Help regarding dent repair on seat tube Reynolds 531ST
Hello!
I have heartbrokenly damaged the seat tube of my newly acquired frame with reynolds 531ST tubing .
Please see pictures in this album:
bikeforums.net/g/album/23836293
I was thinking to repair this by running a greased up 26.9mm steel pipe(seat tube inside diameter is 27mm) with the end of it sloped to be as gentle to the seat tube as possible. Also with a notch cut out in the pipe for the bottle cage hole, the hole It has a slight protrusion inside the tube.
Would this be ok or are the dents too deep? Would I make it even weaker by pushing it out even if the repair goes well, is the tube stronger if I just leave the dent and try to live with it? I don't want to try to roll it out with frame blocks cause of the bottle cage protrusion on the outside and I don't want to mess up the paint. I obviously don't know how weak and thin bicycle tubing is or I would not have managed to damage it in the first place so I'm asking for help from the experts .
Thank you for any help!
Likes For Nessism:
Randomhead
Liked 3,699 Times
That bottle cage boss is going to make dent removal difficult
I have a tool that's like a stem wedge that works great. There is nothing wrong with pushing it out, if you can.
Likes For unterhausen:
Would I be taking a sizeable risk to the integrity of the seat tube with trying?
Thank you for your input!
This may not work, but I would give it a try if it were mine:
Remove the bottle cage bolts. Take an old tube and cut it in half with the cut 10-12 inches away from the valve. Trim the long end of the tube so it will extend past the dent. Tie a knot as close as you can to the valve and on the other end. Partially inflate to give the tube some structure and wrap it in kraft paper to protect it. Insert into the seat tube with the valve as close to the seat tube as possible and inflate. With a small soft faced hammer, lightly tap the edges of the dents. They might come out. They might not.
Space Ghost
Bikes: Bridgestone, Fuji, Iro, Jamis, Gary Fisher, GT, Scott, Specialized and more
Quoted: 292 Post(s)
Liked 412 Times
I actually just did this on a trick track/fgfs bike. Ran a well greased and rounded at the end rod through there.
Popped the dent right out with just a tiny mark left behind.
It worked pretty well. And was easy peasy 1-2-3. I doubt anyone will even be able to notice after a re-paint.
Same spot, too, but I didn’t have to deal with the bottle cage bosses which helped a lot.
The wedge idea mentioned above sounds like it would work even better, although the proximity of the dent to the bosses complicates this approach as well.
Likes For Rage:
Quoted: 4209 Post(s)
Liked 3,875 Times
One might have to sculpt the end of whatever mandrel/expanding tool to go around the bottle boss best possible.
Not important is how the dent was caused. A U lock? Andy
AndrewRStewart
AndrewRStewart
Likes For Andrew R Stewart:
Never done it before and I was way overestimating how tough the seat tube would be to be used as the levering point. I used the sturdiest piece of wood that I had lying around that would be long enough. It didn't occur to me that a *round* piece would just dent the seat tube quite quickly without moving the rear fork all that much.
Likes For Totte86:
Quoted: 103 Post(s)
Liked 144 Times
I have an '80s Columbine that was packaged insufficiently to deal with the rough handling of an airline. The seattube has a similar dent from the rear cogset banging against it as it made a trip many years ago. I considered turning a bar to the required diameter and then cutting a keyway on the mill to clear the bottle bosses. I think putting a brass nose on the bar and rounding it would make sure a sharp edge didn't dig into the dent and cause more deformation. I had also considered filling it with putty and painting it and never speaking about it again. And, proving that actions speak louder than words, I have just ignored it.
https://www.flickr.com/photos/54319503@N05/
https://www.draper-cycles.com
Likes For duanedr:
Quoted: 1610 Post(s)
Liked 2,592 Times
You might try an automotive paintless dent removal. I've watched those guys get dents out in pretty tight places. Seattube may have enough room to work with.
Likes For dabac:
my nice bike is at home
Your idea to fix it sounds interesting....tempting... Let us know how it goes.
I would 'heat' it up a bit w/hot water... makes it more pliable. Double check on that advice.
I have a similar dent in one of my frames, it is very thinned walled tubing.
Showed it to a frame builder and he said best to leave it, since moving the metal again will weaken it. He went on to say:
Metal is a 'crystal structure' & it can't move so many times before failing, like when you bend a paper clip back and forth..eventually on the 3rd or 4th bend, it snaps.
BMC Race Machine / BMC Team Machine / Rossin Record / 80's Pinarello Traviso / Merlin MTB / Raleigh "Folding 20" / Ti-Swift (!)
Erikson w/C&C couplers / Trek's: 2300, 1200, 990 / Jamis 'Sputnik'
Likes For kraftwerk:
Half way there
Quoted: 986 Post(s)
Liked 880 Times
I feel almost too ashamed to say but I was attempting to adjust the rear fork cause the frame was slightly out of alignment.
Likes For Moe Zhoost:
Moe Zhoost I like the cut of your jib. Making a tool for the specific damage sounds like a great idea..
Half way there
Quoted: 986 Post(s)
Liked 880 Times
I had a couple of bikes that needed attention first so it took a while to get going on the pipe.
First a mtb from a friend of mine that has quite a bad economic situation and the bike was pretty much ruined in the drivetrain and the in wheel hubs. Did the best I could and I'm sure he will not spend a dime on the bike anyway so no replacing worn out parts. 🎼 Polishing a turd 🎶
Then my older brothers very unmaintained Bianchi. Waiting for a shimano crank and bottom bracket to replace the very nice looking but broken campagnolo setup. What do you call a bike with both campagnolo and shimano parts, shimagnolo? ^^
I did finish the pipe today and also I managed to push out the dents some. There is still some indentation and looking down the inside of the seat tube I can see there are still some small bumps. But its a big improvement. If the pipe would have been a smidge wider or If I could expand it somehow at the right place it could possibly be even better.
These small white cracks, is this just the paint or is this structural damage? :S
bikeforums.net/g/album/23919537
Thanks for all the help!
Randomhead
Liked 3,699 Times
steel doesn't turn white when you crack it, it's probably the primer
I'll post a picture of my dent outner someday.
Space Ghost
Quoted: 292 Post(s)
Liked 412 Times
Glad it worked out okay.
And, yeah, looks like primer/paint cracks on there.
Intrigued by this “dent outner” of unterhausen’s.
That and Moe Zhoost’s suggestion both sound like great ideas.
Likes For Rage:
Bikes: many
Quoted: 1445 Post(s)
Liked 1,395 Times
I realize you've already done your dent repair, but I thought it worthwhile to relate how I tackled a similar problem on a Trek 770 several years ago.
I constructed something like a Cinelli-style wedge expander from a piece of broomstick. I made four crosscuts near the bottom and a hole the length of it. A bit of all-thread and some nuts completed the "tool." It worked well to remove most of the dent. I didn't have a water bottle boss to contend with, but I think you could finesse that by grinding away enough of the broomstick/dowel to clear the boss.
Likes For smontanaro:
