What is the function of these screws on the brake pad cartridge?
Shimano BR-9000. It is not explained in any of the Shimano manuals I’ve seen.
Quoted: 5969 Post(s)
Liked 2,878 Times
They engage a slot in the pack of the pad, locking it in place so it can't slide out if you apply the brake while rolling the bike backward.
FB
Chain-L site
FB
Chain-L site
Liked 2,878 Times
Logically I'd expect the guide to be formed extending inward for that reason, but wonder if the screw was added as a correction after reports of shoes coming off.
OTOH an extended guide might become a problem as shoes wear, while the screw could be removed if/when necessary.
Likes For FBinNY:
aka: Dr. Cannondale
Quoted: 2173 Post(s)
Liked 3,521 Times
Shimano refers to it as a ‘tire guide’ on the exploded diagram, but doesn’t address adjustment in the owner or dealer manual.
I am potato.
Quoted: 1826 Post(s)
Liked 1,704 Times
They also act as "squealers" when the pads get worn down to cue the owner that it is time to change the pads. At least that's been my experience maintaining Mrs. Base2's winter commuter bike.
Car dependency is a tax.
Method to My Madness
Quoted: 2068 Post(s)
Liked 1,561 Times
I wish it was this easy to remove worn brake pads! I had to use pliers to pull out the Shimano R55C4 pads in my calipers before installing CF specific brake pads.
Liked 2,878 Times
Eons ago, I modified an oyster knife, to make a pad remover. I guide or tap it in under the pad, and a quick twist pops it free.
FB
Chain-L site
FB
Chain-L site
Likes For Biker Pete:
I am potato.
Liked 1,704 Times
Sometimes you are just happy your spouse has decided to participate in the same hobby and tries to do well. No harm. No foul. The plastic nubs did their job & I learned a thing.
