Seeking recommendations a trailer hitch bike rack
Old 07-01-08, 10:43 PM
beowulf7
World's Most Modest Man
beowulf7's Avatar
Seeking recommendations for a trailer hitch bike rack
I'm looking for a trailer hitch bike rack that will slip into my soon-to-arrive 1.25" Class I receiver hitch for my hatchback. I'll most likely going to buy a Trek 7.3 FX hybrid bike. A local bike store sells a couple Saris trailer bike racks (Thelma and T-Rax). I know Saris is a big name, but I'm not sure if there are other better value manufacturers.
My requirements, in arbitrary order, are as follows:
- Capacity of 2 bikes.
- Easy to install and remove the bike rack to/from the receiver hitch.
- Easy to put and remove bike on/off bike rack.
- Reasonably priced (< $200).
- Easy to secure bike rack and bike with a lock.
- Won't damage the bike or paint job (I'm willing to use a washcloth to protect the cables from the frame).
- The bike rack won't break through normal wear-and-tear of installing and removing from receiver hitch.
I also browsed the selection of hitch mount racks at performancebike.com, but I'm not familiar w/ those brands.
Any help and advice would be appreciated. TIA.
Edit: Here's an update.
beowulf7 is offline
Old 07-01-08, 10:51 PM
bigtruck
I use
https://www.drawtite-hitches.com/prod...Carrier,59403#
Works fantastic, Very easy to hitch to car and load your bikes
bigtruck is offline
Old 07-01-08, 11:00 PM
beowulf7
beowulf7's Avatar
Originally Posted by bigtruck
I use
Thanks for the link and the recommendation. I should clarify (and I'll update my original post) that my receiver hitch is a 1.25" Class 1 hitch. I bought it from U-Haul and will have it installed by them in a couple weeks.
beowulf7 is offline
Old 07-02-08, 01:03 AM
MBurke
Quoted: 19 Post(s)
Do a search on Bike Racks. There is alot of info on them. I use one or these and love it.
https://www.sportrack.com/a30901
MBurke is offline
Old 07-02-08, 02:49 AM
martianone
Bikes: recumbent & upright
Quoted: 73 Post(s)
Liked 40 Times in 31 Posts
a thule T-2 works well for two bikes-
easy on and off,
bikes sit on their wheels so no damage to frame/paint,
probably the only downside is the bikes get some road spray
in the rain (all hitch mounted racks have this)- however i think
with the T-2 riding a little lower the bikes might get more than
with a higher hitch mount.
martianone is offline
Old 07-02-08, 09:13 AM
beowulf7
beowulf7's Avatar
Thanks, that looks pretty good and is reasonably priced. I found a video of that bike rack. I see it will still touch the bike's frame, so a washcloth would still have to be used. (No big deal.) At under $200, it's reasonably priced.
easy on and off,
Wow, that's like the deluxe of bike racks! The reviews are great but at almost $400, it costs almost as a new bike. I'll keep it in mind, thanks.
beowulf7 is offline
Old 08-18-08, 03:28 PM
beowulf7
beowulf7's Avatar
Here's a quick update. I recently bought the XPORT Flatbed 2-Bike Hitch Rack from PB and assembled it last weekend. I'm looking for a lock for it and read in one of the reviews to get the SportRack - A30901Lhp - Hitch Pin Bolt w/ Lock. What is your opinion of it? I also need to get a 3/4" wrench to tighten the hitch bolt. The largest wrench I have is 5/8". D'oh! Yeah, I can probably use pliers to hand-tighten it. That's what I did for another bolt that requires a 17mm wrench. (Why the manufacturer decided to mix US and metric sizes for their 2 bolts is beyond my comprehension. )
beowulf7 is offline
Old 08-18-08, 03:34 PM
avmanansala
avmanansala's Avatar
Bikes: Cannondale Road Warrior
I use a Yakima King Pin 4 on my 1.125" rack on my Honda Accord. It works for me. I think this is now discontinued and the replacement models are nice.
https://www.yakima.com/racks/bike-rac...bledown-2.aspx
https://www.yakima.com/racks/bike-rac...4-(1-1-4).aspx
If you have two bikes, google Yakima Kingpin 2.
avmanansala is offline
Old 08-26-08, 06:44 AM
jbpence
Bikes: 2009 Custom TI Frame Road Bike, all 2007 Campy Record, Campy Euros Wheelset
saris thelma = not cheap, but I love it. doesn't clamp down on the carbon fiber top tube, holds the front wheel securely. very nice.
2009 Custom TI Frame touring Bike. S&S couplers, XTR Drivetrain. LOW granny.
2009 Performance Bicycles TI (by Lynsky) road frame, 7900 DA, 7950 DA Compact Crank, Light Niobium Rim Wheels
jbpence is offline
Old 08-26-08, 06:59 AM
Javan
More biking, less flying.
Bikes: Diamondback Citi, GT Timberline, Roady?
Liked 2 Times in 1 Post
I have a Thule Hitching Post that can carry 4 bikes, but have only carried 2 at one time. Works well and was discounted to under $100.
Javan is offline
Old 08-26-08, 07:54 AM
dalmore
Neat - w/ ice on the side
dalmore's Avatar
Bikes: 2005 Dahon Speed TR, 2006 Dahon Mu SL, 2000 GT XiZang, 1999ish Rock Lobster, 2007 Dean Animas CTI
I have a very similar Swagman carrier. Absolutely love it. It's light, easy to use, folds up quickly, stores in a small space and holds the bike securely when in use.
For locking it, you need to lock two things - the rack to the car and the bike to the rack. No experience here with the particular locking hitch pin you noted, but I would avoid it because of the wrench. That mechanism is to stop the rack from rattling. You can use something like this locking hitch pin and a stabilizer like this. I use that exact combo. No wrench required.
For locking the bike to the rack, I'll bet these would work even though they say they are for the Swagman not an Xport. You can also use a chain or cable but I'd advise against that while you are driving. Just put the chain or cable on when you stop or risk much scratching of the bike frame. Word of caution, that rack can be disassembled pretty easily so anything that locks the bike to the rack is not going to stand up in a risky neighborhood for a long time.
Current favorite bumper sticker: Wag more. Bark less.
Change you can believe in - Bigfoot Nessie 08
dalmore is offline
Old 08-26-08, 12:38 PM
beowulf7
beowulf7's Avatar
Thanks for that excellent info. Much appreciated! That'd be great if I didn't have to mess w/ a 3/4" wrench to secure the bolt to the 1.25" receiver hitch. Do you have a picture of your bike rack using that hitch stabilizer and the Nashbar hitch rack hitch pin?
I was planning on just locking my bike to the bike rack w/ my bike lock cable. I wonder how that Swagman locking knobs would work w/ my Xport bike rack. Thanks again for the recommendations.
beowulf7 is offline
Old 08-26-08, 02:40 PM
AGuyNamedSteve
Although you've already got your rack, I was looking for something similar. I have a Ford Ranger with a 2" receiver, while my wife has a 2006 Toyota Camry Solara 2dr coupe. We found the best deal on a hitch from Uhaul also (I moved their sticker up to the top of the hitch away from view), which has a 1 1/4" receiver. So I wanted something that could be switched between the two vehicles.
The Thule Roadway 2-bike 912 was just what we needed. I also got their locking hitch pin and a cable lock to keep the bikes on the hitch and the hitch on the truck/car. We took a 150 mile drive in her car with them mounted with no issues whatsoever. Most of the time, it's mounted to my truck though. Here's a photo just before heading up the mountain pass for our canyon ride:
AGuyNamedSteve is offline
Old 08-27-08, 12:45 PM
beowulf7
beowulf7's Avatar
^ That looks good, Steve. Thanks for posting the pic.
beowulf7 is offline
Old 08-29-08, 05:36 AM
dalmore
dalmore's Avatar
Here you go. I thought I snapped one with the bike still on the rack but alas - it wasn't there when I went to retrieve it. Phone photos so no contest winning quality but I think it shows what you want to see.
File Type: jpg
File Type: jpg
dalmore is offline
Old 08-29-08, 10:55 AM
beowulf7
beowulf7's Avatar
Thanks, I appreciate it! So that stabilizer works in tandem with the existing receiver hitch collar. When I just hand tightened the bolt, I noticed that the bike rack was still a little wobbly or jiggly, but I figured it was b/c I didn't wrench-tighten that bolt. That hitch stabilizer would probably do the trick.
beowulf7 is offline
Old 08-29-08, 12:10 PM
BassClef
Great - I just got the same rack at PB - can't beat it for $140 .
I was thinking about getting a hitch lock, but even if you lock it at the hitch, someone can remove two 17 mm bolts holding the hitch bar to the rack. Is there a solution for that?
BassClef is offline
Old 08-29-08, 10:20 PM
beowulf7
beowulf7's Avatar
I was also thinking about that 17mm bolt that I tightened as part of the assembly process. I don't plan to keep the bike rack attached to my car's receiver hitch permanently. But I'd still be paranoid about it. Otherwise, I might just forgo the idea of getting a lock and keep a 3/4" socket wrench in the car so that I can remove and reinstall the bike rack as needed, storing it in my car's hatch while I'm not there.
beowulf7 is offline
Old 11-24-08, 11:03 AM
PimpinD
Bikes: Gary Fisher Hifi Deluxe
Depends on what style you want...
If you have nice bikes are dont want them to get damaged check out Thules T2 system it is one of the most secure / stable / and safe racks out there...
if you are looking for save money, and dont mind some paint scratchs on the bikes check out the Sette 3 bike hitch rack from price point, it is like $50 and works.
PimpinD is offline
Old 11-24-08, 11:27 AM
AndrewP
Bikes: Peugeot Hybrid, Minelli Hybrid
https://www.mec.ca/Products/product_d...=1227547530878
AndrewP is offline
Old 05-25-09, 10:20 PM
beowulf7
beowulf7's Avatar
I'm not sure what happened to my previous post. Anyway, I wrote that I'm happy w/ the XPORT 2-bike rack I bought last year. I just want to find a better way to secure it (i.e., w/ a lock). I appreciate dalmore's input but am looking for other suggestions that would definitely work w/ my bike rack and a 1-1/4" receiver. How about something like this? I assume the diamater of the hole is 1/2" and not 5/8" for my bike rack's bolt.
beowulf7 is offline
Old 05-26-09, 02:25 PM
MAK
Bikes: Yes, I have bikes.
Quoted: 276 Post(s)
Liked 106 Times in 65 Posts
I have the Performance XPort 2 bike tray hitch rack and use the dual hitch and bike locks below. I love it. I have my bike racked before some riders with roof racks have their front wheels off and leaning on their cars. I also leave it on the car 24/7. To beowulf7...The anti rattle comes from tightening the hitch bar wich is a screw on so what you're asking about is unnecessary.
You'll still need a 15mm wrench to tighten up the screw hitch from time to time but it's no big deal.
https://www.amazon.com/SportRack-A320...sg_ai_-2_5_tit
MAK is offline
Old 05-27-09, 12:50 AM
beowulf7
beowulf7's Avatar
Thanks, MAK. However, I'm a little concerned about the 3/5 rating on that Amazon review.
beowulf7 is offline
Old 11-03-10, 02:54 PM
PaulRivers
Quoted: 539 Post(s)
Liked 44 Times in 38 Posts
Man...this is why it sucks when people link to stuff. I'm really curious what the stabilizer is, but the link doesn't lead to anything but the "I don't know what that means so I'll send you to the front page" front page of those sites. :-(
PaulRivers is offline
Old 11-03-10, 04:20 PM
gunner65
gunner65's Avatar
Bikes: Salsa Casseroll for Street and Airborne Hobgoblin for dirt
You can get these on ebay for like $59 shipped.
https://cgi.ebay.com/NEW-1-1-4-2-2-BI...item2a0b6629a5
gunner65 is offline
