Help me ID this Hercules Roadster
Bikes: (3) 1970's Raleigh Sports, (1) 1968 Robin Hood 3 speed, 1974 Raleigh Grand Prix, 1976 Raleigh Grand Prix, 1969 Peugeot UO-18, 1971 Peugeot UO-08, 1980 Giant road bike, 1954 Humber, 1940ish Hercules Popular, 1963 Dunelt, 2007 Trek 3700 mountain bike
Back in March of 2011, another C&V member, ftwelder, offered me a Hercules Roadster for the cost of shipping. I was working a contract job in Wichita at the time and when the bike arrived at my home in St Louis, my son stuck it in the garage, still packed in the shipping box. That box remained sealed until today when I opened it to quickly check the bike, though not removing it.
The photos below were taken by the previous owner and hopefully they will be enough to help ID the model and possibly year of manufacture. I should say that the rear hub, the Simplex rear derailleur and the both shift levers were removed from the bike prior to shipping.
Get off my lawn!
Bikes: 1917 Loomis, 1923 Rudge, 1930 Hercules Renown, 1947 Mclean, 1948 JA Holland, 1955 Hetchins, 1957 Carlton Flyer, 1962 Raleigh Sport, 1978&81 Raleigh Gomp GS', 2010 Raliegh Clubman
Quoted: 93 Post(s)
Liked 98 Times
Hopelessly addicted...
Bikes: 1949 Hercules Kestrel, 1950 Norman Rapide, 1970 Schwinn Collegiate, 1972 Peugeot UE-8, 1976 Raleigh Sports, 1977 Raleigh Sports, 1977 Jack Taylor Tandem, 1984 Davidson Tandem, 2010 Bilenky "BQ" 650B Constructeur Tandem, 2011 Linus Mixte
Liked 10 Times
Rod Brake Roadster With A Derailleur?
As far as the lever on the top tube, as with the derailleur it is not the original as it would have been a quadrant shifter or a trigger shifter.
Quoted: 790 Post(s)
Liked 1,769 Times
Great bike vintage true Herc before made before they sold out likley orginal just Just pre war. While not original the vintage change to what looks like a 4X3 rear is just very interesting. I would love too see this bike up and running with the vintage 50's changes up and running. As for the two levers one for the IGH threespeed and one for the 3/4speed derailleur both on the rear.
Bikes: Many
Quoted: 5 Post(s)
Liked 10 Times
You guys never heard of a "Hercurailleur?" I think this bike came with one originally. It was made by cyclo if I remember correctly.
Get off my lawn!
Quoted: 93 Post(s)
Liked 98 Times
Yup...but only seen pictures, late 40's to mid 50's and indexed using a thumb shifter that looked like a handlebar bell...no?
Wood
Bikes: Raleigh Sports: hers. Vianelli Professional & Bridgestone 300: mine
Quoted: 8 Post(s)
Liked 12 Times
ftwelder is right, the "Herailleur" though the Simplex derailler is probably a replacement, the catalog shows a Cyclo.
https://threespeedhub.com/wp-content/...g-1954-UK1.pdf
This bike, being the "tourist" type with the bolt up rear triangle, is never mentioned in the catalogs as available with the Herailleur, it could have been ordered that way I suppose.
You can see the faint outline of the circular headbadge on the steering tube. This badge was replaced with the shield shaped badge around 1950.
I just found this web site, https://herculesmuseum.wordpress.com/...ercules-gents/ which could help in pin pointing the specific model and perhaps zero in on the year.
multimodal commuter
Quoted: 1908 Post(s)
Liked 574 Times
I don't believe either shifter is original. It is, as you said, a roadster. It probably came with a single speed freewheel originally. This was upgraded to the three speed freewheel with a Cyclo Standard type derailleur, which has two cables operated by a single shifter (actually one long cable loop). If the derailleur was clamped to the drive side chain stay (as seems most likely) you should find marks on the paint where the clamps attached. You should also find a mark in the paint on the stay near the BB where a hook of some kind was mounted for the spring that maintained chain tension.
If the frame was made for a Cyclo Standard (or similar) derailleur, there will be a derailleur mount brazed to the chain stay and an eyelet for the spring. But I don't see the derailleur mount, so I assume it was an add-on.
Liked 10 Times
Several things here.
1) This bicycle would not have had a Simplex Prestige derailleur.
2) If it had a Cyclo or Herailleur derailleur, it would have normally been mounted on the downtube and not the top tube. See picture below.
3) It is doubtful a roadster would have had a derailleur.
4) The chainguard, while similar to that on other Hercules, does not appear to be original to the bicycle.
5) You are correct that the shield badge appeared around 1950.
6) As far as the Hercules Museum website, while a nice resource, I doubt you'll be able to pinpoint the model or year. Hercules had a fairly large model range which varied by country and from year to year.
I'm guessing it's somewhere around the 1940's -1950's. I would look at the bottom bracket cups or the chainset for signs of a date stamp.
I totally agree with you and never suspected it to be OEM since this was a '70 era French derailleur.
After quite a bit of researching Hercules catalog scans, I can to the same conclusion; probably added by one of its many owners.
censae
21
06-20-15 02:13 PM
4X4XFAR
9
09-26-14 12:27 PM
owenmyers
1
07-23-12 03:34 AM
