derailleur set screws
Old 06-03-22, 05:08 PM
capnjonny
capnjonny's Avatar
Quoted: 339 Post(s)
Liked 632 Times in 229 Posts
At the Bike Exchange we have crates full of used derailleurs,. Everything from early Suntour 7 and Shimano Crane to newer Shimano 105, Ultegra, and Deore that we use when fixing or restoring donated bikes. Yesterday while restoring a Schwinn World Sport I pulled a nice looking Ultegra rear der and installed it only to find that one of the adjustment screws was stuck. Long story short, the only way I could get it to budge was to clamp the head with some needle nose vice grips which ruined it. I went to try to find a replacement only to discover that we had nothing.
So here is my question and request.
Is there a universal standard for these screws?
Where can we order a box of 50 or 100. ?
Also , is it possible to get these with a hex socket head. Often the slot, Philips head is stripped when you look at them in the bin. It seems like a square head or hex socket head would be much better.
capnjonny is offline
Likes For capnjonny:
Old 06-03-22, 06:02 PM
Bill Kapaun
Really Old Senior Member
Bill Kapaun's Avatar
Bikes: 87 RockHopper,2008 Specialized Globe. Both upgraded to 9 speeds. 2019 Giant Explore E+3
Quoted: 1795 Post(s)
Liked 1,269 Times in 876 Posts
A JIS Phillips screwdriver will ease some of your problems.
Bill Kapaun is offline
Old 06-03-22, 07:33 PM
John Nolan
Bikes: Raleigh Classic 15, 84; Miyata 912, 85; Miyata Ridge Runner SE, 85; Miyata 610, 86; Miyata 100M, 86; Miyata Valley Runner, 88; Miyata Triple Cross, 89; GT Karakoram, 90; Miyata Elevation 300, 91; Marinoni Touring, 95; Long Haul Trucker, 2013
Quoted: 159 Post(s)
Liked 133 Times in 80 Posts
JIS Phillips and penetrating oil usually frees them. I don't have an answer on where to source replacements, or if there's a standard size. You could try getting them from other trashed unit, I guess.
John Nolan is offline
Old 06-04-22, 12:00 AM
MudPie
MudPie's Avatar
Quoted: 114 Post(s)
Liked 119 Times in 92 Posts
Do you know what number JIS Philips is typically used on derailleurs?
Thanks
MudPie is offline
Old 06-04-22, 12:26 AM
LesterOfPuppets
cowboy, steel horse, etc
LesterOfPuppets's Avatar
Bikes: everywhere
Quoted: 12771 Post(s)
Liked 7,688 Times in 4,081 Posts
I've gotten a couple at Ace Hardware, and Winks Hardware in Portland. It's been ages, but it seems like they were M3x0.5 for olde Shimano and Suntour.
Once you figure out size and length(s) you need, McMaster Carr has socket head bolts in bags. I'd probably just go for the zinc plated steel.
LesterOfPuppets is offline
Old 06-04-22, 03:04 AM
Aardwolf
Wheelman
Bikes: 1982 Holdsworth Avanti (531), 1961 Holdsworth Cyclone
Quoted: 298 Post(s)
Liked 676 Times in 341 Posts
Suntour Cyclone and VX takes M4 metric fine.
I had a stripped one and retapped it to M5 metric fine.
Aardwolf is online now
Old 06-04-22, 04:46 AM
John Nolan
Quoted: 159 Post(s)
Thanks
I use a #1.
Old 06-04-22, 10:38 PM
MudPie
MudPie's Avatar
Quoted: 114 Post(s)
Originally Posted by John Nolan
I use a #1.
Thanks! I didn't realize a JIS screwdriver is the proper tool for the job. I looked at purchasing and saw many available sizes.
MudPie is offline
Old 06-05-22, 07:50 AM
JohnDThompson
Old fart
JohnDThompson's Avatar
Quoted: 3588 Post(s)
Liked 3,400 Times in 1,934 Posts
Hozan makes a nice JIS screwdriver set. The large ones work well on bikes, the smaller ones on electronics and cameras. Get the set, you won't regret it.
JohnDThompson is offline
Old 06-05-22, 08:04 AM
Crankycrank
Quoted: 837 Post(s)
Liked 1,061 Times in 745 Posts
I was made aware of these about 20 yrs ago after working on Japanese motorcycles for 30 yrs. and feckering up a few screw heads. The JIS work for all Asian made products (pretty much everything in your house) and really lock into the heads compared with non-JIS tools. There has been a change to try to make one standard and there are some headache inducing articles on this so you may not have to buy stated JIS screwdrivers but I forgot the info and recommend reading up a little if you want to widen the list of JIS compatible tools. Well worth the investment for working on bicycles with their small, not so easy to see well and not always hardened fasteners.
Crankycrank is offline
Old 06-05-22, 08:11 AM
the sci guy
bill nyecycles
the sci guy's Avatar
Quoted: 789 Post(s)
Liked 350 Times in 190 Posts
TIL: the difference between a phillips and a jis phillips
Twitter@theSurlyBiker
Instagram @yankee.velo.foxtrot
the sci guy is offline
Old 06-05-22, 12:16 PM
Troul
Troul's Avatar
Liked 2,971 Times in 1,918 Posts
could swap them out for something similar to these:
https://www.grainger.com/product/6FA...B&gclsrc=aw.ds
https://belmetric.com/m4-stainless-a...13-flat-point/
-Oh Hey!
Troul is offline
Old 06-05-22, 12:38 PM
Aardwolf
Wheelman
Quoted: 298 Post(s)
Worth checking what the thread is: Suntour Cyclone and VX is 'metric fine' which is M4 x 0.5 mm pitch (metric standard is M4 x 0.7mm pitch).
Metric fine: https://www.fastenerdata.co.uk/fine-thread
Metric standard: https://www.fastenerdata.co.uk/metric-thread
I found some cap bolts that fit my Suntour Cyclone: https://www.ebay.co.uk/itm/384323051054
Old 06-05-22, 01:18 PM
csport
Bikes: Soma Double Cross Disc (2017), red Hardrock FS (circa 1996)
Quoted: 217 Post(s)
Liked 155 Times in 102 Posts
This or similar ones of a different length.
csport is offline
Old 06-05-22, 01:54 PM
Troul
Troul's Avatar
https://belmetric.com/m4x0-5-fine-al...13-flat-point/ JIC the other ones are not fine for the standard hardware used.
-Oh Hey!
Troul is offline
Old 06-05-22, 07:59 PM
veganbikes
Clark W. Griswold
Quoted: 4355 Post(s)
Liked 3,994 Times in 2,665 Posts
From what I have read most crosstip screwdrivers are now coming as JIS compatible so essentially Phillips and JIS are sort of phased out to a more universal crosstip though I use my JIS screwdrivers on everything I have a Hozan and also got the lovely Park Tool DSD 2 and 4 (one is crosstip the other is flat head and I cannot remember which is which number wise). A good set of tools and knowledge on how to use them is really handy.
veganbikes is offline
Likes For veganbikes:
Old 06-05-22, 10:31 PM
MudPie
MudPie's Avatar
Quoted: 114 Post(s)
TIL what TIL means! ( I had to look this one up.)
MudPie is offline
Likes For MudPie:
Old 06-07-22, 04:07 PM
cyclocross808
JIS screws
Thanks to Cap'n Jonny and other volunteers' hard work refurbishing bikes, we put this together, hopefully to help other mechanics: https://bikex.org/home/past-articles...rs-don-t-do-it
cyclocross808 is offline
