Stuck Steel 1938 Stem
1938 Stuck Bianchi Steel Stem
I recently bought a 1938 Bianchi frame. It came with a stuck steel stem (pictured), which I think may be a Cinelli. It appears to be original. The stem is already without the screw, and the conical nut is free inside the fork steerer, at the bottom.
I tried to remove the stem, after overnight soaking with vinegar, and after that with WD40. I searched the forums but all the posts I found are about stuck aluminum stems.
Any ideias about removing this steel stem, without major damage to stem or fork ? Thanks!
Quoted: 1088 Post(s)
Liked 1,205 Times
I've seen a lot of discussion in the past noting acetone + automatic transmission fluid as a homemade penetrating oil. Before trying it, search Google for "acetone atf bikeforums" and you'll see a lot of advice from folks who have done it before. Unfortunately, if destroying neither the frame nor the stem is an option, you'll need to be very patient.
I've personally had good luck with PB Blaster and Liquid Wrench, and I also see Kroil recommended often.
Likes For noobinsf:
Quoted: 3015 Post(s)
Liked 3,802 Times
Steel to steel stuck is simple rust. Dip the front end in Evaporust or a solution of oxalic acid for a day or two. Should do the job.
Also, the shape of the stem and that it is on a Bianchi says Ambrosio, not Cinelli.
Quoted: 1143 Post(s)
Liked 1,740 Times
Heres my best. Soak as much PB Blaster as you can and use a big vise. I don't know if you have a bar or clamps to get a better grip on the stem.
True the stem is alloy but it's still the same procedures.
Likes For Mr. 66:
Team Beer
Bikes: Too Many
Quoted: 114 Post(s)
Liked 159 Times
I agree with this approach with a small caveat. What material is the headset made of? If it's alu, I might be cautious of the oxalic acid for a long period of time.
I'm not one for fawning over bicycles, but I do believe that our bikes communicate with us, and what this bike is saying is, "You're an idiot." BikeSnobNYC
Likes For Cynikal:
Liked 3,802 Times
If the headset is aluminum, it is not original to the bike. It could be sacrificed, a decision to be made.
Likes For dantonvb:
Also, get a rubber mallet or dead-blow hammer to help preserve old parts from damage whilst whacking on them.
Likes For etherhuffer:
Team Beer
Bikes: Too Many
Quoted: 114 Post(s)
Liked 159 Times
Then OA is going to be your friend.
Likes For Cynikal:
Bikes: A few too many
Quoted: 1364 Post(s)
Liked 2,181 Times
These approaches have ALWAYS worked for me.....WD40 in my estimation is not for use on heavily rusted part....it may also seem counter intuitive, but tapping/hitting down on the part a few times will often help dislodge the parts and allow for better penetration of the mixture.
I have never used the mix of acetone and T.O. but other have had success with it so if you like mixing your own brew, give it a try.
After that O.A. will remove the rest of the rust and you will need less of it.
Let us know how it turns out.
Best, Ben
Voltaire
Voltaire
Likes For xiaoman1:
Quoted: 4511 Post(s)
Liked 6,382 Times
@dantonvb
OA and HUGE amounts of patience, then a lot more, maybe several mountains more.
A large amount of elbow grease will also likely be on the agenda.
Glad I'm not the OP and very jealous all at the same time, what a fantastic challenge to have.
Likes For merziac:
Liked 6,382 Times
Here is another approach. I have a compressor and an air hammer. Too violent to use on bike parts per se. The Eastwood video shows that vibratory action really helps. Cool tool for screw removal
On stuck seat posts or stems, again you could pad or protect the part with a block of wood or similar and use an air hammer to light buzz the part. I had a stuck brake disc on my truck, it was rusted onto the hub. I put a block of wood on the disc and then air hammered the wood and popped off the disc.
Partially Sane.
Bikes: Soma Saga, pre-disc
Quoted: 972 Post(s)
Liked 643 Times
What? You post about a 1938 Bianchi, but won't take a pic of the whole frame for us? 😋😁 Sorry, someone had to say it. 😉
I agree with the soaking everyone recomends, but I'll give you a different approach, for holding the fork still. Just get a large piece of PVC pipe, or maybe wood, to sit the forks over, by straddling the 2 legs over the pipe or wood. If you get a good long section, you can brace it, like against a wall or something. You'll get way better leverage, if trying to twist it. 👍
Likes For stardognine:
Quoted: 566 Post(s)
Liked 1,050 Times
I’m in the Evaporust camp. Tip fork upside down, stuff with rag and douse it with Evaporust. Add Evaporust as necessary. A plastic mallet and a strong wood dowel are your friends.
Likes For RustyJames:
Liked 3,802 Times
Lovey bike. Good luck with the project.
Liked 2,181 Times
ok, then try this and build a "tank" so you don't have to fill up a kiddie pool. Information courtesy of
jonwvara ...there may be other ways to immerse the frame that will minimize material....
Best, Ben
https://www.bikeforums.net/classic-v...evaporust.html
Best, Ben
Voltaire
Voltaire
Likes For xiaoman1:
Quoted: 2588 Post(s)
Liked 4,824 Times
This might sound dumb, but I haven't seen anyone (including the OP) mention this yet: have you tried unscrewing the top nut on the headset to facilitate stem removal?
If so and it's still stuck, I agree that OA or similar is the route to success.
Cool project - good luck!
DD
DD
Likes For Drillium Dude:
Bikes: A Blue One and 2 Green One's, then there's the Yellow one. And oh, yeah, a Black One. Did I mention the Red One?
Quoted: 75 Post(s)
Liked 195 Times
Water is something that the old bike guys do to un-freeze entire bikes. Horse trough full of water, come back in a week.
Probably not viable here though. The OA and patience deal is probably the best bet.
This would be a VERY unusual Bianchi using box pins and fishtail lugs. Perhaps it merely has a few French parts on it. Considering the frames attributes I would tend to agree with the downtube transfer. It looks like an English frame. Considering the drop-outs, it would be a higher level for sure, but English by its construction. Four cup headsets are also usually Clip stem types but the clip can be easily replaced with a standard top. It looks like that is what has been done by the ring in the middle.
No doubt, a nice frame. Once you get it apart, considering the rounded cup flare of the head, one the head cups will probably be stamped, I'd guess Brown & Wilkes.
Considering the fork also has a fishtail crown I'd think it may be original to the frame. Then, Considering that it may actually be a Clip style head steerer tube, that means there may be a "T" cut into the threaded area of the steerer tube to be compressed by the now gone head clip to hold the stem. This "T" area is another bugaboo that will hold up the removal if it is corroded bad.
As mentioned above by Drillium dude, unscrew the headset completely. Do it over a catch pan, there are 60 loose balls in the headset. Then take the stems long bolt that has been removed and re install it several threads and make sure the wedge or barrel is knocked down by smacking the top of the bolt head. Once the headset is all loose and the wedge/barrel is out of the way, things will be easier to asses if you still can't get it out.
Quoted: 1639 Post(s)
Liked 829 Times
I always wondered why most bikes from the 1930's and earlier do not seem to retain their finishes. They always look like they were pulled out from a shipwreck, finish-wise. Was paint and chrome just that bad back then? Or where there grand old bikes just left out on the porch for many years and negldcted.
72 Line Seeker
83 Davidson Signature
84 Peugeot PSV
84 Peugeot PY10FC
84 Gitane Tour de France.
85 Vitus Plus Carbone 7
86 ALAN Record Carbonio
86 Medici Aerodynamic (Project)
88 Pinarello Montello
89 Bottecchia Professional Chorus SL
95 Trek 5500 OCLV (Project)
72 Line Seeker
84 Peugeot PSV
84 Peugeot PY10FC
DD
DD
Liked 3,802 Times
