order my first carbon wheelset going to try tubeless
Quoted: 426 Post(s)
Liked 274 Times
I order a new wheel set with the help of this thread. around page 52
light bicycle thread
To not muck up that thread with my noob question I started this one.
I ordered wr46 with no holes. Does this mean I don't need any rim tape?
This is my first tubeless tire. From amazon I see the gp5000 tires I like I have to order them in tubelss form.
When I go to place my order on amazon recommends these two other things.
stans sealant
KOM Cycling Tubeless Sealant Injector Syringe
Should I just order those two things or is there a better product I should get instead ?
stans sealant
On Your Left
Quoted: 3004 Post(s)
Liked 2,433 Times
Quoted: 426 Post(s)
Liked 274 Times
Should I buy the other stuff that amazon recommended?
On Your Left
Liked 2,433 Times
$12 for an injector, not gonna find one much cheaper.
Buy them.
Likes For GlennR:
I recommend Orange Seal instead of Stan’s sealant. Can you confirm with them that the the included valve stems are tubeless as well?
Quoted: 766 Post(s)
Liked 1,739 Times
I saved one of the small single use containers that had a nozzle that fit into the valve tube and just use that, but I could spend 12 bucks for that injector.
Quoted: 426 Post(s)
Liked 274 Times
https://www.lightbicycle.com/bicycle...alve-stem.html
On Your Left
Liked 2,433 Times
Likes For GlennR:
Quoted: 426 Post(s)
Liked 274 Times
They have amazing customer service!
that was a fast response.
7:26 PM (0 minutes ago)
to me
Hi Sean,
Since the rims are without holes, you don't need the tape and we will make a refund of $6 USD to you in 3-5 workdays.
For Tubeless wheelset, sealant and tires/ valves should be fine. Here is the user guide for your ref:
https://www.lightbicycle.com/support/user-guides
Best regards,
Nicole Ni
Light Bicycle
to me
Hi Sean,
Best regards,
Nicole Ni
Likes For sean.hwy:
Quoted: 164 Post(s)
Liked 44 Times
DO NOT GO ROAD TUBELESS , there is no point to road tubeless , you have no ability to deal with the problems that you will face , save yourself the time and money and just get some regular gp5ks and high quality latex tubes !
Quoted: 20810 Post(s)
Liked 9,456 Times
Likes For WhyFi:
Liked 9,456 Times
Get the injector. Skip the Stan's, get Orange Seal instead.
One note on the injector: some valve stems won't pass the 3mm hard plastic tube all of the way through - many have a little tight spot inside where it'll bind - so if you can't get it all the way in, try another set. The alloy ones from Muc-Off will definitely work, if you're having trouble finding some locally.
On Your Left
Liked 2,433 Times
The tubeless bike is my winter and foul weather bike. It has 32mm Bontrager AWS tires. I have over 6000 miles on it over 3 winters and have had 0 punctures. I do carry a tube and tire levers, but the thought of dealing with the mess of sealant, trying to get a tube inside in 30* weather and possible rain does not excite me. So I might call Uber or AAA to get me home. I generally don't wander more than 10 miles away in those conditions. So I can get 40 miles in and never be more than 10 miles away.
From talking to others they've has similar good results with many trouble free miles. Since my Zipp 303s are not TLR i'll continue using tubes until they are replaced, but I have no plans at the moment.
Likes For GlennR:
Fat n slow
Quoted: 3259 Post(s)
Liked 2,085 Times
Quoted: 4717 Post(s)
Liked 1,882 Times
stans sealant
Likes For noodle soup:
On Your Left
Liked 2,433 Times
Personally when it comes to questions about a specific product, I like to talk to the manufacturer over some anonymous people in the interweb if possible. Better to hear it from the horse's mouth than the other end of the animal
But then there are some vendors that do not have direct support to the end user.
Liked 9,456 Times
I saw it on his order but the OP has contacted customer service and they confirmed it's not needed and is refunding his purchase.
Likes For WhyFi:
Occam's Rotor
Quoted: 2366 Post(s)
Liked 2,331 Times
Likes For Cyclist0108:
On Your Left
Liked 2,433 Times
Years ago i bought a new chain online and the website said I needed a quicklink also. When package arrived I opened it to find the chain comes with a quicklink inside. Not a problem since I would use it when I R&R the chain to do a deep clean... but I didn't need it.
Liked 1,882 Times
When ordering wheels from LB, they give you the option of including tape and valves for all their wheels, and the option is still there even if you select hoops that have no holes in the rim bed.
Bikes: Speedvagen Steel
Quoted: 429 Post(s)
Liked 248 Times
OP, congrats on the new wheels! Seems like all your questions have been answered but I’ll just chime in that with over 6 years on road tubeless and about 4 of those being exclusive that I’ve tried pretty much all the variations of sealant and Orange has definitely been the best for me so far. With Bontrager coming in close behind. I’ve never used an injector before since I’ve just kept the cap and tube that comes with a previous small bottle but anything that makes it quick and clean is a plus in my books.
Have fun, looking forward to your first ride report!
