So I bought an old Sekai 2500 for the derailleurs and barcons but...
ambulatory senior
Quoted: 1955 Post(s)
Liked 3,661 Times
When I got it home I realized the anti rotation pin was broken out of it. Aside from being a pain possibly when changing wheels, is there any danger in using it? The cage seems straight and I rode the bike home shifting thru the gears properly. I mean could this just be a lighter version now?
Quoted: 1829 Post(s)
Liked 3,376 Times
Steve in Peoria
Likes For steelbikeguy:
señor miembro
Bikes: '70s - '80s Campagnolo
Quoted: 3888 Post(s)
Liked 6,488 Times
Come on, man. You're too resourceful to use a broken derailleur on your own fleet. Toss it in your bin, and there's plenty still there (pulley wheels, anchor bolt, etc.) to offer donor pieces for future projects.
Likes For SurferRosa:
ambulatory senior
Liked 3,661 Times
This question has crossed my mind, as I've seen these on ebay without the stop pin. I think you've identified the main issue... over-rotation of the cage when removing or installing the wheel. In general operation, that stop pin should never be used.
Steve in Peoria
Steve in Peoria
Liked 3,376 Times
Steve in Peoria
ambulatory senior
Liked 3,661 Times
I actually have plenty of other derailleurs I could use and I paid 50.00 and got a complete set of barcons in addition to the derailleurs plus a kid down the street wanted the frameset so I didn't have to take it to the coop. All in all a nice aquisition.
Likes For 52telecaster:
señor miembro
Liked 6,488 Times
Quoted: 3811 Post(s)
Liked 6,709 Times
I had a bike set up with an RD that was missing that stop pin. Biggest PITA was if I needed to remove the rear wheel, such as to fix a flat, the cage would spin around, the chain would tie itself in knots, and getting everything straightened out was a major endeavor. Not worth it.
Likes For nlerner:
Quoted: 2363 Post(s)
Liked 1,749 Times
Shove an allen wrench (or small stick or what-not) thru a convenient slot in the cage plate(s) before removing the wheel, to stop the cage from swinging 'round too far.
(Remember to remove it upon re-installation of the wheel.....)
Likes For madpogue:
ambulatory senior
Liked 3,661 Times
If I had to that's an excellent emergency hack. I looked through my pile of broken derailleurs and found several stops that could be used by making a careful tapped hole. I may go that route. It would require buying at least one metric tap. Always a good time!
Liked 1,749 Times
ambulatory senior
Liked 3,661 Times
My thoughts exactly, also giving up on a cool old derailleur against astronomical odds of doing anything remotely beneficial is just not my way!
ambulatory senior
Liked 3,661 Times
A pin taken from a roached cyclone 2. This is the smaller pin that prevents it turning the opposite direction. It seems to be working fine with the new drilled and tapped hole. The location is a bit different so I may have lost a link of wrap but it works well now.
Glad it's back in service!
Bikes: 1984 Miyata 310, 1986 Schwinn Sierra, 2011 Jamis Quest, 1980 Peugeot TH8 Tandem, 1992 Performance Parabola, 1987 Ross Mt. Hood, 1988 Schwinn LeTour, 1988 Trek 400T, 1981 Fuji S12-S LTD, 197? FW Evans
Quoted: 532 Post(s)
Liked 1,007 Times
I also used the tap set to restore the threads in a derailleur stop pin hole so I could insert a small screw.
Likes For Pompiere:
ambulatory senior
Liked 3,661 Times
I bought a metric tap and die set from Sears before they closed all the stores around here. I frequently use the 5mm x .8, and occasionally the 6mm for bike work. What made the set worth the purchase price was using one of the bigger sizes for a mangled thread on a steering knuckle on my daughter's car.
señor miembro
Liked 6,488 Times
ambulatory senior
Liked 3,661 Times
My old man always fixed everything. I wish I was half as good as him. Plus while I didn't weigh before or after, it has to weigh less because the stop is smaller and I lost some stock on the cage so my son says it's now the super legere version.
señor miembro
Liked 6,488 Times
ambulatory senior
Liked 3,661 Times
