Accessory water bottle mounts
Currently using three SKS accessory water bottle mounts on a 1982 Raleigh Competition GS. Have thought about brazing in proper bottle mounts, but don't want to damage the paint patina on the bike. Does anyone know of accessory water boittle mounts that are not as bulky as the SKS mounts? Something less obvious?
Bikes: 86' Centurion Ironman
Quoted: 628 Post(s)
Liked 316 Times
A screw-to-install rivet nut , https://www.mcmaster.com/rivet-nuts/...-rivet-nuts-6/
Mark .
Mark .
Thanks for the suggestion, Markwesti, however I am not a fan of rivnuts and have the ability to braze anyway, so if I drill the frame it will get brazed-in threaded inserts. Am hoping for suggestions to lower profile and less bulky than the SKS mounts.
Bikes: 1963? Anquetil , 1973 PX10,1979 PX10,1984 PX10, VITUS 979 PX10DU,1970S ALAN,1985 PSV10,1980s PY10FC,1978 bERTIN,ALAN carbon
Quoted: 283 Post(s)
Liked 636 Times
I have used the DMR clamps in the past and like them . MAybe still a bit obvious ?
3 sizes exist 28.6 , 31.8? ,34.9
5mm threaded hole
Bikes: 1980 Marinoni Special, 1987 Ciocc Microf. C40, 1978 Raleigh Competition GS, 1982 Colnago Super, 1972 Gitane Pro TdF, 1976 Belgian Diamant by Martelly, 1989 Trek 520, 1972 Dawes Galaxy 2014 Cervelo R5, 2020 Salsa Warbird, 2013 Giant Trance X1
Quoted: 91 Post(s)
Liked 61 Times
Mark .
Mark .
Likes For Dannyboy21:
Quoted: 4513 Post(s)
Liked 6,388 Times
Quoted: 964 Post(s)
Liked 1,451 Times
What about the old-school band clamp things?
They do away completely with the bolt holding on the cage, and can often achieve a very low-profile mounting, like so:
IIRC the old Specialized stainless ones were the best, having a dimple formed in them that would positively locate the clamp on the bottle cage bolt hole to minimize slippage.
Likes For scarlson:
Bikes: 1964 Huffy Sportsman, 1972 Fuji Newest, 1973 Schwinn Super Sport (3), 1982 Trek 412, 1983 Trek 700, 1989 Miyata 1000LT, 1991 Bianchi Boardwalk, plus others
Quoted: 583 Post(s)
Liked 699 Times
Friendship is Magic
Bikes: old ones
Quoted: 26425 Post(s)
Liked 10,381 Times
Likes For 3alarmer:
Friendship is Magic
Bikes: old ones
Liked 10,381 Times
...I've been gradually replacing some of my bar mounted water bottle cages, because I prefer to mount a bar bag there. And there's rarely room for both. Here is a list of all the bottle cage moung adapters I found on Amazon, but thus far the only one I can say works well from personal experience is the Topeak. I haven't yet mounted the others. They look like they ought to work.
https://www.amazon.com/dp/B08JH47VTD...v_ov_lig_dp_it
https://www.amazon.com/dp/B07KC656V1...v_ov_lig_dp_it
https://www.amazon.com/dp/B08NY4L8CY...lig_dp_it&th=1
https://www.amazon.com/dp/B01CY8JUY2...v_ov_lig_dp_it
Quoted: 964 Post(s)
Liked 1,451 Times
Likes For scarlson:
Friendship is Magic
Bikes: old ones
Liked 10,381 Times
Huh, I had the band clamps holding on an old aluminum Blackburn cage for about 350 days of touring, and it was one of the few things on the bike that _didn't_ break. Underlaid the cage with a piece of electrical tape to avoid marring the paint. Might've helped with grip. But the bands were bare on the painted frame tube.
...to be clear, that Topeak adapter is a pillar mount with a stainless steel band clamp that fastens inside the pillar. It's padded with rubber, or in this case, a piece of inner tube. Band clamps come in all shapes and sizes, but I've had the most success with those that can be torqued down pretty tightly, and padding them with rubber from old inner tubes.
2Flit
Location: Orcas Washington and currently Circumnavigating in a Farrier F36 Trimaran
Bikes: 1968 Rene Herse Gentleman's Bike; 1974/5 Jim Merz Custom-built; 1984 Rodriquez tandem; 2012 Bilenky Tandem; 1967 Cinelli SC; 1984 Specialized Exp. 68cm; 1971 Holdsworth 63cm(my first bike ever and owned since new!); 1994 Bridgestone MB5; 86'Trek420
Quoted: 38 Post(s)
Liked 170 Times
Braze-in later at repaint
Use the threaded insert, but 'glue' them in for now...
So here is a long list on metal epoxies. some of this stuff is as good as brazing an insert. Just use the first JB-Weld instead of brazing, then when it's time to repaint... heat things up, pop out the insert, clean and braze it in at the time you repaint the whole frame.
https://toolassociate.com/best-metal-epoxy/
Bike Butcher of Portland
Bikes: It's complicated.
Quoted: 4682 Post(s)
Liked 5,802 Times
Brazing in water bottle bosses is one of the simpler framebuilder jobs. The only downside of course is that your paint is now ruined. On the upside, if your Comp GS is a black model, @Andy_K knows the exact Rustoleum spray match. It's so good a match that it passes the 5' eyeball test.
Steel,Friction,Freewheels
Bikes: '69 Carlton Team Pro, '72 Carlton Giro d'Italia, '78 Motobecane C4C "sur mesure", '64 Royal Enfield Revelation, '73 Peugeot PX10, '77 Mercier Lugano, 2003 Moser M81
Liked 28 Times
Zefal Gizmos are a nice trick too; low risk to your painted tubes.
https://www.flickriver.com/photos/76...N07/446172138/
The Motobecane Grand Jubilee in the photo is using the Gizmos for the water bottle cage.
Crawlin' up, flyin' down
Quoted: 1027 Post(s)
Liked 2,531 Times
Put this or something similar on your handlebar. Works great, your bottle is easy to grab, and no damage to your paint unless you crash, at which point you have bigger problems to worry about.
Quoted: 877 Post(s)
Liked 2,293 Times
I prefer a bar mount myself . It is easier for me to grab and the bottle stays cleaner, nothing worse than reaching down(without thinking) and using your teeth to pull open the spigot and feeling grit in your teeth. This is usually on damp roadways but it happens. I use whatever the bike I am riding on has but much prefer bar mount. My Competition GS came with hose clamp type mount that was fortunately pro mounted at the Cupertino Bike shop where it was purchased so the clamps had a "gasket" . No marks on the original paint when I removed them. I modified a drink holder from a beach cruiser to accept a water bottle.In this case I was heading out for a long ride so the Sub Zero SS water "tank" fit just fine!
It ain't the prettiest but it works!
Bikes: Yes
Quoted: 3230 Post(s)
Liked 3,868 Times
BTW, it's just Rust-Oleum Gloss Black Enamel. No special shade. Black is black, apparently.
My Bikes
My Bikes
Scarlson, I am such a dope!! I forgot all about those H2O clamps from the old days. Installed hundreds of them and I forgot all about them. They are less intrusive than the SKS that I have. Will be ordering eight of them soon! Thanks for the reminder, I owe you one.
Likes For TiHabanero:
