Chain scratches a front chainring
Bikes: 2008 jamis ventura race
Quoted: 25 Post(s)
Hi,
Just started the process of adjusting the front and rear derailleur, trying to find where the scratching sound is coming from.
I've got 2 front chainrings and 10 on a cassette. The sound comes from the chain rubbing against a big chainring when the chain is on a smaller one (crankset) and 1-2 smallest gears (cassette).
Is it possible to align chainrings or it makes more sense just to buy new?
aka: Dr. Cannondale
Quoted: 2159 Post(s)
Liked 3,457 Times
Hi,
Mosr bikes are not designed to run in that gearing combination.
Likes For rccardr:
rebmeM roineS
Quoted: 653 Post(s)
Liked 347 Times
If you only have a problem when on the small chainring and 1-2 smallest cogs, then try not using that combination.
Likes For JanMM:
Quoted: 4847 Post(s)
Liked 3,980 Times
The chain is probably hitting the teeth of the big chainring. Ths is basically a fact of life on any bike with lots of cogs in back unless the chainstays are very long. It is made worse when the chainrings are very different sizes. On bikes with compact gearing (say 50-34 in front) and the short chainstays of a performance bike, the two small cogs in back are often completely unusable when in the inside chainring because the large chainring pins (or the teeth themselves) will try to pick up the chain and shift it to the big chainring.
Most of us simply consider those gear combinations unusable.
Likes For 79pmooney:
hello
Just don’t crosschain. Chainrub occurs whenever you crosschain. Small ring, small cog combo is a no no with most drivetrains. Same goes for big ring, big cog combo. Also, they cause unnecessary wear and tear.
Likes For roadfix:
Quoted: 4527 Post(s)
Liked 1,670 Times
New parts won't fix this. It is built into the geometry of the frame and is acceptable because the drivetrain manufacturer did not intend that you would ride in those gears.
Likes For Kontact:
Quoted: 682 Post(s)
Liked 455 Times
You don’t need to buy anything.
To give a specific example
If you’ve got 50/34 chain rings
and a 10 speed cassette covering 11-28 which is 11-12-13-14-15-17-19-21-24-28
then your small/2nd smallest is 34:12 which is pretty much the same as 50:17, the large ring and 6th smallest cog
so there’s a big overlap.
Likes For choddo:
Method to My Madness
Quoted: 2025 Post(s)
Liked 1,519 Times
Hi,
Likes For SoSmellyAir:
Liked 1,670 Times
Likes For Kontact:
Bikes: 1974 PX-10E sold, 1977 Witcomb stolen, 1980 Roberts 1 speed, 1987 Cyclops 3 x 6 friction triple crank, 2010 Masi Commuter 1 speed, 2017 Ribble 525 2 x 10 with Ergos
Quoted: 60 Post(s)
Liked 28 Times
Probably any 2 x 10 drivetrain on any road bike with relatively short chainstays will do this in one or two small/small gears if it has a 16 tooth chainring difference and a standard chainline. You can fix it, though if you really want to use those gears and can accept compromise elsewhere.
Some things to try:
1. Reduce the tooth-size difference of the chainrings. If you have a 50/34 chainset, maybe 46/34 would do it, if you are willing to give up the top end.
2. Shift the right crank outward 2-3 mm to reduce the chain angle in small/small. This will make the big/big gears rougher and maybe unusable, and it may be easy or hard to do depending on your bottom bracket type. For square taper use a spacer or two under the right cup, moving both cranks to the right, or install an axle 4-6 mm longer, moving both cranks outward. Check first that the front derailler can reach out the 2-3 mm further. Choosing a suitable new front derailler might be messy.
Good luck with this. You should have the freedom to set up and use your bike the way you want to.
oldschoolbike
Some things to try:
oldschoolbike
Liked 3,980 Times
I considered saying some of what oldschoolbike said but felt it was better to keep my post above simple. I agree. The bike should do what we want it to do.
I like the ability to run small-small (even on triples) because I love doing hard and long climbs. Many of those have stretches where the grade levels out in the middle. Not using small-small means either staying in too low a gear or double shifting, only to have the double shift back as the steep grade resumes.
Another trick that will allow more extreme small-small combos to run smoothly, if not silently is to trim the front derailleur so the outer cage rubs on and slightly pushes the chain in. (Not possible with all indexing systems. I use friction shifting so it is easy. In the earlier days of brifters, racers were known to use friction downtube shifters for the front for lighter weight and reliability. That also included the trim option.)
Quoted: 854 Post(s)
Liked 1,087 Times
You can also mount some chainring shims between the outer chainring and the spider and the bolts go through the shims. This is an entirely experimental trick for your individual bike as the problem that can arise is that you create too large of a gap between the small and large chainrings which allows (on some bike setups) the chain to get stuck between them when shifting sometimes. You may get lucky and it will work with no issues. Here's just an example and they come in different thicknesses and diameters. Sugino 0.7mm Chainring Bolt Spacers (10 x 14 x 0.7mm) - Set of Five | eBay These are 0.7mm thickness which would be about the thickest I would try. As others have mentioned, most of us just stay away from those gear combos that rub.
Likes For Crankycrank:
Liked 3,038 Times
you could try an 11sp chain to see if the noise goes away. it might create for lazy shifting. ymmv
-Oh Hey!
-Oh Hey!
Quoted: 1103 Post(s)
Liked 1,045 Times
On one of my bikes, in order to accommodate the wide spread of gearing 16t difference in the front and 23t difference in the rear, the rear der doesn't have enough spring tension in the small/small to stop the chain from skipping. Although it is possible to mess with things to try to make them work sometimes we have to accept some limitations. Troul mentioned switching to an 11sp chain, my experience has been that the narrower chains are better at cross chaining without having rubbing or issues and its probably not a bad suggestion. I would suspect you'll still have rubbing in the smallest cog but maybe not the second smallest.
Noise-wise I doubt it would be much better, maybe have the advantage of the pick up pins not trying to grab the chain to help it up. Not certain how long it took, though I'd guess a long time from the age of the ders, but I've seen two bikes with worn through front ders from doing this.
Likes For Russ Roth:
Liked 3,980 Times
Liked 1,670 Times
Another trick to avoid chain rub is to remove the second chainring entirely, or give up bicycling.
Quoted: 25 Post(s)
Quoted: 2542 Post(s)
Liked 3,018 Times
There are several different ways to compare sprocket/chainring/wheel combinations. Some people prefer "gain ratios" or "gear development," but I've used "gear inches" for many decades, so that's what I'm used to. All the methods result in numbers that you can utilize for the comparisons.
(If you're curious, here's a forum thread where the differences between those methods are explained.)
Here's one bike gear chart. You choose your chainring tooth counts, sprocket tooth counts, etc., from the drop-down menus at the top of the page and then click "Calculate."
In the table that the calculation will produce, chainring tooth counts are listed in the column heads, and sprocket tooth counts are listed in the rows.
I just calculated the gears for 49/36 chainrings and an 11/28 cassette, using the default tire and wheel sizes. 36/11 (small to small) gives an 86" gear. So does 49/15 (large to middle or thereabouts).
Your bike may not include a large-chainring/moderate-sized-sprocket that is precisely identical to your small/small combination, but a difference of 2 or 3 inches will be all but imperceptible.
Likes For Trakhak:
Quoted: 682 Post(s)
Liked 455 Times
and for a simple example of ratios, ignoring the other factors that can change gear inches but would involve swapping out wheels or cranks, using the tooth counts I used in the post above, you can see the ratio of front T divided by back T overlap like this between the chain rings. The highest numbers in this chart represent the hardest & highest speed and the smallest numbers are the climbing gears. Big overlap where you don't really need to use the small/small section of the cassette and using big / biggish instead will give you similar effort and no noise.
Quoted: 532 Post(s)
Liked 475 Times
Hi,
Cross-chaining can be expected to run poorly or even be unusable - just avoid it, it's not useful.
Anything you do to "fix" it will hurt something else, if you don't have a very specific objective then just leave it and live with it.
Look at a gear inch calculator for your specific set-up until you understand it.
Quoted: 60 Post(s)
Liked 28 Times
oldschoolbike
Quoted: 854 Post(s)
Liked 1,087 Times
My experience with different types of epoxies is that they would not survive an angry attack by a steel chain. Great for bonding and light duty filler but not great for abrasive/cutting situations.
Liked 1,519 Times
Several places, but I find this to be the best visualization:
Bicycle Gear Calculator (gear-calculator.com)
