Questions on shifter, derailleur & cassette compatibilty
Added Nov 21, 2022Will 6/7 speed RD-TY300-SGS and appropriate 9-speed shifter work with 9-speed cassette CS-HG400-9, 12-36T?Max capacity of RD is 34T. link to cassettehttps://bike.shimano.com/en-EU/product/component/alivio-m3100/CS-HG400-9.html link to RDhttps://bike.shimano.com/en-US/product/component/tourney/RD-TY300-SGS.html
Hi
Two combinations.
Added: Shimano
1. 7-speed shifter, 8-speed cassette, 7-speed derailleur
Can above combo use 7 out of 8 cogs in the 8-speed cassette?
2. 8-speed shifter, 8-speed cassette, 7-speed derailleur
Will above combo use all 8 cogs in the cassette?
Thanks
Hi
Two combinations.
Added: Shimano
Thanks
SE Wis
Quoted: 2747 Post(s)
Liked 3,399 Times
Brand?
Likes For bboy314:
Mad bike riding scientist
Quoted: 6219 Post(s)
Liked 4,219 Times
Thanks
Thanks
Stuart Black
Stuart Black
Clark W. Griswold
Quoted: 4357 Post(s)
Liked 3,994 Times
2 is going to work I am running 7 and 8 speed derailleurs with 9 speed shifters (cassette and chain as well) and they work just fine. 9 is the way to go as you can still find decent serviceable 9 speed stuff.
Bikes: More bikes than riders
Quoted: 1446 Post(s)
Liked 762 Times
I have experience with both situations described above and both have worked acceptably well to me. This is with Shimano "mountain" stuff, though I think mountain and road are pretty interchangeable in 7- and 8-speed land.
I'm currently using an 8-speed Microshift thumb shifter on a 7-speed Shimano cassette with an 8-speed Acera derailer on one of my bikes and it works very nicely.
Liked 762 Times
https://sheldonbrown.com/cribsheet-spacing.html
(Having said that, I think IG's sprocket spacing itself...center-to-center...is compatible, so should work similarly as long as the chain will support it.)
Liked 4,219 Times
Did you mean to say Shimano IG (Interactive Glide)? I think the sprocket thickness on those is pretty thick (with thin spacers). I think it's Shimano HG (Hyper Glide) that's compatible with SRAM, right?
Stuart Black
Stuart Black
SE Wis
Liked 3,399 Times
"In general" Shimano 6 - 10s road and 6 - 9s mountain rear derailleurs all use the same ratio. There are a couple outliers in Dura Ace
Quoted: 2026 Post(s)
Liked 1,096 Times
10-speed is the dividing line. For road rear derailleurs 10-speed is backward compatible with 7,8 and 9-speed components. For MTB derailleurs 10-speed is not backward compatible. 11-speed and above aren't backward compatible at all.
Liked 4,219 Times
I assumed that anga is using mountain derailers. That may have been a wrong assumption but someone using 7 and 8 speed equipment at this date is probably not using road equipment. No point in muddying the already muddy waters.
Stuart Black
Stuart Black
Liked 4,219 Times
Stuart Black
Stuart Black
Just to be clear, your system will work better if the shifter and cassette are matched. You can make a 7 speed shifter shift an 8 speed cassette but you’ll get better results if you make the 7 speed shifter shift a 7 speed cassette and an 8 speed shifter shift an 8 speed cassette. If you have a 7 speed shifter and need lower gears you can get wider range 7 speed cassettes like this one.
Quoted: 1944 Post(s)
Liked 2,164 Times
If you can fit an 8 speed cassette onto the freehub, that is the best way to go.
I’ve lived in the 7 speed cassette with 8 speed shifters for a years due to freehub body/frame limitations. Still have one set up that way.
I’ve read many posts saying it is possible as is, but in my opinion, the only way I would run it is to:
Use a cassette with full length cogs,
Take it apart, and
Sand the plastic spacers to get the correct center to center spacing of 4.8mm.
Depending on the freehub body and lockring, you might need a slightly wider spacer behind the cassette, or shim washer(s) between the lockring and the 1st position cog. This is only necessary if the lockring bottoms out against the freehub body.
You need to block out one shift. The only caveat doing this with any pawl/ratchet index shifter, front or rear, is make sure to set the end limit screw doesn’t cause the pawl to wedge against the ratchet. Actually this holds true regardless of blocking a shift.
John
Take it apart, and
John
Liked 4,219 Times
That’s the best way to go. Your 7 speed derailer will work with it.
Stuart Black
Stuart Black
Shimano's current 10-speed road group (Tiagra 4700) uses the new Shimano 11-speed road pull ratio. The Tiagra 4700 RD won't work with Shimano 6-9 speed shifters, or other Shimano 10-speed road shifters, for that matter - including Tiagra 4600.
I understand the same is true of the Tiagra 4700 double FD, but not the triple. Can neither confirm or deny this from personal experience, though.
link to cassette
https://bike.shimano.com/en-EU/produ...S-HG400-9.html
link to RD
https://bike.shimano.com/en-US/produ...TY300-SGS.html
link to cassette
link to RD
Liked 4,219 Times
link to cassette
link to RD
link to cassette
link to RD
Stuart Black
Stuart Black
Likes For cyccommute:
Maybe but probably not. The shifter and the cassette aren’t the problem. The rear derailer is. It just doesn’t have the capacity for the 36 tooth cog and likely can’t be pushed to make it work. You’d be better off with an Acera M3000 which has the capacity for a 36 tooth cog. It’s about $30 and is worth every penny when compared to the Tourney.
Other point I recall is that front difference in chainring sizes is binding while rear difference in cog sizes is not as long as total capacity is not exceeded.
Here front difference is 18 (40 - 22), rear difference is 24 (36 - 12) and total difference of 42 is less than total capacity of 43.
I have zero practical experience on this issue.
So, experienced users are welcome to comment.
Liked 4,219 Times
Keep reading that max rear capacity for Shimano RDs is conservative and can easily handle a couple of more teeth.
Stuart Black
Stuart Black
Total capacity of RD is 43
Low sprocket_Max is 34T
Low sprocket_Min is 11T
Max front difference is 20
What I recall reading is that the derailleur can handle a sprocket 2T larger than the Low sprocket_Max as long as the total capacity is not exceeded.
cyccommute are you saying this is not the case?
If above RD doesn't work, will go for RD-M2000 or RD-M3100 that support 36T. RD-M3000 is unavailable here.
Liked 4,219 Times
Yes, the two rear derailers you listed would work.
Stuart Black
Stuart Black
