Mask for pollution
Bikes: 2011 Raleigh Sojourn, 2012 Marin Four Corners, 2013 Soma Saga, 2014 Scott Spark 940, 2017 Brompton H6E, 2016 Trek FX 7.2
Quoted: 10 Post(s)
Mask for pollution
I’ve got a new job in a heavy industrial area of Salt Lake City. Cycling to work is an essential part of my excercise routine. Though I’m finding, through biking into this part of the city, that the air is exceptionally dirty. Even when we aren’t dealing with inversions, the air at the ground level in the industrial area is full of road dust which has god knows what in it.
So I’m looking into solutions for cleaning up the air I’m breathing. I’m gonna get a filter for my desk, but I need something for the ride to/from work. I have N95’s but I have a hard time breathing through those when I’m just doing low cardio work around the house. I can’t imagine trying to bike with an N95 on.
I’ve come across the Respro brand. That seems like the big player in the mask-for-athletic-use space. Does anyone have experience with these or any other masks? I’m trying to avoid spending $50 on a respro mask if they’re basically the same flow rate of any other construction type N95. The stuff I’m trying to protect against is pretty nasty and I’m already a mild asthma case, so I’m not okay with just a cloth buff or a bandana. I need a high-flow solution that actually removes fine particles. Please share your saga on finding a suitable with mask for biking in heavy pollution! Bonus points if said solution works well with glasses.
Thanks!
Thanks!
Quoted: 966 Post(s)
Liked 1,629 Times
I have pulmonary problems so I have a box full of masks that work and don't. The mask I wear for street dust is the Fightech. It has a large face and allows for more air in front of my mouth and nose. I sewed up my own filters out of thick ShamWow material by using the disposable filters as a template. I remove the filter and wash out all the snot and dirt that gets deposited during my rides. The ShamWow dries fast and can even be used wet.
Amazon 20 USD
Amazon 20 USD
Likes For zandoval:
There are a decent number of options out there targeting athletes. Cambridge Mask Co., Craft Cadence, Supa Labs came up after a search. This is a more commonplace concern in Europe these days, where there are more diesel cars and geography has made smog pretty bad. It's also part of the reason you see a lot of those eBike commuter helmets with the flip down visors - to keep pollution out of your eyes. I don't have much experience with the masks myself but can sympathize.
Quoted: 358 Post(s)
Liked 136 Times
I use to work in a industrial part of Denver. I couldn't find anything decent to keep me from breathing in all the junk. I resoled in using a double mask. Ok, not great but it work.
Quoted: 5224 Post(s)
Liked 3,582 Times
the only thing I was ever able to ride with during the worst covid times was a pull up neck sleeve type mask. it was helpful on dusty roads so it might help you. but chemicals/gasses in the air, are much finer than that thing was filtering
Disco Infiltrator
Quoted: 3126 Post(s)
Liked 2,105 Times
A year or two pre covid here in California there was a fire at the same time as an unusual wind that blew it into San Francisco. The techies all discovered N95 masks at the same time and wiped out the country supply for the year. The version for industrial, not medical is 3m 8511 as it is filtered in but not out and so it flows better and doesn't get full of moisture as fast. I have some for occasional use in fire season, as here in the central valley we get the smoke of whatever catches fire in the coastal range, and from the Sierras on days when the wind shifts and the fire slows down. (unpleasant irony that when the normal wind from the west keeps the smoke moving east away from us, it's stoking the fire) As long as you are using it for smoke and not sanitation they are good for a few rides. I have not looked for anything reusable or washable.
Respirator masks (for smoke not covid) | Mountain Bike Reviews Forum (mtbr.com)
Genesis 49:16-17
Genesis 49:16-17
Likes For Darth Lefty:
Thanks!
Thanks!
https://www.3m.com/3M/en_US/p/c/ppe/...ry-protection/
Quoted: 4806 Post(s)
Liked 3,929 Times
That ( bolded ) seems to imply a larger filtration surface area is needed. If airborne particles are the problem, this sounds similar to what welders, boilermakers, etc. have to deal with when welding galvanised steel, grinding, etc. The 3M ( and similar ) type masks shown in the photo use twin filters to help achieve greater surface area. Also the type of filters shown are specifically made for particles ( not solvent vapours, etc. ). There are several filter types available, depending on the particles. More info. on respiratory protection on 3M's web-site.
I used the older, heavier versions of this for years building boats. Yes, more than I want to wear riding but I got to breath better air inside fiberglass molds than out in the parking lot after the job on poor air quality days. (Alameda CA, early '80s)
