Garmin tempe performance
Beer & Bikes
Bikes: '20 Specialized Roubaix Expert, '20 Specialized Shiv Elite, '13 Specialized S-Works Epic
Quoted: 38 Post(s)
Liked 80 Times
TL;DR – Garmin tempe is good for hyper local temperature measurement and logging but has some limitations and use challenges.
After reading some mixed reviews, I wanted to test out a Garmin tempe and see for myself. My first test was to measure the accuracy of the sensor against a calibrated basic lab thermometer. The room was air-conditioned and closed off for reasonably consistent ambient temperature. The setup was both the tempe and the lab probe isolated from any heat sink or conductor. Solo cups worked well. Is there anything a Solo Cup Company product can’t be used for? Over an hour with 5 minute intervals, I tracked the temperature of the lab probe as well as the tempe via a 3rd party app on my Vivoactive 4. You can see the excel spreadsheet for the results. In summary, it’s close to a calibrated thermometer that itself has a +/- accuracy of 1 degree Celsius. That should be good for most uses.
Then I mounted it on my bike and went for a ride. The tempe readings were a consistent 4 degrees Fahrenheit warmer than the National Weather Service (NWS) report. The line graph shows its plot via a 3rd party app on my Garmin Edge 530. The grey block graph is the Edge internal temperature. My NWS sites are five and fifteen miles straight line from me so I’m not entirely clear why the discrepancy.
The most common complaint was accuracy and I get that. Radiant body heat or direct sunlight would definitely skew the data. Isolated from those two error sources and the device seems reasonably accurate. Mounting options are not great. The included bracket is marginal for most situations unless you can move it off your body and not in constant direct sunlight.
But my biggest disappointment is Garmin’s current decision to not make it a native sensor for Edge cycling computers (as of post date). It’s an ANT+ sensor so there is no practical reason to not include it on the Edge computers. There are several 3rd party apps that allow work-arounds for the Edge series. Still, it should be an easy fix.
Quoted: 680 Post(s)
Liked 949 Times
Quoted: 6194 Post(s)
Liked 4,810 Times
It's always seemed to me that the biggest thing with temp sensors is how much lag there is from the true ambient temp. When riding a bike or even walking there are plenty of times when going from wide open sun exposed areas to dense tree shaded areas the temps change quite a bit.
On a bike going 20 to 30 feet per second you can be in and out of those areas pretty fast. So will any temp probe respond quick enough for those changes? My instant read food thermometers require 3 seconds to give an accurate reading. So is Tempe able to do better?
Perhaps put it in a cooler temp and then move it to a hotter temp and see how long it takes to match.
Quoted: 18883 Post(s)
Liked 10,646 Times
Tempe is natively supported by their watches. I have mine mounted near the BB.
Liked 10,646 Times
Tempe is extremely parsimonious with its battery. It broadcasts twice a minute. Your watch finds Tempe's schedule and then turns its own radio on and off in sync to reduce power consumption.
Liked 4,810 Times
A lot of the finer changes in temps of my ride will be missed entirely just by that alone.
I'll still be just as happy with sticking my arm out the door before I leave to gauge what to wear and how I might perform.
Though I don't know what the use is the OP has for their Tempe, other than to have something that might be a little more local to them than the TV weather report.
Liked 10,646 Times
@Iride01 what do you do with your temperature data that losing the transition that happened from 23 to 24 seconds would throw your experience on the bike off?
Liked 4,810 Times
If I did want to know temperature to equate what I was doing on a particular segment of my ride, I'd rather know that the resolution of the data can be resolved to allow several data points for just that segment.
900 feet or about 274 meters does not seem adequate enough if I wanted to use air temp variance to evaluate other data on some of my climbs I track. Though I have no idea why I'd even worry about temp other than it's cold, comfortable or terribly hot. Which doesn't require a thermometer.
Liked 10,646 Times
Every 30 seconds, a Tempe unit will broadcast 3 things: the current temperature, plus the high and low temp it's seen over the last 24 hours. According to its own internal clock.
Use cases: I have a Tempe clipped to each paper of ski boots I use. I've been night skiing down to -10F. I keep one on my backpack for hiking. When I hike in and camp in the wilderness, I bring 2 Tempes, one stays outside, the other comes in the tent with me. The watch lets me check either of them at will. None of this is for decision making, or correlating performance data. I have one on my bike because my Garmin records temperature but is affected by my body, and this gets rid of bad data for me.
Tempe costs about $25 and weighs maybe 10g. The battery lasts a year or two.
Likes For Seattle Forrest:
