First Use of Topeak Joe Blow Sport Floor Pump (Yellow Barrel)
senior member
On a recommendation by a member I just got this floor pump - tried it out on an old 700x23 - I was comfortably able to get the psi to 100 but it was a bit of hulk type effort to get another 10 psi - now I know there are reports that someone was able to get very high pressures with a frame pump like the old Zefal but in all honesty don't most of us struggle a bit when we go over 100psi on any floor pump - or are those last handful of pounds really much easier with say the Joe Bloe Twin Turbo or the new Sport 2-stage - the model I have is the Sport single stage .
Quoted: 3513 Post(s)
Liked 2,926 Times
I use a Silca Pista Plus to get my tires to 140 psi. Of course, it’s harder to pump as the pressure increases, but not so much as to be a struggle.
Likes For smd4:
Advocatus Diaboli
Quoted: 4736 Post(s)
Liked 1,532 Times
Are you using gravity and your body weight to help?
senior member
I think you're probably an outlier for clinchers - I'm more interested in the experience of members who are at 90-110 for clinchers - Topeak has pumps that are promoted as able to deliver 160-200 psi but I'm assuming that's for tubeless .
Quoted: 1819 Post(s)
Liked 1,695 Times
For tubeless at the same tire size pressure is usually lower than for tube type or tubular tires. When I was using very narrow 700 x 20 clinchers my Silca Super Pista floor pump was able to pump my tires up to 150 psi
senior member
Liked 2,926 Times
Likes For smd4:
Advocatus Diaboli
Liked 1,532 Times
senior member
That's nothing , there's a guy out there who does that with a frame pump .
senior member
Liked 2,926 Times
senior member
Quoted: 6195 Post(s)
Liked 4,810 Times
Make certain the valve on the wheel isn't stuck or sticking. I've got one tire that the valve sticks and if I don't burp it when I loosen it to add air, then I do get a significant amount of resistance at the bottom of the pump stroke.
I doubt I could fill my tires with air from a floor pump if I am sitting in my easy chair. <grin> Though I've always been able to pump to a much higher inflation pressure with my floor pump. Even back in the days of skinny tires and rock hard was the defacto pressure to be at.
Quoted: 1438 Post(s)
Liked 1,092 Times
There is also a Joe Blow Race pump which has a gauge which tops out at 200psi and has a "thinner steel barrel for easier pump up to 200 psi / 14 bar." https://www.topeak.com/global/en/pro...-joeblow--race
senior member
senior member
Quoted: 426 Post(s)
Liked 274 Times
The 90lb GF has a very difficult time with anything close to 100psi. @ 150lbs I have no problem pumping 150psi+ on my charge canister. I just use my body weight and push down. Maybe I am the ideal height for floor pump at 5'7"? Six feet plus people maybe it's harder to pend that far down with pressure? dunno.
charge pump
charge pump
Method to My Madness
Bikes: Trek FX 2, Cannondale Synapse, Cannondale CAAD4, Santa Cruz Stigmata GRX
Quoted: 1948 Post(s)
Liked 1,471 Times
Don't want to start collecting floor pumps - don't need more than 110 in my 700x25's and my Topeak Sport gets me there with some effort - if I want less effort and/or more pressure I'll use the compressor - would like to reburbish my old Specialized floor pump if possible , would get me to 120 when I was running 23's .
charge pump
charge pump
Quoted: 426 Post(s)
Liked 274 Times
110 PSI in 700 x 25C tires seems kind of high; what rim width are you running? But despite not needing anything over 100 PSI, the charge pump below looks so legit that I want one ASAP; I assume I can get up to my riding pressures in two strokes, as I am a chubby ably assisted by my body weight.
it's not faster at all, sorry. It works great for tubeless tires. can pump up to 220 psi. I never tried that though. I have tried several times to get away with 125/135 psi to set up tubeless tires. Just not enough air/psi with only 135psi and the small canister. I have much better luck at 150psi. When it gets up around 150psi I slow way down. I think it would be difficult for me to hit 220psi at my weight of 150lbs.
Liked 1,471 Times
Quoted: 426 Post(s)
Liked 274 Times
I just saw you post the same charge pump in another thread re: tubeless tires, and now realize what this is for. I already have a pancake compressor (for my car tires), but do not use it to inflate my tubed bike tires; I was traumatized at a young age by inflating and exploding multiple bike tubes at my neighborhood gas station.
On your air compress you can set air pressure with the regulator. If you are not trying to seat a tubeless tire you can set the psi to something low like 90 psi.
Liked 1,471 Times
You are totally right! Now instead of buying this pump I only have to buy a Presta inflator (preferably with a gauge that goes up to 150 PSI if I ever go tubeless); do you have a recommendation?
Quoted: 431 Post(s)
Liked 460 Times
Some pumps are marketed as high pressure and some pumps are marketed as high volume. That said, I've never had trouble getting 100+ psi on any floor pump. The more expensive pumps just felt nicer getting there.
Quoted: 426 Post(s)
Liked 274 Times
If you don't mind spending money, everyone seems to love the park tool one.
Park Tool INF-2 Shop Inflator Presta/Schrader
some people have had good luck cobbling something together piece meal with stuff from mcmasters/homedepot etc...
If you just want to blast air into seat you tires then manual top off with your floor pump you could use something cheap like this
If it was me and I already committed the space for an air compressor, plugged it, waited for to fill several gallons I would just want the park tool. ha-ha
Likes For sean.hwy:
