Frame Painting: stuck Al seatpost in carbon frame
I have an old 27.5 mtb carbon frame that i want to spray paint. The frame itself is in carbon and the seatpost is aluminium. Frame and seatpost is totally stuck. My plan is to use some kind of sealant and make the transition smooth from the frame to the seatpost, then paint the whole frame and seatpost in one go. I see that a lot of the primers on the market is specifically made for either carbon or aluminum. The question is: What kind of primer should i use? Anything to consider while spray painting carbon and aluminum in one go? Any tips in which sealant to use?
Thank you!
Thank you!
Randomhead
Liked 3,802 Times
You should get the post out. The LBS uses Coca-Cola
Likes For unterhausen:
