Gloves: What to Look for?
Bikes: Secteur, Camber, Trek 930
I'm about to head down to my LBS and get some gloves to try to keep my fingers from falling asleep on longer rides. They have one wall and many bins full of gloves (dozens and dozens of different gloves). Anything I should look for, other than a good fit and I guess gel pads? I assume I want fingerless too.
I wasted more money on gloves (name brand gloves) that didn't hold up well. Finally I stumbled on a pair of Craft gloves that have now lasted me three years. They are very well made (quality material, heavy duty stitching, etc.). They don't have any "gel padding" but the padding they have is in just the right place and they work great. They weren't cheap but they have actually saved me money in the long run.
I would look for the best quality gloves you can find (even if that means buying online).
Bikes: Giant Defy Advanced 1 (2011), Santa Cruz Superlight (2000), Jamis Coda Comp (2009)
In addition to looking for good vibration absorption and fit, some of them have an absorbent material on the back (like terry cloth) to wipe the sweat from your forehead and brows. Don't get gloves that have too much padding - they can result in an unnatural position on the handlebars and can actually cause compression of the nerves in your hands, and they can cause you to lose your "feel for the road".
Just in case the new better fitting gel-padded gloves don't make any difference, you may want to ask the LBS if they could help you with a basic fitting (seat up/down, fore/aft). In my experience, changing gloves never helped much in solving hand numbness - the solution has always been some sort of seat adjustment to take pressure (weight) off of my hands. The fact that you're getting numbness late in long rides, could indicate that your position on the bike is changing as you become fatigued and it's resulting in you leaning forward and putting more pressure on your hands. With my riding position dialed in correctly, the primary reason that I wear gloves is to prevent callouses.
Bikes: '86 Cannondale SR400, '86 Pugeot PX10, '92 Bianchi Axis, '95 Bianchi Campione d'Italia, '00 Fondriest X-Status, '08 Specialized Roubaix, '13 Cannondale CAADX
Padding has got to fit you. One pair somehow pressed my ulnar nerve and two fingers went numb/tingly. Most others don't. This'll depend on your particular physiology.
Big +1 on absorbent back...Hay fever season demands no less.
Erect member since 1953
Bikes: Trek 520 Grando, Roubaix Expert, Motobecane Ti Century Elite turned commuter, Some old French thing gone fixie
Liked 38 Times
My favorites are an old pair of thick (compared to the fine leather new ones) leather gloves.
I find most have padding I don't care about and are made of such soft, fine leather they wear out too quickly.
The other option is just to go cheap as possible and figure they're like tires; things that don't last long.
CAADdict
Bikes: 2009 Cannondale CAAD9-?
Liked 5 Times
I've tried a few. I settled on a pair of Louis Garneau Air Carbon gloves.
They've stayed cool enough for me during the summers.
I gladly paid $40. for them, but they can be found now for $20. I think they are a great value.
Very comfortable, but not so much so that they make me feel disconnected from the road.
It's hard to know what you personally need/want.
I like gel. I like quality materials that can be washed a lot.
The Louis Garneaus I chose made a huge difference in my riding experience.
Bikes: S-Works Roubaix SL2^H4, Secteur Sport, TriCross, Kaffenback, Lurcher 29er
I have a pair of those LGs, and they seem like they would be fantastic gloves for me if they weren't a smidgen small (I wear XL in most gloves, XXL if I can get them). Unfortunately they cut into the webbing between my fingers and get a bit painful after an hour or so.
I agree with the previously stated opinion that too much gel is not good. I like a fairly thin pad, and if there is gel I like it to be thin like the LGs. I've got Descente Supreme gloves that I really like, and I'm a fan of the Specialized BG Pro glove, but the BG Gel has too much padding for my taste.
Anyone have a way to stretch a glove out? I'd really like those LG's to work for me.
Specialized BG Pro gloves. I just like padding on the heels of my hands. Make sure the velcro, if the gloves have it, is on the outside of the glove, not the inside which can result in getting hooked on stuff.
Bikes: Cervelo RS, Specialized Stumpy, Schwinn 974
Giro Monacos are very good gloves. Real leather (Pittard) palms are more durable than Clarino " synthetic leather". Colored models get back-of-hand sun-bleached color wash out, but the gloves otherwise hold up fine. Wait until October-December for major discount prices.
I also like Specialized BG Pro gloves. I think Monacos are better, but you decide.
I tried a pair of PI "clarino leather palm" gloves, not doing that again, they just didn't hold up with long, rigorous riding.
I use the Louis Garneau (2 pair) and really like them. I have fairly big hands and they are tight for the first few rides and then they stretch out. These have become my favorites after using Specialized for a long time.
CAADdict
Liked 5 Times
It might sound wierd, but soak them in water, squeeze the excess water out of them, then wear them.
Make fists, manipulate your fingers, stretch your hands and keep working the material.
They'll begin to conform to your hands. I have big hands myself. I have the XL pair.
I learned this trick with my Ironclad Work Gloves by accident
(they were tight until I had to work with them in a rain storm).
Thanks everybody -- lots of good info!
I'll likely try to bug the LBS where I bought my bike to check its fit. It's pretty much the first two fingers on my left hand that fall asleep.
The specialized body technology or something gloves that were recommended on here are the only ones that keep my hands from going numb. All the gel ones kill me. They were like $30 on the specialized website.
Bikes: 2010 Specialized Tricross Expert, 2011 Cannondale CAAD10-4
I have the ones that don't have velcro, with the nice Pittard leather palm, and a very breathable back.
Bikes: 2011 Scott Addict R3 and Redline Conquest with Campy Veloce
All I buy anymore are unpadded gloves. I love the feel of the road. You may think "If you're wearing unpadded gloves, why wear gloves at all?" The answer is the abrasion can wear on the heels of my hands after changing position and sliding my palms all over the top of my bar.
Bikes: '14 Kona Rove, '06 Bob Jackson
I just got a pair of Specialized BodyGeometry Sport, which are great so far. IMO, the best part about gloves is you can get a great pair for $20, and if they aren't so great than it's only $20!
en fuego
Bikes: Trek Madone 3.1
gloves are subjective. i prefer gloves with minimal padding. i like the terry section on the thumbs for wiping sweat. i also like the little finger loops for removing the gloves. i have a pair of craft and a pair of castelli gloves that are great. i currently ride most of my miles in these: https://www.probikekit.com/us/clothin...s-mitts-1.html
