Does dirt collect right around anyone else's valve stems?
Sunshine
Quoted: 10964 Post(s)
Liked 7,490 Times
This started a few weeks ago and happens on every ride. No air is noticably escaping during or between rides, and the valves are tight. I now clean the rims after each ride since it's intrigued me.
No big deal, just an odd thing to suddenly happen and continue.
Perhaps there is some residual sealant or water in your rim that is seeping out around your valve stem, making the rim wet in that area.
Likes For mihlbach:
Randomhead
Liked 3,698 Times
Are you running tubeless?
Quoted: 1218 Post(s)
Liked 298 Times
No different than the rear of a vehicle that sees gravel/dirt roads.
It's air turbulence, combined with lower air pressure surrounding valve stem. sucks in dust, allows it to settle.
You could glue a fake valve stem onto the other side 180⁰, and it would do same thing.
Likes For Metieval:
Sunshine
Liked 7,490 Times
Yes, tubeless.
I haven't noticed it in the few years that I've run tubeless, but maybe I was just unaware?
I assume it's the slightest bit of air escaping somehow, even though I haven't been able to measure the difference with my pump.
Oh well.
Oh well.
Likes For mstateglfr:
Likes For veloz:
Quoted: 1461 Post(s)
Liked 1,485 Times
I've never noticed this happening before on my bikes. It seems like you'd see similar smaller patches of dirt around each spoke nipple if air flow was causing this. It doesn't seem like any air turbulence caused by the valve stem would play a role.
Is it doing this on both wheels? I'd suspect some tiny amount of sealant is escaping and collecting dirt. It's also possible that old sealant wasn't completely cleaned off and some residue on the wheel is still attracting dirt.
Quoted: 2604 Post(s)
Liked 1,933 Times
I haven't seen anything like it on my bikes, but I'm still using tubes.
Quoted: 5224 Post(s)
Liked 3,581 Times
is it on both sides?
is it on both wheels?
Quoted: 696 Post(s)
Liked 910 Times
I’ve never thought about it until I saw this thread. My rain bike which I recently converted to tubeless does the same thing. I bet it’s from sealant slowly leaking from the stem. I do have to top them up every few days.
