TSDZ2 problem - pedals spin freely, not engaging with gear
Old 09-06-22, 12:50 AM
jeffieh
South Seas Correspondent
jeffieh's Avatar
Liked 6 Times in 4 Posts
Greetings from the South Pacific! I write today with a minor-ish but annoying problem that's happening with my TSDZ2 mid-drive. Sometimes (and it's usually just after changing up) the cranks spin freely instead of engaging with the motor gear. It's a completely 'clean' spin - no hint of the shaft partly engaging or rubbing or anything like that. I wondered if it could be the sprag clutch but I can't see how this would totally fail occasionally and yet work perfectly most of the time. Has anyone had this experience, and if so did you get to the bottom of it?
Any feedback will be gratefully received.
Many thanks, Jeff
TSDZ2 48v, 500w with 6100km on the clock.
jeffieh is offline
Old 09-06-22, 08:06 AM
2old
Quoted: 883 Post(s)
Liked 824 Times in 623 Posts
Not much on the "TS" here; you might check endless sphere.
2old is offline
Old 09-24-22, 07:34 PM
randomgear
Bikes: '89 Specialized Hardrock Fixed Gear Commuter; 1984? Dawes Atlantis
Quoted: 43 Post(s)
Liked 2 Times in 1 Post
Nothing is failing, the mid-drive needs to have a freewheel in order to have the pedals remain in place while the chainring spins and provides power. The same situation occurs on my mid-drive Bafang 750w, when I hate it is when I stop and find no resistance on the pedals, but it;s an issue with the mid-drive system.
randomgear is offline
Old 09-24-22, 08:57 PM
Doc_Wui
Doc_Wui's Avatar
Quoted: 340 Post(s)
Liked 275 Times in 192 Posts
I cannot see it being normal on any middrive, because if the pedals spin freely forward, you could get injured badly. For example, if you stand on the pedals while climbing a hill, they better not let go,
Doc_Wui is offline
Old 09-25-22, 09:35 AM
2old
Quoted: 883 Post(s)
It's never occurred with any of my three BBS02's.
2old is offline
