1UP Bicycle Rack Question
I am looking at getting a 1UP bicycle rack and they have the original Quik Rack 1.25"
https://www.1up-usa.com/product/quik-rack-single/
and the Equip-D Single 1.25"
https://www.1up-usa.com/product/equip-d-single/
I watched the videos on how to use them and the original Quik Rack seems simpler to use. On the Equip-D there is a red pin that has to be removed to rotate the rack(and another pin that sits beside the red pin). It seems to me the non-red pin might be jarred out of place. On the Quik Rack just pull a handle. Anyone have experience with both?
Don't bother with 1.25". Just get a 2"hitch receiver and get the real racks. I have their 2"single rack and am very happy.
They sure provide quality, but 2"is just inherently better. Especially with more weight, higher speeds etc.
Cry once... a 1up rack will last a life time.
Quoted: 765 Post(s)
Liked 1,735 Times
Get an expander to hold the 2 inch rack, they sell one, but way over priced. I found one at the where I had my the 1.25" rack I installed on an old CRV way back in the day. They are about $20 to $30 or so. The 1 Up is a fantastic rack, will not be disappointed, I was very happy when I decided to move to theirs from my 12 yr old Yakima.
Edit: Found this one:
Brian | 2023 Trek Domane SLR 7 AXS | 2023 Trek CheckPoint SL 7 AXS | 2016 Trek Emonda ALR | 2022 Trek FX Sport 5
Ignore those guys and get the 1.25. Running an adapter just extends your rack out further, increases the leverage on the hitch, lowers your max tongue weight, and adds more places to wiggle.
I've never seen a D in person but yeah watching that video doesn't seem like that great of an update. The tilt on the old one which I have is a bit of a pain but not that big of a deal, becomes more of an issue the more trays you add on since you have to reach further under the rack. The pain part is the lever kinda jams a bit and you may have to wiggle it or the rack to get it to move every now and again.
Likes For Canker:
Bikes: Soma Pescadero, Surly Pugsley, Salsa Fargo, Schwinn Klunker, Gravity SS 27.5, Monocog 29er
Quoted: 186 Post(s)
Liked 234 Times
Don't worry about it. I have never folded up my quick rack single. It doesnt help with clearance. I can undersand folding the 2 bike model if you don't have a bike on it.
Likes For themp:
Advanced Slacker
Quoted: 2762 Post(s)
Liked 2,537 Times
2” is definitely better, but only if you have a 2” receiver.
If you have a 1.25” receiver, using an extender to stick a 2” in a 1.25” reciever completely defeats the purpose of having a 2” rack, and will be LESS stable than a 1.25” rack.
One nice thing about 1Up is that (at least on the standard rack) you can replace the 1-1/4” hitch piece with a 2” one down the road. That part is the only difference between the 1.25” and 2” versions of the basic rack.
Quoted: 1109 Post(s)
Liked 1,200 Times
It is just as stable as it is on my 2" receiver. People who think it's less stable because of the adapter are plain wrong.
Quoted: 2975 Post(s)
Liked 1,181 Times
Advanced Slacker
Liked 2,537 Times
Not a reason to avoid a 2" rack. Just get a 1.25 - 2" converter. That's what I did on my Subaru. Use an anti-rattle clamp (look it up) between the 1.25 receiver and the 2" adapter and it will be rock solid. Even without the anti rattle clamp, it still works fine, just makes noise and has a bit more movement. Just don't be an idiot and think it actually turns the capacity of your vehicle into that of a 2" receiver. But a bike rack is the same whether it's on a 1.25 or 2" receiver (allowing for a slight difference in torque and therefore carrying capacity because of the extension...irrelevant for the weight of a bike rack).
Liked 1,200 Times
I was just trying to make the point that having a 1.25" receiver on a vehicle should not be considered a barrier to getting a 2" rack. If the OP's 2" option has features that the 1.25 does not, go with the 2". The adapters - especially with an anti-rattle clamp - are as stable and quiet as if they weren't there. I did acknowledge that the adapter does extend the receiver therefore increasing torque of the load and that needs to be taken into consideration. This needs to be considered for heavy loads like the tongue weight of a trailer, or a receiver hitch cargo carrier. But not for a bike rack (IMHO). Maybe not if the user had two heavy e-bikes? But for normal road or mountain bikes, I don't think weight is an issue.
Anyway, I had several personal reasons to get the 2", not in order, but it wasn't based on stability, per se. My rack is a Yakima. I like to have the option of using it on my 2" receiver (truck) and the possibility of adding 2 more bikes (total 4) which the 2" Yakima has an option for, but not the 1.25 (which I wouldn't do if it was on the 2" adapter car). Second, the 2" was available locally where the 1.25 would have required shipping expense - not insignificant where I live. Finally, I already had a 2" adapter in place for a small utility trailer I tow regularly. Factors which likely don't apply very often to others!
My previous Yakima receiver rack was 1.25 and 2" compatible. The shaft was 1.25, but it came with a very simple 2" adapter that was attached to the shaft with an allen bolt, didn't require the receiver itself to have an adapter. I wonder why this isn't routine?
Quoted: 236 Post(s)
Liked 196 Times
People seem to be missing the part where the 1.25 - 2" Quick Rack comes with it's own 2" adapter that allows it to be used in either size receiver.
Likes For gpburdell:
Quoted: 383 Post(s)
Liked 690 Times
A 2" hitch receiver cost almost the same as the 1.25. So I don't see the point in installing a 1.25" receiver.
Quoted: 765 Post(s)
Liked 1,735 Times
They probably could, but in this situation with a 40 lb rack, and a 20 lb bike, it was a non factor. It only extended the receiver about 2 inches. I would never do that if I was looking to pull something, but for a bike rack, meh, no big deal.
Liked 1,200 Times
As I mentioned a couple of times above, if you use an anti-rattle clamp, they're very solid. Here's one example, that doesn't require tools to put on and off. See a site like eTrailer to see the variety available.
This is the sort of adapter a Yakima rack I had years ago had. It's a great way to do it.
Quoted: 236 Post(s)
Liked 196 Times
With a single bike rack such as those cited, you're nowhere near the typical 350lb tongue weight rating for a 1.25" rack and the additional capability of a 525lb rated 2" hitch gives zero functional benefit.
OP already has a 1.25" hitch installed per post #3. Thus it would cost more to replace the existing 1.25" hitch than to use it.
Quoted: 236 Post(s)
Liked 196 Times
Sure, if someone is buying a hitch and the vehicle can accommodate a 2" receiver that'd be the way to go, but in OP's case of already having a 1.25" hitch installed the 1.25"-2" QuickRack Single is a fine choice. Just be aware it's rated to 50# per spot (up to three bike spots with AddOn's) in case thinking about ebikes.
Here is my 1UP 1.25" that I just received. It is very solid for one bicycle with the 1.25" hitch. It actually sways slightly from the front wheel pivoting while you are driving.
https://www.dropbox.com/s/p1fcexjeyd..._0319.jpg?dl=0
1.) It is a nice piece of engineering. Everything is milled perfectly and no scratches.
2.) First concern was what if a tire went flat on the bicycle while driving. Google searches said not to worry.
3.) Since I had a $69 dollar rack previously, I was not worried about theft. Now I am. Going to look at getting a u-lock and lock the rack to the hitch. This would also solve the concern of the post coming out. They give you a Velcro strap for this but in no way would it stop the rack from falling out. When I am traveling and staying over night at a hotel or camping I will just disconnect and put it in the back of the SUV. It is very light and compact.
4.) In using it for taking the bicycle off, you want to disconnect the front wheel first.. Otherwise, if you did the rear first, the bicycle will pivot on the front wheel and want to fall off. You can do the front wheel and them move to the rear and the bicycle stays stable.
5.) Have not tried the extension, but will in a few weeks. It is again perfectly milled and assembled with no manufacturing blemishes of any kind.
6.) I actually hated installing it the first time as I knew my older 1.25" hitch was going to mess up the nice aluminum post on the 1UP(scratches and rust marks).
well hello there
Quoted: 503 Post(s)
Liked 336 Times
I used to have a 2 inch hitch and a 1.25 rack and this was the perfect device to stop all the shaking and rattling.
Likes For Nachoman:
Fxxxxr
Quoted: 2671 Post(s)
Liked 1,151 Times
i have had the original 1UP with the 1.25 on my Forester for over 4 years >>> no problems and solid
Quoted: 236 Post(s)
Liked 196 Times
#3 - the strap is intended to prevent the rack from wiggling out of the receiver if it should loosen, and is plenty strong for that purpose. Just make sure it's tight. I also check that the rack is tight in the hitch receiver by giving it a wiggle as I walk by.
For brief stops while traveling I use the Hitch Bar Lock which I thought was included with the 1.25" Quick Rack now, along with a couple Wheel Locks as referenced in #2. The ability to fold the rack makes it easy to stash inside a trunk or back of an SUV for the overnight stops where you'll be taking the bike inside.
Advanced Slacker
Liked 2,537 Times
This is my low tech security device for the rack itself:
Stuff I had on hand. I will likely get a more heavy duty lock and some hardened steel chain.
#2 - if you wish to make absolutely sure, either use a couple of 1UP Wheel Locks or a velcro cinch strap around the bottom of each wheel similar to what came with the rack.
