GRX400 lever
GRX400 lever
This is a stupid question but......
I bought a new take-off GRX shifter. the connection where the hydro hose fits into has a factory plug in it. however, there wasn't a yellow factory or any lever stop installed.
So, my question...if the brake lever has/had been pulled without any hose-caliper installed, could there be any damage to the internals?
Clark W. Griswold
Quoted: 4355 Post(s)
Liked 3,994 Times
It wouldn't likely damage anything maybe if you did it bunch and somehow built up pressure you could damage some seals maybe but I doubt you will have done much to it pulling it with the plug.
Quoted: 4408 Post(s)
Liked 1,561 Times
The plug and the block are there to prevent pumping the fluid out. With the plug in it shouldn't be any different than when you have the pads set too tight and pull the brake lever - no damage.
[QUOTE=veganbikes;22840376]It wouldn't likely damage anything maybe if you did it bunch and somehow built up pressure you could damage some seals maybe but I doubt you will have done much to it pulling it with the plug.[/QUOTE
Thank you
Thank you
Likes For TwoRings:
Bikes: !982 Trek 930R Custom, Diamondback ascent with SERIOUS updates, Fuji Team Pro CF and a '09 Comencal Meta 5.5
Quoted: 1299 Post(s)
Liked 739 Times
Bike brakes do not have one way valves in the system.. "building pressure" once the piston in the master cylinder returns to the "open", fully released Position, is impossible. The Master Cyl. Piston Moves oil in both directions.
Clark W. Griswold
Liked 3,994 Times
Exactly that is why I said you would have to somehow build up pressure which I didn't state is basically impossible but I should have made that clearer.
