British Classic Bike Info Request
Bikes: 1980 Marinoni Special, 1987 Ciocc Microf. C40, 1978 Raleigh Competition GS, 1982 Colnago Super, 1972 Gitane Pro TdF, 1976 Belgian Diamant by Martelly, 1989 Trek 520, 1972 Dawes Galaxy 2014 Cervelo R5, 2020 Salsa Warbird, 2013 Giant Trance X1
Quoted: 91 Post(s)
Liked 61 Times
Happy sunny Sunday. Before I head out for my likely last fat bike ride of the year, here is an info request. I was contacted by an enthusiastic fan of British bikes who was wondering what this bike might be. I had some thoughts but told him I would post on BF for better feedback. The BSA crankset points to Birmingham Small Arms and I believe they also made frames. We were both interested in the 4 speed freewheel rear hub with a fixed gear flip flop. Any thoughts to share with Rod would be appreciated. He should be signing up in short order!
Quoted: 3814 Post(s)
Liked 3,345 Times
frame -
readers might be able to advance the discussion if you could include images of the head and fork crown as seen from the side
also images of the bottom bracket shell
odd that dropouts are without eyelets while fork ends display them
perhaps they were removed prior to the present respray
the D/S hub looks like it might be from S-A
the integral headset is something which was quite common on British cycles at one time
frame -
Shifting is fun!
Bikes: Yes, please.
Quoted: 2198 Post(s)
Liked 4,610 Times
Difficult to tell without bigger and better pictures as well as additional information, such as a serial number. The bike has clearly been 'restored' at some point in time, so parts may not be original. The seat cluster is the only thing I see that may provide a clue to someone. The location of the pump pegs suggests 50's or older.
That head badge would tell the tale. Post a photo of that.
Want to thank Dannyboy21 for directing me to this forum ... just signed up! As suggested I will post some additional pics shortly. Thanks again.
Likes For Oslerblue:
Liked 3,345 Times
it is simply a Union Jack transfer with no writing
mounted after the latest respray
best to place little weight on it
regarding the chainset -
Dannyboy21 wrote -
"The BSA crankset points to Birmingham Small Arms and I believe they also made frames."
BSA was a manufacturer of both cycles and fittings
many non-BSA bicycles were manufactured with BSA components OEM
so even if the chainset is original to the cycle it may or may not be a BSA bicycle
tip -
serial number placement and format can be a helpful clue in the detection process...
Dannyboy21 wrote -
tip -
Likes For juvela:
Here are some additional pics of the BSA bike I am currently working on. Would really like to know the model and original frame colour so I can try to match as closely as possible. Thanks.
Quoted: 91 Post(s)
Liked 61 Times
Can't wait to see the results! I will dive into online serial numbers to see if can find anything. Does that read 2960 or 2960 11, I wonder?
