The ultimate 27" tire reference thread!
#276
Bikes: A Blue One and 2 Green One's, then there's the Yellow one. And oh, yeah, a Black One. Did I mention the Red One?
Quoted: 75 Post(s)
Liked 195 Times
I've got two bikes that still have 27" inches on them and I noticed the short supply and the size being squeezed out a few years ago. I bought four pairs, all different and haven't gone through set yet.
Schwalbe puncture resistant w/ reflective strip - About 300 miles on them and all the center flashing isn't gone yet. The compound is very soft to the touch but they wear very slowly
Pasela Pro-tite - in the wings
Pasela regulars - in the wings
Michelin World Tour - About 500 miles on them and still look newish. These won't inflate past 65lbs on non hooked rims without spitting off the rim. Probably the rims fault though, and me for matching them up.
Im not very demanding of my tires. I look for the smoothest path always. The streets in Tucson are another story but I avoid most of the bigger holes.
I found the Michelins in England and the others here in the USA on Ebay. I think I bought them all in 2019.
By the looks of it, there will be a couple pairs of Paselas at my Estate Sale.... stand by.....
#277
Western Bikeworks, www.westernbikeworks.com, has Schwalbe HS159 27 X 1-1/4 gumwalls at $19.99 ($16.99 each when I put 2 into the basket). With puncture protection and real tread they look like great commuter or pathway tires.
Likes For tommymc:
#278
#279
mycocyclist
Quoted: 910 Post(s)
Liked 819 Times
Happy Wednesday the 13th!
SwiftTire's Sand Canyon 27 x 1 3/8 Tan Wall are back in stock!
(Price has inflated 20%, to $36, but where else are you going to find a 350 g folding Kevlar beaded 27" tire with a tan wall?
I ordered a pair already.
(I have been refreshing their page for years, literally years, waiting for these to present and an hour or so ago they did. I have no personal experience with them, but they are attractive on paper? I somehow don't think they will be in stock for very long?))
"Description
The original SwiftTire! Now in Tan for a more vintage feel.
- 27 x 1 3/8
- 66 TPI
- 350 grams
- 35-80 PSI
- Tan sidewalls
- Folding Kevlar bead
- 33 mm width on common 630 rims
- Made in Japan by Panaracer exclusively for us
Last edited by machinist42; 10-13-21 at 11:05 AM. Reason: Added Picture, because it did happen.
Likes For machinist42:
#280
Ride, Wrench, Swap, Race
Quoted: 1565 Post(s)
Liked 1,296 Times
I suspect these are based on the same casing size as the 1-1/4 Pasela, which measures huge compared to other 1-1/4" tires.
The World Tour is of course similarly huge (though is heavy, sluggish and stiff at least compared to most skin-side tires).
I get good tread mileage from Panaracer tires of this type, Pasela et al.
#281
Bikes: 68 SS, 72 Fuji Finest, 72 PX-10, 77 Pana Pro 7000, 84 Pinnarello Treviso NR, 84 Trek 520, 88 Project KOM, 90 Trek 750, 91 Trek 930
Quoted: 184 Post(s)
Liked 204 Times
Last new bike 1991
Last new bike 1991
#282
FalconLvr
Bikes: 62 Falcon, 58 Raleigh Lenton Gran Prix, 74 Raleigh Pro, 75 Raleigh Int, 75 Raleigh Comp, 76 Colnago Super, 75 Crescent, 80 Peugeot PX10, plus others too numerous to mention!
Quoted: 51 Post(s)
Liked 112 Times
Western bikeworks now only has 3 gumwall schwalbes left in stock! Hopefully they will get more in,,,
#283
Liked 1,296 Times
Blueskycycling has HS159's in white or gum for $20 today. Plus tax/shipping.
#284
Quoted: 2338 Post(s)
Liked 2,824 Times
#285
I just ordered a pair of these Pasela Panaracer Urban Max 27" tires. Hope they roll as fast as they claim.
https://www.thebikesmiths.com/collec...panaracer-3319
#286
Liked 1,296 Times
It's a ruggedized tire for urban use, so there will be some layers of added material under the tread cap, but Paselas typically leave the sidewalls thin, to flex easier.
#289
Bikes: 2017 Sage Skyline, 2015 Co-Motion Periscope Tandem, 2012 Soma Smoothie, 2006 Kona Jake, 1986 Miyata Nine Twelve, 1977 Peugeot UO18c, 1977 Peugeot PRN10, 1974 Allegro Schweitzermeister Model 76, 1972 Hugo Rickert Spezial
Quoted: 114 Post(s)
Liked 594 Times
I buy regularly from Bike Tires Direct and they are a good and long established online vendor. They have a good rewards program, too for repeat customers.
Likes For Sactown_Albert:
#290
Bikes: Rivendell Sam Hillborne, Peugeot UO8, Trek 820, Motobecane Grand Record + projects
I have a set of the Swift Tires ( black wall ). They measure 30mm at 45psi on VERY narrow rims. That works out to just a bit under 1 1/4" . The O.D. on these rims is 20mm sooo maybe 18mm I.D. ? The cheap 1 1/4 tires I took off were measuring around 27mm. I'm sure they would be plumper on normal rims.
I am very happy with them. Smooth, fast, and enough tread to last a while. Definite step up from the Chin Shens they replaced.
#291
Liked 1,296 Times
Back in the 70's, it wasn't possible to make a wider rim without some serious weight gain. Later design development allowed deeper and wider rims extruded with much thinner walls and of stronger alloys like Maxtal, and which defines today's state-of-the-art alloy rims.
30mm (as mounted) tires on such narrow rims invites the possibility of the tube suffering stretching stress concentration as the pressure tries to push the tube down between the tire beads after the tube has already firmed up and started to pin the tube against the inside of the tire. The rubber reinforcing pad surrounding the valve stem, in particular, may not fully descend to the floor of the rim and so may cause tube wall ruptures to either side of said rubber reinforcement (look for tell-tale stretch marks to either side of the rubber valve stem reinforcement).
It is helpful with such combinations of wide tires on narrow rims to tug on the valve stem as the tire is being inflated past 5psi, to prevent such tube ruptures.
It is also helpful to use only tubes having generous width relative to the tire width.
#292
There's going to be about 6-7mm difference between the outer and inner width dimensions, so your 20mm wide rims will probably measure i13mm, which is very near the lower limit of what is possible to mount tires on and have the tube and valve stem fill the space between the rim sidewalls and tire beads.
I'll un-mount the tires and check it out. They are presta valves ( there isn't anywhere near enough room for schrader )
I bought this bike as a frame and fork project ( a Raleigh Super Course ) and I wanted aluminum rims for better braking, these were all I could find locally at the time.
#293
Bikes: 1964 Huffy Sportsman, 1972 Fuji Newest, 1973 Schwinn Super Sport (3), 1982 Trek 412, 1983 Trek 700, 1989 Miyata 1000LT, 1991 Bianchi Boardwalk, plus others
Quoted: 583 Post(s)
Liked 699 Times
In praise of the Kendas
I’m just a low performance biker in the Midwest, but the cheap Kenda K35s do have a place for me. They were what I have used on my old 73 Super Sport for decades. I got a bit more involved in the next rung up of vintage bikes in the last 5-10 years. That put me onto some Panaracer Paselas and Gravel Kings. Nothing pricey, but a notch up.
Anyhow, after updating my old Schwinn including a new crank spider so I could change the front chainrings, I also updated to Paselas. They are the standard 1 1/4” ones and not Pro Tite with the added flat protection. They really transformed the feel and rode nicely except….. City riding here in the Midwest with the poor pavement and patches and cracks was terrible on that bike. I think the frame is quite stiff and has fairly sporty angles. I found myself watching for the tiniest road imperfections.
Back to the Kendas on my SS upright conversion and my 73 stocker and city riding on poor roads is quite tolerable. The Kendas on an upright conversion of a 72 Schwinn Continental was pleasing too. On that bike, one could practically ignore the road surface. Today I did a 15 mile shakedown ride with half being on so so roads on my recent Peugeot UO14 acquisition. The bike had a pleasant neutral feel with the Kendas and the tires and bike complemented each other for the conditions.
Obviously nicer tires for nicer roads equal nicer feel, but there is something to be said for a decent ride over poorer pavement. Other thicker tires would certainly give similar results, but this is my experience. All areas of the country aren’t blessed with fine pavement, especially in the heavier traveled cities.
#294
Quoted: 1950 Post(s)
Liked 2,011 Times
I just mounted a Swift Tire Sand Canyon on a Rigida 13-20 for my Motobecane and inflated to 55 psi, it measures 1 1/8. I wonder what the OG Michelin Elan measured on these rims.
#295
working on my sandal tan
Quoted: 3871 Post(s)
Liked 2,568 Times
In fairness to the tires, those are really skinny rims. Panaracer Pasela 27"x1-1/4" tires measure an honest-to-goodness 32mm on the original wide steel rims on my wife's Schwinn Suburban. I bet your tires would measure closer to the labelling on wider rims, too!
#296
Liked 2,011 Times
edit: at 60 psi or less and my 155 lbs. on these rims results in a less than ideal cross section. At 80 psi, they are still very comfortable and more round.
Likes For Classtime:
#299
Quoted: 1106 Post(s)
Liked 1,328 Times
Black 1 1/4" Paselas available in Canada
My LBS just checked with their "supplier in Vancouver", "50 in stock there", and the price was reasonable so I'm in for four. Their store interface is the same as loads of other online LBS presences, I'd bet the same supplier get to other LBSs in the Great White North.
Only 46 now...
Only 46 now...
