Newer Tricolor brakes or other on a non-recessed frame?
Edumacator
Quoted: 2440 Post(s)
Liked 3,131 Times
Just in the planning stages, but I have a frame that is meant for bolt on front and rear calipers, and is not able to be drilled out for recessed use in the back (barrel style brake bridge).
Options
1. Drill out the front and install; buy a second front and convert to bolt on for the rear with a curved washer?
2. Find a different brake-set that would coordinate with the rest of the tri-color set?
If 2, what vintage brakes with bolt-ons actually stop the bike, AND coordinate with Shimano tri-color, AND will not brake the bank...?
Options
working on my sandal tan
Quoted: 3871 Post(s)
Liked 2,568 Times
SE Wis
Quoted: 2747 Post(s)
Liked 3,401 Times
YOu can often mount recessed calipers on an undrilled rear bridge with the concave spacers and a short recessed nut.
https://www.bikeforums.net/classic-v...ecessed-2.html
https://www.bikeforums.net/bicycle-m...not-drill.html
Edumacator
Liked 3,131 Times
I don't think so. I think they are pretty proprietary.
Edumacator
Liked 3,131 Times
Quoted: 3464 Post(s)
Liked 2,831 Times
Tekro
Edumacator
Liked 3,131 Times
I saw reviews for the 559 and they weren't too complimentary...I've heard they are pretty flexy...
Liked 2,568 Times
The R559 is a long-reach model. Short- and medium-reach brakes tend to have less flex.
Edumacator
Liked 3,131 Times
Not sure if there are many options in the short reach world. Might have to go Tektro after all.
Quoted: 502 Post(s)
Liked 466 Times
Tektro and 650B:
DA and 700C:
Edumacator
Liked 3,131 Times
Edumacator
Liked 3,131 Times
The Marinoni when it’s in 650B configuration uses Tektro 556 (predecessor to 559), and Dura-Ace 7402 short reach in its 700C setup, all with Kool Stop salmon pads. I certainly do NOT feel that the Tektros are flexy or deficient in any way. I certainly love and slightly prefer the feel of the DA brakes, but ATM I’m using and happy with the Tektros/650B’s. FWIW, my regular routes around home in very hilly Seattle include several 10%+ grades that I take several times/week.
Tektro and 650B:
DA and 700C:
Tektro and 650B:
DA and 700C:
weapons-grade bolognium
Quoted: 985 Post(s)
Liked 2,378 Times
You can flip the front and rear brakes, if you drill the fork. This will allow you to use just about any brakeset that has the correct reach.
You'll need concave bolts for the rear and an extended recessed front nut like so:
Edumacator
Liked 3,131 Times
I think this is where I am leaning. I saw somewhere else where the person drilled the concave clamp thingy and then used a short recessed bolt in the back, keeping it clean, while doing the exact thing you are talking about in the front.
Quoted: 985 Post(s)
Liked 2,378 Times
I'm running a bolt-on on the rear and an extended recessed on the front. No issues, newer Shimano brakes.
Extraordinary Magnitude
Quoted: 2608 Post(s)
Liked 1,703 Times
I ended up using 2 front brakes.
Commence to jigglin’ huh?!?!
