getting to the point of having to assume that nobody ever reads available manuals or instructions (RTFAMOI) about the parts that they're having trouble with before asking someone else to figure it out for them. But that's a different rant.
Bikes: 2020 Masi Giramondo 700c; 2013 Lynskey Peloton; 1992 Giant Rincon; 1989 Dawes needs parts; 1985 Trek 660; 1985 Fuji Club; 1984 Schwinn Voyager; 1984 Miyata 612; 1977 Raleigh Competition GS
Quoted: 1126 Post(s)
Liked 253 Times
Likes For Hondo6:
Quoted: 883 Post(s)
Liked 823 Times
Likes For 2old:
