Stronglight cottered cranks
Quoted: 339 Post(s)
Liked 632 Times
I recently was given a couple very nice Stronglight steel cottered cranks. I was waiting for a project to use them on when I got my hands on a Gitane Interclub that was donated to the Bike Exchange. I thought it would be a nice upgrade to the Somewhat less well finished crank on the bike. After stripping the bike and regreasing the spindle bearings I went to install the crank arms only to find that they didn't fit, being a mil to large in diameter. Pulling out about a dozen old spindles I had in the shop I tried all of them on the Stronglight crank and they were all a hair too large for the Stronglight cranks. I then went in to the Bike Exchange and pulled out all the cottered spindles we had. I found at least 3 distinct diameters among them. Luckily I got 2 that fit the stronglight cranks. Most were larger and one was even smaller than the stronglight.
Does anyone have any further info on this topic. I also found 2 different spindle lengths in the pile with different offsets right and left. I had assumed that since all cottered cranks were for double chainrings and 120 mm dropouts they would all have the same profile.
Quoted: 3815 Post(s)
Liked 3,345 Times
there are two main diameters for cottered spindles:
British & Metric
Brit is 5/8" / 15.88mm nominal / 15.75mm actual
Metric 16mm nominal, 15.9mm actual
British & Metric
Likes For juvela:
Location: Western Riverside county, Southern California
Bikes: 07 Raleigh supercourse, 04 Specialized epic MB, Surly 1x1, Recycled Recumbents Mach 2, 63 jc Higgins racer single speed, early 60’s Armstrong roadster, KHS tandem electric conversion, GT mb electric city bike conversion.
Quoted: 14 Post(s)
Liked 21 Times
Don’t forget about the many single chainring cottered cranks found on 3 and 5 speed roadster style bikes. Lots of those produced from many different countries of origin. Spindle length could vary on these single chainring models also.
If I own it, I ride it
Quoted: 591 Post(s)
Liked 663 Times
I would guess that near the arm size of the crank there is an "A". That means it is for an English (Anglais) spindle. Example below:
I came across the same issue.
Likes For CV-6:
Old fart
Quoted: 3591 Post(s)
Liked 3,401 Times
Here's what Sutherland's (4th ed.) has to say about cottered bottom bracket axles:
Likes For bbbob:
Bikes: Drysdale/Gitane/Zeus/Masi/Falcon/Palo Alto/Raleigh/Legnano
Quoted: 987 Post(s)
Liked 646 Times
That's a lot more detail than my 1974 edition has!
Larry:1958 Drysdale, 1961 Gitane Gran Sport, 1974 Zeus track, 1988 Masi Gran Corsa, 1974 Falcon, 1980 Palo Alto, 1973 Raleigh Gran Sport, 1974 Legnano. Susan: 1976 Windsor Profesional.
Quoted: 591 Post(s)
Liked 663 Times
Not correct in this application. The "A" is for Anglais or English spindle. The "A" is by the arm size, not the model number. The model 45, which is the pic I shared, did not appear in a Duraluminum model. So there is/was no need to indicate a steel or Duraluminum model. Your statement is correct when applied to the 49 model, but the crank in question is cottered and the 45 is the only Stronglight model that used 50.4 BCD and is cottered
Quoted: 753 Post(s)
Liked 737 Times
My experience is limited, but I think all of the 3 pin cottered Stronglight cranks I have messed with are from 70's Raleigh Super Courses. I have no idea wether a Raleigh spindle is compatable with French cups, but that would be the first thing I would try
Liked 3,345 Times
mfr catalogue page of 1958 -
I've never seen a Stronglight cotter crank or spindle that wasn't "anglais" size, so why would they need to mark it as such? It's the Italian stuff that uses the larger diameter "metric" spindles in my experience.
Quoted: 591 Post(s)
Liked 663 Times
And remember, gotta love the French.
Quoted: 339 Post(s)
Liked 632 Times
Thanks for all thr info on cottered cranks. I work on more of these than I want to. I am tempted to buy a cotter press if they were affordable . luckily the Bike Exchange has one I can use.
Here are a couple pictures of the bike I wanted to put the Stronglight crank on, an early 70's ? Gitane Inter club . Gotta love that purple paint. I was going to put yellow bar tape on it but the cheap tape we had broke when I was wrapping the bars. I am not sure what the proper way is to wrap bars without hoods.
So here are the pictures. For its age the bike was in very good condition. The decals were almost completely intact. I only changed the front and rear derailleurs for something a bit more durable. I also swapped out the sew up rims for clinchers and gave it bar end shifters. We have a ton of them at the shop and I think they are easier and safer to use than down tube units. no looking down every time you shift.
Likes For capnjonny:
blahblahblah chrome moly
Quoted: 1181 Post(s)
Liked 2,576 Times
I think some vintage track cranks don't even have room for a derailer cage between the chainring and the crank, so they can't really be adapted to a 2x drivetrain. Narrow tread was a selling point to racers, especially pre-WWII.
Likes For bulgie:
