Go Back  Bike Forums > Bike Forums > Recumbent
Tire issues
Recumbent What IS that thing?! Recumbents may be odd looking, but they have many advantages over a "wedgie" bicycle. Discuss the in's and out's recumbent lifestyle in the recumbent forum.
Tire issues
Old 07-01-22, 04:22 PM
Shannon Casto
Tire issues
Can I replace 16x 1-3/8 tires with 16-1/4 tires?
Shannon Casto is offline
Old 07-02-22, 02:17 PM
Leisesturm
Quoted: 2495 Post(s)
Liked 738 Times in 522 Posts
Of course. Can you find 16.25" tires is the question. Why, is also a valid question.
Leisesturm is offline
Old 07-02-22, 07:46 PM
VegasTriker
Quoted: 523 Post(s)
Liked 229 Times in 181 Posts
Selection is mighty slim but they are available
The answer is yes but be sure you buy a tire that will fit your ISO 349 rim. At one time the 16" wheel on recumbent bikes was a lot more common but these days with fewer bikes and more trikes being made it has become harder to find. You can see all about rim sizes here https://www.sheldonbrown.com/rim-sizing.html. It is also true that fractional size tires such as 16 X 1+1/4 are not interchangeable with 16 X 1.25 (ISO 305). Found that out the hard way when I bought a tire at my local discount store. It was the right diameter in inches but would not mount on the rim. Schwalbe makes a 16 inch ISO 349 tire in 1+1/4 width. https://www.modernbike.com/schwalbe-...16x1-1-4-black
VegasTriker is offline
Old 07-06-22, 08:36 AM
BlazingPedals
BlazingPedals's Avatar
Quoted: 1514 Post(s)
Liked 734 Times in 455 Posts
Going from 1 3/8" to 1 1/4" is a very small change and shouldnt' be a problem. Just make sure, as Vegas says, you get the correct ISO (also called Bead Seat Diameter) size. Matching the rim size is VERY important. The size of the tire will be in metric, imprinted on the sidewall. Your current tire probably says something like 37x349. A 1 1/4" wide tire would be a 32x349.
BlazingPedals is offline
