Hub Dyno Wiring Examples Please?
Quoted: 3461 Post(s)
Liked 1,466 Times
There are also a bunch of different brackets if the bending method doesn't get it high enough.
Jedi Master
Bikes: Working on replacing my stolen Soma Buena Vista Mixte
Quoted: 417 Post(s)
Liked 95 Times
Here is a neat example: Aftermarket Dynamo Lights: a Clean Look
I have internal routing on my current bike, previous bikes have used a front rack and fenders to hide the wires along the way!
Likes For jade408:
Quoted: 1188 Post(s)
Liked 1,154 Times
Dunno, I just used black plastic truck air line for the rear light wire. Comes in a bunch of diameters. The smallest one looks about the same as brake or gear outer, so it runs alongside those in the same mounts. Mostly because I have to fully demolish the bike when I pack it for travel, so the cover stops the wire from getting damaged when I jamb stuff in the box. Could probably do the same for the front, zip tied on.
I like cats.
Came looking for advice, left with the reassurance that comes with realizing that your plan isn't any jankier than anybody else's setup. I mount my light on the front of a porteur rack, so the cable has lots of area where it's just supported by air. Thinking that in those sections I might try enclosing the rear light and dynamo output wires together in heat-shrink with a 1/32" piece of TIG rod so that there's some support.
Likes For ericoseveins:
Randomhead
Liked 3,698 Times
My usual excuse for messy dyno wiring is that the wiring on my bike is temporary. OTOH, some of my temporary wiring has been on a bike for 10 years. Once I get my travel bike painted I may actually try to do a permanent wiring job. I have provisions for most wires to travel in the frame/fork.
Quoted: 2604 Post(s)
Liked 1,933 Times
I prefer to think of my dyno wiring as a theft deterrent. Would you want to be caught riding a bike like mine, with the wires wrapped around the fork and everything?
reducedfatoreo
10
06-03-16 08:13 AM
southpawboston
Classic & Vintage
26
03-15-13 08:33 AM
Easy Peasy
15
09-23-11 12:59 PM
