Squeaking noise from bottom bracket
Bikes: 1983 Univega Super Strada, 1986 Panasonic DX5000, 1984 Fuji Team 85 Univega Gran Turismo, 1984 Lotus Unique, 1987 Centurion Expert, 1987 Centurion Ironman Master,
Quoted: 677 Post(s)
Liked 460 Times
My 86 Panasonic DX 5000 has developed a squeaking noise that I believe
is coming from the bottom bracket. It doesn't make the noise when coasting
or when it's on a stand. Only when pressure is applied to the pedals. It almost
sounds like squeaking rubber. The person I bought it from earlier this year
told me he had serviced all the bearings
Very Senior Member
Bikes: Giant Quasar & Fuji Roubaix
Quoted: 413 Post(s)
Liked 343 Times
A quick search says that bike came with a sealed bottom bracket set and Shimano 600 EX crank set. Have you tried wiggling a pedal side to side and see if the crank arm has any play in it? I doubt if the person you bought it from serviced the bottom bracket, but hey, I've been wrong before.
Quoted: 677 Post(s)
Liked 460 Times
Could this cause a squeaking noise and could that noise only occur under load?
Guest
Quoted: 1346 Post(s)
Liked 3,270 Times
Take the pedals from another bike and put them on the bike that's squeaking. Remember that the left pedal is reverse threaded.
Likes For Rolla:
Quoted: 677 Post(s)
Liked 460 Times
Guest
Liked 3,270 Times
Pull the BB and inspect. You might just re-grease the threads and re-install, but if it's a cartridge unit, it's cheap and easy to replace.
Bikes: 2016 Fuji Tread, 1983 Trek 520
Quoted: 676 Post(s)
Liked 741 Times
Of course, if the noise goes away when you stand up out of the saddle and pedal, it's the saddle or clamp. It's amazing how that noise telegraphs to the BB.
Likes For andrewclaus:
Old fart
Quoted: 3588 Post(s)
Liked 3,400 Times
Noises like this are notoriously difficult to track down. It could be the bottom bracket or pedals, but also could be shoe cleats, saddle rails, even handlebars or even something else entirely. Change one thing at a time until you can isolate the cause.
Quoted: 677 Post(s)
Liked 460 Times
Quoted: 677 Post(s)
Liked 460 Times
Shouldn't it have a different fitting?
Very Senior Member
Quoted: 413 Post(s)
Liked 343 Times
No, they'll look the same and both will use square taper cranks. Rolla might have offered the best suggestion with removing the bracket, inspect it for play and resistance and put a little grease on the threads before you re-install. Sometimes that little bit of friction in the threads can cause a noise. Good luck
Bikes: Trek 730 (quad), 720 & 830, Bike Friday NWT, Brompton M36R & M6R, Dahon HAT060 & HT060, ...
Quoted: 840 Post(s)
Liked 336 Times
Usually, these are BB cups or arm bolts that are not tightened enough. The previous owner has not tightened them enough and you just follow the path, scared of overtightening.
Quoted: 677 Post(s)
Liked 460 Times
Quoted: 677 Post(s)
Liked 460 Times
All the ones I relubed before I tightened them just enough so there was no no play in the axle but they
still turn freely
Quoted: 677 Post(s)
Liked 460 Times
clean and regrease them.. The inside of the bottom bracket ,the axle and all
the bearings looked like new when cleaned up. Never had the inside of a
bottom bracket look so clean. Now I just have to regrease and put back together.
Likes For robertj298:
Guest
Liked 3,270 Times
Quoted: 840 Post(s)
Liked 336 Times
I think psychologically it is difficult to go to the other side, but of course it is principally possible. You begin to destroy the threads then and shards of metal begin to come off. Yes, it begins to be loose then too, but the usual owner doing maintenance would not go there. The way you can test where you are is to ride and listen to the squeaking, while carrying a wrench. Then you tighten a bit more and listen do the squeaking. If yes, you are likely on the right track. Presumably a chainring that was removed and not put back tightly enough could generate a squeaking too. In that case the squeaking would depend on the ring you were on. Note that that legs can generate far greater forces than hands can. What might seem tight for the hands, might not be such for the legs.
Quoted: 677 Post(s)
Liked 460 Times
I would have swore it was the bottom bracket. It only makes the squeak when pressure is applied to the pedal it lets up until
pressure is applied to the other pedal .I've probably serviced 10 bottom brackets before and have never had any issue. I changed
both pedals also.
Quoted: 677 Post(s)
Liked 460 Times
Problem solved. Of all the stupid things it was something simple. The rear wheel wasn't
locked in tight so when pressure was put on either pedal the wheel would move slightly
rubbing against either the brake or chain stay. It would move back when there was no
pressure. I feel so stupid lol
Quoted: 837 Post(s)
Liked 1,061 Times
