Poles on my bike
Old 06-23-21, 07:55 AM
alo
Quoted: 529 Post(s)
Liked 255 Times in 185 Posts
Poles on my bike
Where I am, there are a lot of uncontrolled dogs, and a lot of people have been bitten by dogs. One way to keep dogs back, is to swing a stick at them. I decided it would be a good idea to have something I could use on my bike. So I clamped a PVC pipe to the chain stay, and rack. I put a longer thinner PVC pipe inside it. I could lift it out while cycling, and swing it at any dogs that came too close. Some time later, I went under a low tree, bent the pipe, which kinked, and it finished up shorter. I replaced it with a piece of bamboo.
I had previously carried two backpacks on my rack. They tend to lean over, and can fall off. With a pole on my bike, it was easy to secure two backpacks so they stay in place.
My aluminum rack broke. So I clamped a piece of bamboo to the side of it, and screwed the support to the bamboo, making it stronger than new. Later the other side of the rack broke. I used more bamboo to repair it and make it larger. My rack now has more bamboo than aluminum. The aluminum is broken in so many places it would fall apart if I removed the bamboo. The front of the rack is clamped around the seat post, allowing the rack to swing from side to side. Having pipe clamped to the side, reduced that. But PVC flexes, so I added another one on the other side, to reduce the swinging.
I now have a pole on each side. I can carry two backpack or more between the two poles, and one strap secures them. I can also carry two cartons of drinks or more between the tow poles, and one strap secures them. They make it really easy to secure high loads on the rack.
In the future I plan to replace the rack with a large strong rack. I plan to still have a pole each side, so it is easy to secure high loads on my rack.
If I ever ride long distances on busy roads, I can use a longer pole, and have a flag on top.
The best way to set up a bike depends on how you use it. Anyone wanting to load a rack high, consider a pole each side. This is light weight, and makes it easy to secure high loads on your rack. You could use broom handles, or aluminum tube, or anything else you want to use.
I prefer this to having something sticking out the sides, which can be an inconvenience in narrow spaces, either in traffic, or narrow trails.
alo is offline
Old 06-23-21, 08:27 AM
kahn
Quoted: 383 Post(s)
Liked 690 Times in 396 Posts
It wold be interesting to see a photograph of this setup.
kahn is offline
Likes For kahn:
Old 06-23-21, 08:33 AM
msu2001la
msu2001la's Avatar
Quoted: 1461 Post(s)
Liked 1,485 Times in 870 Posts
Wouldn't it be easier to just carry a collapsable baton? Or maybe some pepper spray?
msu2001la is offline
Likes For msu2001la:
Old 06-23-21, 08:36 AM
prj71
Quoted: 2975 Post(s)
Liked 1,182 Times in 771 Posts
I'm laughing at you real hard. Can you please post of pic of this nonsense?
prj71 is offline
Old 06-23-21, 08:37 AM
ofajen
Cheerfully low end
ofajen's Avatar
Quoted: 646 Post(s)
Liked 1,044 Times in 667 Posts
Back in the day, I used a frame mounted Silca pump mounted along the seat tube to deter dogs. Easy to reach while riding and a useful length.
Otto
ofajen is offline
Likes For ofajen:
Old 06-23-21, 08:39 AM
Outrider1
Outrider1's Avatar
Bikes: Trek Emonda ALR 5
Quoted: 159 Post(s)
Liked 302 Times in 140 Posts
I employ a similar setup for jousting.
Outrider1 is offline
Likes For Outrider1:
Old 06-23-21, 08:42 AM
10 Wheels
Galveston County Texas
10 Wheels's Avatar
Bikes: 02 GTO, 2011 Magnum
Quoted: 1350 Post(s)
Liked 1,245 Times in 623 Posts
I use a Small Marine Air Horn to fend off biting dogs. Has worked for 60,000 miles.
Keep it on the Right
Fred "The Real Fred"
10 Wheels is offline
Likes For 10 Wheels:
Old 06-23-21, 08:48 AM
rumrunn6
rumrunn6's Avatar
Quoted: 5224 Post(s)
Liked 3,581 Times in 2,342 Posts
Originally Posted by alo
clamped a PVC pipe to the chain stay, and put a longer thinner PVC pipe inside it
I agree w/ Kahn "It would be interesting to see a photograph of this setup" for me because I like to carry a camera stick & I want to find a better way to do it. right now it rides on my rear rack, collapsed or partially collapsed. I can reach around while I'm riding to get it, but I have to stop to collapse it & put it back on the rack. sometimes I carry it across the front bars but that's not ideal. I know there have been threads about carrying fishing poles on bikes, that might interest you (I found a cpl see below). I once carried one on my top tub w/ velcro straps but it couldn't be retrieved while riding
https://www.bikeforums.net/fifty-plu...hing-bike.html
https://www.bikeforums.net/recreatio...hing-pole.html
https://www.bikeforums.net/general-c...reel-bike.html
Finished building the "Fishing Bike" - Bike Forums
https://www.bikeforums.net/general-c...any-ideas.html
https://www.bikeforums.net/touring/9...hing-rods.html
rumrunn6 is offline
Old 06-23-21, 08:54 AM
Iride01
Iride01's Avatar
Quoted: 6193 Post(s)
Liked 4,809 Times in 3,317 Posts
I've yet to find a dog that will bite me. They love it when you flee or look scared. They seem to become meek as soon as you stand your ground and look big.
Though I'll suppose that maybe I haven't encountered that one dog that will bite me.
Seems like pepper spray will be the better choice, then they can go home and rub it on their owner.
Iride01 is offline
Old 06-23-21, 08:55 AM
livedarklions
Tragically Ignorant
livedarklions's Avatar
Quoted: 8186 Post(s)
Liked 9,098 Times in 5,054 Posts
I used to ride with a Pole on my rear rack, and he was quite adept at scaring off dogs. The Swede? Not so much.
livedarklions is offline
Likes For livedarklions:
Old 06-23-21, 08:57 AM
Quoted: 18415 Post(s)
Liked 15,542 Times in 7,329 Posts
Don't hold your breath. And any pic needs to be a "proof-of-life" pic.
Likes For indyfabz:
Old 06-23-21, 08:59 AM
alo
Quoted: 529 Post(s)
Here is one picture. It has gone through a number of remodels. When I started, the pipe was longer. This is after going under a tree and breaking it off. Since then I replaced it with bamboo. Since them my rack is wider with more bamboo than aluminum. Since then I have one each side. I plan to fit a new rack in the future, but maybe not for some time.
alo is offline
Letts are more effective.
Likes For indyfabz:
Old 06-23-21, 09:00 AM
livedarklions
Tragically Ignorant
So basically, you've constructed a rack that looks like a prop from Gilligan's Island?
Old 06-23-21, 09:01 AM
VegasTriker
Quoted: 523 Post(s)
Liked 229 Times in 181 Posts
This never ends well and almost always gets locked fairly quickly as it degenerates into a pissing match between dog lovers and some who do not love dogs much. In decades of riding I have been bitten only once and the confrontation with the owner was far more cantankerous than with the dog. It ended up with calling the county sheriff for assistance.
My last memorable encounter with a dog was to have it jump into my lap and lick my face, much to the dismay of the owner. They can do that when you ride a trike. Luckily it was s small dog!
VegasTriker is offline
Likes For VegasTriker:
Old 06-23-21, 09:02 AM
livedarklions
Tragically Ignorant
Sorry, but that has "this isn't going to end well" written all over it.
Old 06-23-21, 09:04 AM
alo
Quoted: 529 Post(s)
This started out for dogs, and ended up being a good way to secure a high load on the rack.
alo is offline
Old 06-23-21, 09:06 AM
livedarklions
Tragically Ignorant
Frankly, I think the OP is running a bigger risk with that monstrosity on his bike just begging to fail than any risk a dog attack could bring.
Old 06-23-21, 09:07 AM
prj71
Why don't you just get a new bike rack and carry some mace with you?
prj71 is offline
Old 06-23-21, 09:08 AM
livedarklions
Tragically Ignorant
Are you familiar with the expression "plumber's nightmare"?
Old 06-23-21, 09:13 AM
Rick
Quoted: 624 Post(s)
Liked 396 Times in 274 Posts
I rode with a touring group in Florida and when a dog took chase it was usually the girls they went after. One morning A dog went after one of the female riders and I came up behind the dog, grabbed his tail and raised him up some then released him. At one time I had a cattle prod attached to the top tube of my Tandem. Most of the time being stern is enough so a dog will back off.
Rick is offline
Old 06-23-21, 09:15 AM
woodcraft
woodcraft's Avatar
Quoted: 1814 Post(s)
Liked 923 Times in 569 Posts
Can you deploy the pole while riding? Have you warded off any dogs with it yet?
Bit of a samurai vibe, which I like.
woodcraft is offline
Old 06-23-21, 10:26 AM
msu2001la
msu2001la's Avatar
Seriously guys, you can get a collapsible baton for less than $20. Carry it in a a holster and live out your ninja samurai fantasy whenever you are attacked by beast or man.
https://www.amazon.com/Halafs-Expand...12954170&psc=1
Old 06-23-21, 10:49 AM
blacknbluebikes
blacknbluebikes's Avatar
Bikes: two blacks, a blue and a white.
Quoted: 445 Post(s)
Liked 847 Times in 410 Posts
I throw kittens. Works great.
blacknbluebikes is offline
Likes For blacknbluebikes:
Old 06-23-21, 10:52 AM
livedarklions
Tragically Ignorant
I don't vouch for the accuracy of this list, but you might want to consult this before you do that:
State Baton Laws - Weapon Laws for Dummies
