56 vs 54cm Specialized Diverge
Hello,
wondering if I should get a 56 or 54 cm specialized diverge. Can't test ride in my lbs right now, as due to covid they don't allow test-rides.
My height is 5'9.5
Inseam is 30.5
Armspan is 64.5 inches
I have short legs, short arms, and a long torso.
Any advice on sizing would be excellent.
My height is 5'9.5
Inseam is 30.5
Wanderer
With a long torso I'd recommend a 56cm but there are so many variables that are unknown. I have a 31" inseam and a longer torso and arms and a 56 fits me perfectly. But mine is a Cannondale. I have 1" of clearance from my top tube and it feels comfortable to ride.
Liked 2,971 Times
I'd go with the smaller size.
-Oh Hey!
-Oh Hey!
Likes For Troul:
Quoted: 1104 Post(s)
Liked 1,825 Times
You can make a small bike bigger but you can't make a big bike smaller. If it were me, I'd get the 54 and run a longer stem and get a tighter triangle/better standover in the deal.
Likes For nomadmax:
Likes For Outrider1:
Bikes: 2021 S-Works Turbo Creo SL, 2020 Specialized Roubaix Expert
Quoted: 762 Post(s)
Liked 4,035 Times
Yep, I’m 6’ and ride a 56 Diverge. 31” inseam. I run a 90mm stem. I’d vote 54.
I am 5'8.5 and have a 56cm bike that is just a little too big for me and although I can ride it, it never gets used. Go 54cm and use the bike more.
Quoted: 608 Post(s)
Liked 352 Times
Sorry to be the naysayer here but go to the Specialized site and fit generator and it will come up with 56 which is what I would put you on. When I hear 6' foot people on 56 I have to ask who do they make the 62 cm bikes for, 8' tall people?
Dirty Heathen
Quoted: 889 Post(s)
Liked 906 Times
Depends. You could probably ride either, depending on what you’re looking for. I am almost exactly the same height and inseam as the OP, and while I fit fine on a 54, I found it very short front-to-back, and surprisingly upright, more so than my XC bike. The 56 was better, although still higher than I was expecting.
The Diverge just wasn’t the bike I was looking for, I ended up on a 56cm Cannondale Synapse.
Hello,
My height is 5'9.5
Inseam is 30.5
My height is 5'9.5
Inseam is 30.5
Quoted: 1743 Post(s)
Liked 1,281 Times
In my youth I was 5' 10 1/2" with a 32.5" inseam. Down to 5' 9" but same inseam. I find a 54-55 is perfect. If my inseam was like yours I'd go no larger than a 54 and probably a 53. Be careful when buying a bike with a sloping TT. My CAAD 12 is a 53 but using virtual TT measurement it is actually a 55.
Quoted: 762 Post(s)
Liked 4,035 Times
I just did that. At 5’9” it comes back with 54. If you enter 5’10” it comes back 56. The OP should probably use their size calculator and enter the other measurements they ask for, not just height. I’d be curious to see which they recommend.
For The Fun of It
Bikes: Lynskey GR300, Lynskey Backroad, Litespeed T6, Lynskey MT29, Burley Duet
Quoted: 2135 Post(s)
Liked 1,647 Times
It is likely that both bikes can be adjusted to fit you just fine.
Likes For Paul Barnard:
Measurements for knee to floor was 18 inches and ankle to floor was 3 inches.
I also measured some more and inputted information into competitvecyclist calculator although i'm not sure I measured everything correctly, and it gave me these frame specs:
https://imgur.com/tG1OcY0
Quoted: 1248 Post(s)
Liked 1,323 Times
There is a tendency to ride smaller bikes as that's what the current pros ride. In days past seat posts only came in 180 cm lengths and road stems were horizontal to the ground. The typical MAMIL setup is a bike with a tall stack of spacers and a sharply angled stem rather than just buying a bike that is one size larger allowing a more stable ride and comfortable fit.
Likes For Atlas Shrugged:
Quoted: 762 Post(s)
Liked 4,035 Times
They actually recommended 52cm.
Bikes: 2014 Giant Defy 1, 1996 Trek 730
I am almost exactly your dimensions and am very comfortable on the 54. These bikes have very relaxed geometries and while there has been a lot of discussion of reach I would be concerned that on the 56 the stack would be too high and put you overly upright. The Future Shock is not a pile of spacers that allow you to lower the stem. My recommendation is go with the 54 and change to a longer stem if you think you need it.
Quoted: 1034 Post(s)
Liked 1,290 Times
Here is Specialized chart for the bike you are considering. You are on the cusp between 54 and 56.
Occam's Rotor
Quoted: 2366 Post(s)
Liked 2,331 Times
Hello,
My height is 5'9.5
Inseam is 30.5
My height is 5'9.5
Inseam is 30.5
I have very similar measurements (including armspan -- I just checked). I got a custom frame built, and it turned out to be almost identical to a 54cm Trek Domane. I know that isn't one you are looking at, but it might be a useful starting point.
This link, if it works correctly, should compare a 54cm Domane to the two sizes of Diverge you are considering:
https://geometrygeeks.bike/compare/t...arbon-2020-56/
I think you will find the reach too long with the 56, and the standover height too high.
Likes For Cyclist0108:
Bikes: 2019 Specialized Diverge, 2021 Cervelo Caledonia
Quoted: 258 Post(s)
Liked 378 Times
I am 6 feet tall and ride a 58cm Diverge. It's a great fit and very comfortable. Based on that, I'd think the 56 would be a better fit for you. But I'd also be reluctant to buy without trying it out first.
Liked 1,281 Times
Inseam not height is a better metric for proper fit.
Liked 1,281 Times
